1048578 Basic configuration not performed, control panel
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Driver123
Post25-03-2022, 14:36    Subject: 1048578 Basic configuration not performed, control panel Quote
Hallo,hab ein kl. Problem.
Since the vcds service doesn't allow for automatic scheduling, I adjusted it manually instead.
Since then, this error has been occurring.
1048578: Initial configuration not performed.
Terminal block insert.
Can someone help me with this? Thank you!!!
 File size:  2.94 MB
 Viewed:  3051 times
Translated on 16-07-2026, 3:08.
Back to top Profile PM Email
Driver123
Post25-03-2022, 14:37    Subject: 1048578 Basic configuration not performed, control panel Quote
It's a Passat from June 2017.
2.0 TDI engine. 150 horsepower.
Translated on 16-07-2026, 3:09.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber and Driver123 likes this.
Post25-03-2022, 14:49    Subject: 1048578 Basic configuration not performed, control panel Quote
The control unit has lost its default settings. The maintenance interval was not reset correctly.
Did you also change the oil quality when you adjusted it?
The period is often forgotten.
What exactly did you do / change?
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
Michael.
Driver123
dieselschrauber likes this.
Post25-03-2022, 15:02    Subject: 1048578 Basic configuration not performed, control panel Quote
You're welcome. It worked! XX
Ich hatte den Inspektions- u. Service interval.
set to 30,000 km.
Now back to 15,000, no more error messages.
You're welcome.
Translated on 16-07-2026, 3:11.
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts DSG: No 6-Speed Default Setting Possible On-Board Diagnostics (OBD)
No new posts Throttle valve basic setting not possible, 1.8L R4/5V AGN Gasoline Engine Technology
No new posts Audi A5: 7-Speed S-Tronic Basic Settings Not Working Transmission, Chassis, Body & Interior
No new posts Default settings + LOG BKD Upload
