KData Scope: Unable to Activate/Unlock
safedriver
2002 Volkswagen Passat
Post27-11-2016, 14:57    Subject: KData Scope: Unable to Activate/Unlock Quote
Hello fellow diesel mechanics,
I hope I'm in the right place with my inquiry.
I recently purchased the VCDS professional diagnostic system KKL+CAN and have already done quite a bit with it.
Okay, I wanted to try data logging and reading with KDataScope. However, I can't open any logs because KDataScope always tells me that I need to activate it. I tried connecting it to the car's interface and first connected it with VCDS to make sure I have a connection.
After that, I started KDataScope and tried to open a log file from VCDS, but it didn't work because the license couldn't be activated.
After that, connect the laptop to the internet and try logging in using the customer account username and password. However, I always receive the error message: "Unable to connect to the 'dieselschrauber' server, or the customer account login credentials are invalid."
I have already tried reinstalling the program multiple times (both the German and English versions), and also on two different laptops, one with Windows 7 Professional and one with Windows 10 Home, but without success.
I've also tried running KDataScope as an administrator, but unfortunately, that didn't work either.
Both operating systems are current and always up-to-date, and VCDS runs without any problems. icon_smile_thumb_up.gif
Dominik
Skoda Ovtavia 5E Combi Style 4x4 2.0 TDi CRMB 150PS Euro 6 ohne SCR-Kat; BJ 2018
VW Passat 3BG Variant Highline; 1.9 TDI-PD 101PS; MKB: AVB; GKB: EEN; Umbau auf EMS(Valeo 4KKit)
Translated on 30-09-2026, 0:52.
Post27-11-2016, 15:58    Subject: KData Scope: Unable to Activate/Unlock Quote
Hello Dominik,
KDataScope uses the exact same data for activation as the login process for the customer account on the Dieselschrauber-Shop website. Therefore, if you can log in to your customer account, the activation should also work.
If you are certain that you have not accidentally mistyped anything here (pay attention to capitalization) and your operating system is at least Windows XP SP3, then in 99% of cases, the cause is that you have infected your computer with spyware/malware that is eavesdropping on SSL/TLS connections.
The fact that KDataScope is not activated is the least of your problems in this case, because why would someone be spying on encrypted connections? The keywords "online banking" and "webmail" come to mind.
KDataScope verifies the identity of the other party during connections, including authorization/licensing. icon_idea.gif If it's not my diesel engine unlocking code, the process is aborted.
For example, it has been documented that eavesdropping occurs through a tool (Sysprofile) that uploads "computer configurations" to a website, essentially a virtual "benchmark" comparison. It's likely that all sorts of other data is also being uploaded elsewhere.
You can check what happens during an activation attempt in the Windows command line using the command: `netstat -bn`.
KDataScope needs to connect to the IP address 178.209.53.204 (IP: ping dieselschrauber.de). Connecting to other IP addresses will result in a "sniffing" server that has nothing to do with us.
But now that it is public, the snooping software will probably be adjusted. icon_cool.gif
Translated on 30-09-2026, 0:55.
safedriver
Post27-11-2016, 16:39    Subject: KData Scope: Unable to Activate/Unlock Quote
Hello Rainer,
I used the command `netstat -bn` in the Windows command prompt to check the IP address. KDataScope always connects to the remote address: 178.209.53.204:443.
I can log in to the shop normally. However, I still get the error message described above when using the same login credentials in KDataScope.
When I try to enable KDAtaScope through the interface, I get an error message saying that no interface is connected, even though VCDS is working normally.
Dominik.
 Screenshot von der Kommandozeile
 File size:  56.56 KB
 Viewed:  1112 times
Translated on 30-09-2026, 0:58.
Post27-11-2016, 20:22    Subject: KData Scope: Unable to Activate/Unlock Quote
The KDataScope unlocking feature is only available in the RKS+CAN interfaces (which are our own designs), and not in the MicroCAN, HEX-USB+CAN, or HEX-NET interfaces.
Okay, I will translate the text and tell you when I started.
(Translation will follow after I indicate the start time.)
Starting translation: 2024-02-29 14:35:00 UTC
What is DiagTrack?
Translated on 30-09-2026, 0:59.
safedriver
Post27-11-2016, 20:54    Subject: KData Scope: Unable to Activate/Unlock Quote
Okay, thanks for the information.
I can't send you a private message because I need to have at least 5 forum posts.
Dominik.
Translated on 30-09-2026, 1:00.
safedriver
Post27-11-2016, 20:55    Subject: KData Scope: Unable to Activate/Unlock Quote
DiagTrack ist eine Software von windows die Fehlerberichte und Daten vom Betriebssystem an Microsoft schickt lt. Google.
Dominik
safedriver
Post27-11-2016, 20:56    Subject: KData Scope: Unable to Activate/Unlock Quote
Ok. Ich schreib dir wenn ichs versucht habe. "Thank you!"
Dominik
safedriver
Post27-11-2016, 22:14    Subject: KData Scope: Unable to Activate/Unlock Quote
I just tried it on both laptops -> without success. icon_sad.gif icon_sad.gif
Dominik.
Translated on 30-09-2026, 1:01.
Post28-11-2016, 11:23    Subject: KData Scope: Unable to Activate/Unlock Quote
Just tested, and it works with your data.
Accidentally copied/pasted a space into your email address or password?
If not, you cannot rely on secure SSL/TLS connections to your computers.
You might also want to run a virus scan on the entire system.
safedriver
Post29-11-2016, 8:59    Subject: KData Scope: Unable to Activate/Unlock Quote
Okay, if it's working with my data, then the problem is probably somewhere on my end.
I've tried entering my email address and password many times and always double-checked, so it should be correct.
Yes, I will run a virus scan and a malware scan, and thank you for the tip.
Is there perhaps another way to unlock it? Or is KDataScope programmed in such a way that it always checks with the server to see if it's unlocked, even when there's an existing internet connection?
Can I establish an SSL connection myself to make it work?
Dominik.
Translated on 30-09-2026, 1:03.
Post29-11-2016, 9:08    Subject: KData Scope: Unable to Activate/Unlock Quote
Hello Dominik,
KDataScope requires a secure connection to the server, one that prevents unauthorized access and modification. Otherwise, the licensing would be meaningless.
The connection doesn't need to be permanently online, but it does need to be connected for licensing purposes. I recommend practicing good computer hygiene, and that should resolve the issue.
Another option for unlocking would be the RKS+CAN diagnostic hardware.
http://shop.dieselschrauber.de/can-bus-interface-rks-can-c-24.php
However, I strongly advise you to take the issue of insecure/eavesdropped encrypted connections seriously, unless you don't care about compromised email or online banking.
Translated on 30-09-2026, 1:04.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The Electric Car - Why It Isn't Taking Off Technical Articles
No new posts A4 Doku: Engine Control Not Connecting to WFS. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI: GRA unlock issue - 90PS engine On-Board Diagnostics (OBD)
No new posts 1.6 TDI AGR module cannot be programmed Diesel Engine Technology
No new posts Transmission Control Unit: Recording Issues On-Board Diagnostics (OBD)
No new posts Navigation CD cannot be ejected Electrical Systems, Vehicle Electronics, Multimedia
