Tapping noises, Audi A3 8P rear hatch/trunk lid (Solution)
Karma: +807 / -0   Thank you, like it!
Post11-07-2016, 10:44    Subject: Tapping noises, Audi A3 8P rear hatch/trunk lid Quote
In the Audi A3 8P, the upper mounting screws that secure the lower plastic interior trim of the tailgate can become loose. These screws then fall down into the tailgate.
When the tailgate is closed or when driving on rough roads, it rattles because the screws in the tailgate are loose and bouncing around.
Two retaining screws are located in the recessed area of the aforementioned cover. Two additional retaining screws are located on top, underneath the removable covers of the cover.
At the remaining attachment points, the trim is only clipped onto the metal of the tailgate.
You can use slightly larger screws or modified mounting brackets, or simply reattach the screws with a dab of body sealant to prevent them from coming loose on their own.
 File size:  186.29 KB
 Viewed:  2254 times
 File size:  163.64 KB
 Viewed:  1206 times
Translated on 15-07-2026, 16:45.
Ratings - Tapping noises, Audi A3 8P rear hatch/trunk lid
No new posts MKB, AHW, AKQ, APE: Documenting Clicking Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Sunroof Rattle Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Engine Knocking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Does the A6 C4 Avant rear door fit the rear door? Transmission, Chassis, Body & Interior
No new posts VW Touran: Engine Knocking Noise at 344k km Diesel Engine Technology
No new posts Rear hatch Transmission, Chassis, Body & Interior
No new posts Images for 3C Rear Hatch Upload
