n0kat Guest
12-10-2016, 11:36 Subject: Golf IV Light Switch |
Hi everyone,
My plan: Turn on the light switch or change the pin configuration on the connector as follows:
Stand Light - Nothing Happens (No Light)
Headlight + Fog Lights - Headlight ON
Headlights - Headlights on without headlights
Headlights + Fog Lights - Turn headlights on with parking lights
Does anyone have a schematic, pinout diagram, any kind of power source, or just plain nonsense comments?
I look forward to any feedback.
Best regards
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
12-10-2016, 11:58 Subject: Re: Golf IV Light Switch
ich habe einen Golf IV und suche einen neuen Lichtschalter. Gibt es bestimmte Marken oder Modelle, die empfehlenswert sind?
Ich benötige einen Schalter, der sowohl die Scheinwerfer als auch die Innenraumbeleuchtung steuern kann.
Vielen Dank für eure Hilfe!
Viele Grüße,
[Dein Name] |
n0kat wrote: | Does anyone have any {suggestions}, {silly comments}?
I welcome any feedback |
I have plenty more stupid comments  . However, I am completely committed to this point.
n0kat wrote: | Standlicht - Nothing happens (no light on)
Headlights + Fog Lights - Headlights on with parking lights |
If I read the list like that, then you just need to jump the indicator light to the NSW output. Nothing else.
I don't have a specific document handy, but I'm quite confident that Google offers something suitable.
You should make the conversion reversible, in order to pass the next TÜV (German technical inspection).
Should this be a replacement for daytime running lights, or a flashing hazard light switch? The latter should clearly demonstrate the offender's intent in a serious case and appropriately influence the severity of the punishment.
Best regards
Guste
Profile PM Garage |
n0kat Guest
12-10-2016, 13:15 Subject: Golf IV Light Switch |
Thank you, Guest, for the quick response,
You don't have to hold back  My opinions are important to me, they broaden my own perspective.
It shouldn't be a getaway car, but since you said that, I've noticed a mistake on my part: the indicator lights are probably just a cable connected to the switch for the front, which controls the two bulbs, and the rear indicator lights + license plate light?
Best regards
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
12-10-2016, 13:16 Subject: Golf IV Light Switch |
If the indicator light goes out, then the brake light also goes out, right? I dismiss the concerns that have been raised regarding the upcoming inspection.
Purely speculative: If the goal is a daytime running light solution without additional lights, I would suggest the term "Scandinavian circuit". In some vehicles, this was achieved by installing a cable or wire bridge on the fuse or relay carrier, while in others, it was done through programming. Automobile Zeitzeugen: |SUZUKI Swift Sport (2008)| |Smart 450 (2002)| |Honda CB 125 F (2018)|
12-10-2016, 13:41 Subject: Re: Golf IV Light Switch
Viele Grüße,
[Dein Name] |
n0kat wrote: | | The indicator light is probably just a cable to the switch for the front, with the two bulbs, and the rear indicator light + license plate light ? |
Why so many questions when the answer is just a few clicks away?
guste100 wrote: | | I don't have a specific booking in hand, but I'm very confident that Google offers something suitable. |
Google search for "light switch wiring golf 4" directly provides the correct answer on the first click. http://lmgtfy.com/?q=lichtschalter+belegung+golf4
Regarding image searches, do you also arrive at http://www.passatplus.de/umbauteile/stecker/stecker3.htm (look at the very bottom)?
Furthermore, you can activate the headlights when the switch is in position 0 using a simple jumper, as suggested by Huti (a jumper between pin 56 and TFL). See also here: http://forum.auto-steuerung.de/viewtopic.php?f=18&t=164&start=165 third post.)
Please be a bit more proactive next time
Greetings
Guste
Profile PM Garage |
n0kat Guest
12-10-2016, 13:57 Subject: Golf IV Light Switch |
Thank you for everything!
