Hifigarage
15-12-2016, 15:58 Subject: Bordnetz Golf VII |
I'm new to this forum and I have a question right away. I have a Golf VII that I've converted from standard headlights to xenon, and now I want to code the car's electrical system. However, I'm getting the message "no documentation available". Can someone help me? Which bits do I need to code? Thanks.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
15-12-2016, 17:14 Subject: Bordnetz Golf VII |
no. Where is your car scan, and where can I see what's installed and how it's been coded?
Best regards, Rainer
Profile PM WWW Garage |
Hifigarage
15-12-2016, 18:05 Subject: Bordnetz Golf VII |
Oh, sorry, I'll be sure to pay attention next time. Here is the car scan.
| Description: |
 Download |
| File name: |
vcds golf VII.txt |
| File size: |
33.94 KB |
| Downloaded: |
1373 times |
Hifigarage
15-12-2016, 18:10 Subject: Bordnetz Golf VII |
Please disregard any errors, the entire vehicle is disassembled. I would also like to have the multifunction steering wheel coded, and I would be grateful for any assistance.
15-12-2016, 22:24 Subject: Bordnetz Golf VII |
Unfortunately, there is no label file available for your onboard control unit yet... please wait. I will pass on the information.
Hifigarage
16-12-2016, 9:34 Subject: Bordnetz Golf VII |
ok, danke. How long could it take approximately?
Best regards, Roy
16-12-2016, 12:05 Subject: Re: Golf VII Wiring |
Hifigarage wrote: | Hello,
Best regards, Roy |
No idea  Have you already searched online for auto-scans with identical control units and Xenon headlights?
In such cases, please do not blindly copy everything, but find out which bits/bytes cause the lamp error messages to disappear, as the rest of the vehicle environment is usually also hardly identical.
16-12-2016, 15:40 Subject: Bordnetz Golf VII |
According to Ross-Tech, VCDS 16.8.4 in English already has a corresponding label file, please test the long coding assistant with the English VCDS version.
Hifigarage
20-12-2016, 18:42 Subject: Bordnetz Golf VII |
Hello, thank you for the tip, I tried it but unfortunately the same thing happened, too bad.
Best regards, Roy
20-12-2016, 20:47 Subject: Bordnetz Golf VII |
Please use the English version for Autoscan...
