AC Compressor Not Working: Troubleshooting Guide
Go to page: 1, 2, 3, 4  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
vag-driver
Post11-05-2016, 12:00    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
Hello everyone,
The text refers to a Sharan 7N manufactured in 2011. Yesterday, the cooling system was drained and refilled. The system is leak-free, and the initial suspicion that there was too little coolant was not confirmed. Only 90 grams of coolant were missing.
The error memory is empty, but the compressor is not starting.
Now, I would appreciate some well-informed advice on what else I can check using VCDS.
Thank you very much.
Andreas.
Translated on 02-09-2026, 1:54.
Post11-05-2016, 12:07    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
Perform an Autoscan, then access the climate control module, and check the deactivation conditions. There's a measurement block available for this.
Translated on 02-09-2026, 1:55.
vag-driver
Post11-05-2016, 13:06    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
Here's a car scan:
Wednesday, April 20, 2016, 07:19:34:19385
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 15.7.4.1
Data as of: 20160226
Vehicle Identification Number: WVWZZZ7NZBV023072
License plate: xyz
Mileage: 97120 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 7N (7N0)
Scan: 01 03 05 08 09 10 15 16 17 18 19 25 2B 36 37 42 44 46 47 4F
52 53 55 56 61 62 69 6C 6D 72 77 BE BF
Mileage: 97,120 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
2B steering column lock. -- Status: OK 0000.
36-seat adjustable passenger seat -- Status: OK 0000.
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
6C Rear-view camera -- Status: OK 0000
6D tailgate -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
77-Phone -- Status: OK 0000
Rear left sliding door -- Status: OK.
Rear right sliding door -- Status: OK 0000.
Address 01: Engine Control Module (J623-CFGB)
Label file: DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 F, HW: 03L 907 309 Q.
Component: R4 2.0L EDC H24 0257
Revision: 44H24--- Serial number:
Encoding: 0019001A043401080000
Operating number: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01103L906018F 003003
ROD: EV_ECM20TDI01103L906018F_VW36.rod
VCID: 2D573FB17C5A8756E5-8078
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics
Label file: 7N0-614-109.clb
Part number SW: 7N0 614 109 L, HW: 7N0 614 109 L.
Component: J104 C3 450M VDD4 0008
Revision: --H07--- Serial number: 00000003531178
Encoding: 0023072
Operating number: WSC 00020 790 00000
VCID: 366510DD410CC48E94-8062
Address 05: Access/Startup Authorization (J518)
Label file: DRV\5K0-959-434.clb
Part number SW: 5K0 959 434 A, Part number HW: 5K0 959 434 A.
Part number: VWKESSYPQ35GP 085 0802
Revision: 00085000 Serial Number: 0140603123
Encoding: 03100C
ASAM Dataset: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP.rod
VCID: 336329C99A7ED1A6B3-8066
Address 08: Climate Control/Heating (J255)
Label file: DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 J, Part number HW: 5K0 907 044 J.
Part: Clima-Sharan H11 0104
Revision: 00002001
Encoding: 0000000109
ASAM Dataset: EV_ClimatronicSharan A01005
ROD: EV_ClimaAutoSharaBasis_VW36.rod
VCID: 326D2CCD6564D8AEB8-8066
Slave 1:
Subsystem 1 - Part number SW: 7N0 907 049 B, HW: 7N0 907 049 B.
Component: KBT-H 004 0102
Serial number: 20101220000000011735
Address 09: Central Electronics (J519)
Label file: DRV\1K0-937-08x-09.clb
Part number SW: 5K0 937 087 M, Part number HW: 5K0 937 087 M.
Component: BCM PQ35 H 011 0046
Revision: BE011001
Encoding: 4E510A3BE937F3C0500800C0740009E443551408676D25F2E4808700A2C1
Operating number: WSC 00020 790 12345
VCID: 3F8B75F9AE3605C647-806A
Subsystem 1 - Part number SW: 7N1 955 119 A, HW: 7N1 955 119, Label file: DRV\1KX-955-119.CLB.
Component: WWS 110905 31 0032
Encoding: 000D9D
Subsystem 2 - Part number SW: 7N0 955 559 HW: 7N0 955 559 Label file: DRV\7N0-955-559.CLB
Component: RLFS 021 0022
Encoding: 0780BB
Subsystem 3 - Part number: 7N0 951 171.
Component: DWA sensor 00 002 0205.
Encoding: 000000
Subsystem 4 - Part number: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Encoding: 000000
Address 10: Parking Assist 2 (J446)
Label file: DRV\1Q0-919-475.clb
Part number SW: 7N0 919 475 HW: 7N0 919 475
Part: PARKING ASSIST 8K H04 0010
Revision: -------- Serial Number: 80231034802665
Encoding: 318001
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 78F9DEE5C398F2FE46-802C
Address 15: Airbag (J234) Label file: 5K0-959-655.clb
Part number SW: 7N0 959 655 B, Hardware: 7N0 959 655 B.
Part number: VW10Airbag01L H07 0013
Serial number: 003GFPR2BKD3
Encoding: 00314C
ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3E7508FDA13C0CCE4C-806A
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60A4062A139DP
Encoding: 000000
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: --- HW: ---
Component: S. Sensor, passenger side --- ---
Serial number: 3503ETS6013C227139DC
Encoding: 000000
Rear side airbag crash sensor (driver's side).
Subsystem 3 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60B0E429139DQ
Encoding: 000000
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: --- HW: ---
Component: S. Sensor, Passenger Side. --- ---
Serial number: 3523ETS606E783913DD
Encoding: 000000
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60EF6F3913DD0
Encoding: 000000
Address 16: Steering wheel electronics (J527)
Label file: DRV\5K0-953-569.clb
Part number SW: 5K0 953 501 BM, HW: 5K0 953 569 L.
Component: STEERING MODULE 009 0136
Revision: FF010039 Serial number: 20101213300280
Encoding: 110A240000
Operating number: WSC 40517 000 1048576
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 76E5D0DDC98C848E54-8022
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 3C8 959 537 D, HW: 3C8 959 537 D, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-TK6 H06 0022
Encoding: E20000
Address 17: Control panel module (J285)
Label file: DRV\5K0-920-xxx-17.clb
Part number SW: 7N0 920 870 A, Hardware: 7N0 920 870 A.
Component: KOMBI H20 0420
Serial number: 00000000000000
Encoding: 140F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 306926C56B68EABECE-8064
Address 18: Auxiliary heater
Label file: DRV\1K0-815-007.clb
Part number: 7N0 963 272 A
Component: Portable heater 043 4730
Revision: 00043000 Serial number: 09022127000000
Encoding: 0031142
VCID: 336329C9527ED1A6B3-8066
Address 19: Diagnostic interface (J533)
Label file: DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 D, HW: 1K0 907 951.
Component: J533 Gateway H35 0614.
Revision: H35
Serial number: 041210F2003181
Encoding: 468002
Operating number: WSC 00000 864 716674
VCID: 316F23C16862E3B6C1-8064
Address 25: Immobilizer (J334)
Label file: DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234
Part number HW: 5K0 953 234
Component: IMMO H20 0420
Serial number:
Encoding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADDF4AD8D34506EC0-803E
Address 2B: Steering column lock. (J764)
Label file: DRV\5K0-905-861.clb
Part number SW: 5K0 905 861 A, Part number HW: 5K0 905 861 A.
Component: ELV-PQ35 H20 0220
Revision: 00000000 Serial number: 10000090905004
Encoding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E5538BD715CFC4EDC-807A
Address 36: Seat adjustment for driver (J810)
Label file: 3C0-959-760.lbl
Part number SW: 3C8 959 760 A, HW: 3C8 959 760 A.
Component: Seat Memory. Part Number: H05 2201.
Revision: 00H05000
Encoding: 000018
Operating number: WSC 12336 024 394758
VCID: 336329C9927ED1A6B3-8066
Address 37: Navigation (J0506)
Label file: DRV\1T0-035-680.clb
Part number SW: 1T0 035 680 C, HW: 1T0 035 680 C.
Component: RNS-MID H42 2720
Revision: AB001001 Serial Number: VWZ6Z7K4353137
Encoding: 06050002010000A000
VCID: 2E5538BD795CFC4EDC-807A
Address 42: Door electrical driver (J386)
Label file: 7N0-959-793.clb
Part number SW: 7N0 959 793 E, HW: 7N0 959 793 A.
Component: TSG FA H04 0400
Revision: Serial number: 0000110558255
Encoding: 01153E20DE00411001
VCID: 44817A15C7D0661E1A-8010
Address 44: Steering Assist
Label file: DRV\5N1-909-144.clb
Part number SW: 5N1 909 144 L, HW: 5N1 909 148 G.
Component: J500__APA-BS, Class 325, 0802.
Revision: 1AH03729 Serial Number: 00103480158201
Coding: 0000258
VCID: 3B7301E97A2E19E66B-806E
Address 47: Soundsystem (R12) Label file: 5K0-035-456.clb
Part number SW: 5K0 035 456 A, HW: 5K0 035 456 A.
Component: Corporate Amplifier 8K H06 0180.
Revision: -------- Serial Number: BP218809236600
ASAM Dataset: EV_AudioAmplifier8ChannelBNO1 A01003
ROD: EV_AudioAmplifier8ChannelBNO1.rod
VCID: 2859CEA553B8A27E16-807C
Address 4F: Central Electricity II (J520)
Label file: DRV\1K0-907-532.clb
Part number SW: 7N0 907 532, HW: 1K0 907 951.
Component: EZE_2 H35 0614
Revision: H35
Encoding: 050B0500
VCID: 6FEBE5B9BED6B54697-803A
Subsystem 1 - Part number SW: 8R0 959 591 A, HW: 8R0 959 591.
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part number SW: 8R0 959 591 A, HW: 8R0 959 591.
Component: J394EE20SKB13 H02 0220
Address 52: Power door lock, front passenger side (J387)
Label file: 7N0-959-792.clb
Part number SW: 7N0 959 792 E, HW: 7N0 959 792 A.
Component: TSG BF H04 0400
Revision: Serial number: 0000110694398
VCID: 43837909C2DE612623-8016
Address 53: Parking brake
Label file: DRV\3AA-907-801.clb
Part number SW: 3AA 907 801 D, Hardware: 3AA 907 801 D.
Part number: J540 EPB4 VW-53083 0006.
Revision: H18 Serial Number: 00000000131217
Encoding: 0024067
VCID: 326D2CCDAD64D8AEB8-8066
Address 55: Headlight range control. Label file: DRV\5M0-907-357-V2.lbl
Part number SW: 5M0 907 357 D, Hardware: 5M0 907 357 D.
Component: AFS Control Unit 0149
Revision: 00H04000 Serial Number:
Encoding: 3555545
VCID: 356717D15C0ACF969D-8060
Subsystem 1 - Part number: 1T0 941 329
Label file: 3D0-941-329.CLB
Component: AFS-List Module l 0001
Encoding: 00000054
Subsystem 2 - Part number: 1T0 941 329
Component: AFS-Lst. module r 0001
Encoding: 00000054
Address 56: Radio (J0506) Label file: DRV\1T0-035-680.clb
Address 61: Battery Management (J840)
Label file: DRV\1K0-907-534.clb
Part number SW: 7N0 907 534, HW: 1K0 907 951.
Component: Battery management system H35 0614.
Encoding: 030B085A
VCID: 71EFE3C1A8E2A3B681-8024
Subsystem 1 - Part number SW: 1K0 915 181 F, HW: 1K0 915 181 A.
Component: J367-BDM H07 0150
Address 62: Door electric, left/right (J388) Label file: 7N0-959-794.clb
Part number SW: 7N0 959 794 F, HW: 7N0 959 795 B.
Component: TSG HL H03 0400
Revision: Serial number: 0000111312028
Encoding: 01007C200000411001
VCID: 4685601DF1EC540E04-8012
Address 69: Trailer (J345) Label file: DRV\7N0-907-383.clb
Part number SW: 7N0 907 383 HW: 7N0 907 383
Component: Trailer H07 0101
Revision: 3I001002 Serial number: 00000138883202
Encoding: 410C040001000000
VCID: 73E3E9C9D2FE91A673-8026
Address 6C: Rear view camera
Label file: DRV\5N0-907-441.clb
Part number SW: 7N0 907 441, HW: 7N0 907 441.
Part: J772__Rearview 0020
Revision: 00H08000 Serial Number: 525PA8-J0Y0329
Encoding: 0030011
VCID: 6ED5F8BD79DCBC4E9C-803A
Address 6D: Rear hatch (----)
Label file: DRV\7N0-959-107.clb
Part number SW: 7N0 959 107 B, HW: 7N0 959 107 A.
Component: HDSG Module H11 0803
Revision: 41011001 Serial number: 330000559
Encoding: 0733334003
ASAM Dataset: EV_HDSGVW428 201133
ROD: EV_HDSGVW428_SE36.rod
VCID: 366510DD890CC48E94-8062
Address 72: Door electric strike, high, right (J389)
Component: TSG HR H03 0400
Revision: Serial number: 0000111314705
Address 77: Phone (J412)
Label file: DRV\3C8-035-730-A.clb
Part number SW: 5N0 035 730 D, Hardware: 5N0 035 730 D.
Component: Telephone 009 0511
Revision: -------- Serial Number: 35909603087080
Encoding: 020100000100000000010000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_SE36.rod
VCID: 295FCBA148B29B7609-807C
Address BE: Rear left sliding door (J558)
Label file: 7N0-959-244.clb
Part number SW: 7N0 959 244
Part number HW: 7N0 959 244
Component: Sliding door_l 005 2213
Serial number: 10481927.
ASAM Dataset: EV_AST A03002
ROD: EV_AST.rod
Address BF: Rear right sliding door (J731)
Component: Sliding door_r 005 2213
Serial number: 10481904.
ROD: EV_AST.rod
End----------------------------(Duration: 05:17)-----------------------------
Which values at address 08 should I examine more closely?
Translated on 02-09-2026, 2:44.
dieselschrauber likes this.
Post11-05-2016, 13:25    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
Look for "shutdown condition" within the measurement blocks, and hover your mouse over it to see the explanatory texts.
Also, please check the current readings for both the compressor and the swash plate.
It's also possible that the climate control system is activating the compressor, but the pulley is damaged. Let's check if the center of the pulley is rotating, or if it's only rotating on the outer edge (you might need a mirror). This is a common issue. Sometimes it's because the compressor is seized (meaning it's fulfilling its intended function), but sometimes it just happens for no apparent reason.
Greetings.
Guste.
Translated on 02-09-2026, 2:45.
Post11-05-2016, 14:42    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
Translated on 02-09-2026, 2:46.
vag-driver
Post11-05-2016, 23:27    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
Here are the measurement readings:
Address 08: Climate Control/Heater (5K0 907 044 J)
21:15:23
001 Magnetic coupling for air conditioning system status control, relay output, not in use.
005 Compressor current; Actual value 0.820 A.
006 Compressor current; setpoint 0.820 A.
007 Compressor load: 1.9 Nm.
008 Compressor shutdown condition; last shutdown via the engine control unit (ECU) over CAN.
009 Compressor shutdown condition: Compressor active; no shutdown condition detected.
text
010 Compressor shutdown condition; third-to-last shutdown initiated by the engine control unit via CAN.
011 Compressor shutdown condition; outdoor temperature too low (second to last reading).
012 Compressor speed: 900 rpm.
Wednesday, May 11, 2016, 21:33:07:19385
"Der schnelle braune Fuchs springt ĂŒber den faulen Hund."
Zur Frage mit der Riemenscheibe: Sowohl die Riemenscheibe als auch der innere Teil drehen. Bei AC ausgeschaltet hÀtte ich aber erwartet, dass der innere Teil stehen bleibt. What he doesn't do.
Is there any chance that hitting the compressor housing could make it functional again?
Translated on 02-09-2026, 2:48.
Post12-05-2016, 10:15    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
If the compressor shaft is definitely rotating but nothing is being pumped, then either the compressor is broken or there is nothing to pump. icon_idea.gif
Translated on 02-09-2026, 2:50.
vag-driver
Post12-05-2016, 10:21    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
The system was evacuated and refilled on Tuesday, so a lack of refrigerant can be ruled out.
I will then replace the compressor. Which manufacturer do you recommend? What other parts should be replaced at the same time? For example, the dryer...?
Translated on 02-09-2026, 2:51.
vag-driver
Post12-05-2016, 10:29    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
The pulley and the inner runner with the 3 contacts were rotating, but the shaft in the middle was not.
Translated on 02-09-2026, 2:52.
Post12-05-2016, 10:48    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
Well, that doesn't look good. Without the compressor shaft rotating, nothing will happen. Based on your description, it seems like there's a faulty compressor.
vag-driver
Post12-05-2016, 22:26    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
I just removed the base plate and took a look at everything. The power is on. I can turn the compressor's impeller by hand, but it's not being driven by the system.
I'm going to order a new one.
- Are there any recommendations regarding the manufacturers?
- What else should I exchange? A dryer...?
Translated on 02-09-2026, 2:53.
Post13-05-2016, 10:31    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
If the compressor can still be turned manually, then there's a good chance you only need a new pulley.
vag-driver
Post13-05-2016, 10:41    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
I haven't disassembled a climate control compressor before, so I hope I don't ask too many silly questions.
What is the internal structure of the disc like? I assumed that the shaft inside might have broken off.
In its installed state, the disc is probably not replaceable icon_question.gif.
Translated on 02-09-2026, 2:54.
vag-driver
Post14-05-2016, 10:22    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
"I took a picture of the pulley. It's clear that the rivets on the driven pulley have sheared off. I checked the alternator's freewheel mechanism. The fan wheel is not stuck, and the belt is running smoothly. The compressor does not have a magnetic clutch; it is valve-controlled."
As mentioned before: The wave (black star) can be turned by hand.
Now, the exciting question: What caused the rivets to be sheared off?
 Riemenscheibe Klimakompressor defekt
 File size:  5.74 MB
 Viewed:  4579 times
Translated on 02-09-2026, 2:55.
vag-driver
Post15-05-2016, 10:15    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
I'm going to replace the wear plate now. According to a specialist, this is wear and tear that occurs with usage.
As soon as the exchange has been completed, I will inform Ecuh again.
Post15-05-2016, 10:39    Subject: AC Compressor Not Working: Troubleshooting Guide Quote
vag-driver wrote:
I am now going to replace the drive belt. According to a statement from an expert, this is wear and tear that is dependent on mileage.
As soon as the exchange has taken place, I will report back to Ecuh.
Okay, so is it rust on the rivet or material fatigue from the back-and-forth movement?
What is the mileage?
Translated on 02-09-2026, 2:56.
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Air conditioning compressor making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts AC Compressor Not Working: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Climate compressor T5 only runs occasionally, shutdown co... On-Board Diagnostics (OBD)
No new posts Climatronic AC Compressor: When Does It Run? Transmission, Chassis, Body & Interior
No new posts 2.5L AKN Engine Not Running - Troubleshooting Diesel Engine Technology
