Audi A5 2.7 TDI Multitronic: Common Problems
Ro.Shm69
Post12-01-2017, 14:34    Subject: Audi A5 2.7 TDI Multitronic: Common Problems Quote
I'm new here and couldn't find a suitable topic using the search function. If there is one, please forgive me, and I would appreciate it if you could direct me to it.
Regarding my issue:
The day before yesterday, I drove my A5 as usual, without any issues. While driving on a slight incline, I suddenly heard a somewhat louder noise coming from the engine/transmission area.
Consequently, the coupling disengaged, and the car rolled away.
Even after restarting the engine, absolutely nothing happened in either D (Drive) or S (Sport) mode, except that the engine revved up.
The transmission was removed yesterday, but it hasn't been inspected yet to determine the cause of the problem.
Do you have any idea, or has anyone else experienced this exact problem before?
I've read quite often that it could be ZMS, but I'm pretty clueless.
Thank you in advance!
Translated on 30-10-2026, 7:35.
Karma: +805 / -0   Thank you, like it!
Post20-01-2017, 13:13    Subject: Audi A5 2.7 TDI Multitronic: Common Problems Quote
If you can't repair the car yourself, unfortunately, tips about potential causes of the problem won't be very helpful to you.
Ob der Fehler in fehlendem Kraftschluss zwischen Motor und Automatikgetriebe oder einem defekten Automatikgetriebe zu finden ist, könnte man mit VCDS herausfinden. Sure, here is the translation of the text from German to English:
Keywords:
- Speed of the input shaft of the gearbox.
- Perform an automatic scan or read the error codes from the vehicle's memory.
Translated on 30-10-2026, 7:37.
Karma: +649 / -0   Thank you, like it!
Post22-01-2017, 10:54    Subject: Audi A5 2.7 TDI Multitronic: Common Problems Quote
Hi.
The Multitronic is arguably the worst automated transmission that the VW Group could have produced, and it sounds like it's experiencing a complete transmission failure.
I recommend you sign up and describe the problem.
http://multitronicforum.de/viewforum.php?f=7
I know that there are specialists in this forum who can repair these transmissions for a portable device. Do some research or ask around. With Audi, you'll only hear the term "AT," and that will cost you 6000 euros plus additional expenses.
Best regards, Rüdi.
Translated on 30-10-2026, 7:38.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Multitronic Problems Audi A6 2.5 TDI Transmission, Chassis, Body & Interior
No new posts Multitronic Problems: Troubleshooting & Solutions Transmission, Chassis, Body & Interior
No new posts Reverse gear problem Audi A4 8D 1.8T Multitronic, first r... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A6 C5 Allroad transmission conversion: from Multitro... Gasoline Engine Technology
