Clutch Pedal Switch CFGB
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post24-03-2019, 14:01    Subject: Clutch Pedal Switch CFGB Quote
Hello everyone,
I wanted to check the switching point of my clutch pedal sensor on the CFGB today using VCDS, but I couldn't find it in the measuring values of the engine control unit. According to the wiring diagram, it should be sensor G476.
Has anyone ever found this before, and if so, under what name or designation?
Thank you & best regards.
pretzel man
Translated on 27-08-2026, 16:36.
No new posts Kupplungspedalschalter Diesel Engine Technology
No new posts Clutch Pedal Switch Disconnected: Save 1L Fuel On-Board Diagnostics (OBD)
No new posts Audi A3 8P Oil Temp Sensor CFGB Diesel Engine Technology
No new posts Air Mass Meter (CFGB) - Implausible Reading Diesel Engine Technology
