Audi A4 1.9 TDI: Intermittent Starting Problems
robrob
Post20-10-2016, 22:20    Subject: Audi A4 1.9 TDI: Intermittent Starting Problems Quote
Good day.
I'm having the following problem:
"On my Audi A4, model year 2002, with a 1.9 TDI engine and 131 horsepower, I occasionally have the problem that it only starts on the second or third attempt."
It could be anything from 3 to 10 days, and then it might happen once every day again.
If it runs, it runs without any problems.
Is the temperature independent of the weather?
No error codes found.
Has anyone else encountered this error before and managed to fix it?
Thank you.
Translated on 04-09-2026, 16:12.
Wiesel
Post21-10-2016, 5:22    Subject: Audi A4 1.9 TDI: Intermittent Starting Problems Quote
How long do you let it idle per start attempt?
Are the temperatures displayed under "Diagnosis" plausible?
Please create a vehicle log and post it here.
Micha
Translated on 04-09-2026, 16:13.
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
Post24-10-2016, 10:17    Subject: Audi A4 1.9 TDI: Intermittent Starting Problems Quote
There was a TPI investigation.
I had the same problem with AWX and AVF.
Simply set the light switch to: parking light or low beam, and it will turn on icon_smile.gif.
Somewhere, the BUS system is colliding with the engine management system. Replacing the light switch might also help.
Otherwise:
Check the PD cables (they are located in the oil of the valve cover). But if that's the issue, he'll also likely have problems with the engine running.
Beste Grüße,
Hufe
Translated on 04-09-2026, 16:14.
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Audi A6 TDI: Intermittent Starting Problems Diesel Engine Technology
No new posts Audi A4 2.0 TDI: Intermittent Starting Problems Diesel Engine Technology
No new posts 1.6 CAY: Intermittent Starting Problems Diesel Engine Technology
No new posts Audi Starting Problems? ESP Failure Diagnosis. Diesel Engine Technology
