Installation location of the gateway control unit, Audi A3 8PA
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post10-06-2016, 11:56    Subject: Installation location of the gateway control unit, Audi A3 8PA Quote
I would appreciate it if someone could tell me where the gateway control unit is located in an Audi A3 8PA.
Thanks, best regards, Rainer.
dieselschrauber likes this.
Post10-06-2016, 13:38    Subject: Installation location of the gateway control unit, Audi A3 8PA Quote
Hi Rainer,
It is located in the driver's footwell. Remove the cover, take off the air duct for the footwell, and you're done.
Greetings.
Guste.
Post10-06-2016, 16:05    Subject: Installation location of the gateway control unit, Audi A3 8PA Quote
Addition: It is attached to the center tunnel above the accelerator pedal. icon_idea.gif
 File size:  1.29 MB
 Viewed:  9267 times
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8P Alarm: Gateway Issues & Error Solutions On-Board Diagnostics (OBD)
No new posts CAN Gateway A3 8PA: Incorrect Coding? On-Board Diagnostics (OBD)
No new posts Passat 3C: Gateway Replacement Guide On-Board Diagnostics (OBD)
No new posts Disable 4Motion control module in the CAN gateway On-Board Diagnostics (OBD)
