spock wrote: |
| Where is that thing (on the turbocharger - that's probably clear, but where exactly)? |
Do I have to remove the turbocharger to get to it? Or is there some way to access it?
Hi.
On my tractor, you can still easily access it: At the top of the loader, you can see the membrane housing for the VTG adjustment. Above it is the control hose, and below it, the actuation rod comes out.
You'll probably have to find the rest yourself }.
I didn't have to do any dismantling during the VTG activities.
However, if you remove the double-angled pipe leading to the charger inlet (with the KGE connection), you will have a clearer path.
