Hello TDIMaster,
Here's a quote from the excellent Ulf:
"The preheating fuse often causes problems, and it's also well-hidden in some vehicles. For example, in a 1997 Golf 3, it's located on the top of the central electrical unit as an oversized flat fuse, making it difficult to access, while the owner's manual refers to the splash guard in the engine compartment."
In vehicles with a fuse box located on the battery, the glow plug fuse is usually located there as well.
I would also consider adding a temperature sensor in that location. If the sensor indicates "warm," the relay will not close for preheating.
Beste Grüße,
Hufe
Translated on 27-10-2026, 10:43.
