dieter.bayern
2005 Volkswagen Golf Free account, no CAN development support
16-10-2016, 15:07 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
I have a problem with the built-in heater in my car and I need help.
My car is a Golf V, 2.0 TDI 4Motion, first registered in 10/2005. The space heater has the problem that the corresponding button on the climate control unit lights up for about 2 seconds after being pressed, and then turns off without the space heater actually doing anything.
First, the data for the portable heater according to the sticker in the engine compartment:
Quote: | Duplicate Factory Label - Valid only in conjunction with the original
e1
00 0018
e1
02 1232
HEATING DEVICE Type TT-V
Voltage / Electricity Performance 12 V / 42 W
Maximum power: 5.0 kW
Fuel: Diesel/Biodiesel
allowed Operating Pressure 2.5 bar
Part Number: 1K0 010375 R |
Now the errors that were read out:
Quote: | Error Code: 1299
Central CAN-Bus Controller
- Communication error/Control unit incorrectly coded.
Error Code: 1408
Shutdown due to Undervoltage
- Shutdown due to low voltage
Error Code: 1412
Candle with flame monitoring Q8
- Flame monitoring candle Q8
Error code: 2251
Heizgerät
- Device is locked. |
Does anyone have an idea, or does anyone perhaps know exactly what the cause is?
Thank you!
Greetings,
Dieter
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
16-10-2016, 18:20 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] Erstmal startet das Ding nicht, da es verriegelt ist. Das muss zurück gestellt werden. Der Grund dafür kann die Unterspannung oder die Glühkerze sein. Fehler löschen und schauen was wieder kommt. Ein Wechsel der Glühkerze scheint aber sehr möglich. |
dieter.bayern
19-10-2016, 14:19 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] Danke, Matthias.
Ich verstehe von dem Ganzen nicht viel und ein Freund hat den Fehler gelöscht.
Ist das Gerät jetzt wieder entriegelt oder muss man am Gerät selbst Hand anlegen (das Problem besteht nach wie vor wenn ich auf die Taste am Klimabedienteil drücke)? |
Profile PM Garage |
19-10-2016, 14:37 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] Es gibt bei VCDS die Funktion des Entriegelns im Steuergerät der Standheizung. Dies würde ich zuerst einmal ausprobieren und schauen wie sie sich dann verhält. Das Fehler Löschen setzt nicht die Verriegelung zurück. |
dieter.bayern
02-11-2016, 17:12 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] Habe erst jetzt wieder Zeit, mich dem Thema zu widmen.
Zwischenzeitlich habe ich mich bei einem Fachbetrieb unter Nennung der Fehlercodes online erkundigt, ob eine Diagnose sowie die Nennung eines Preises möglich sind. Die Antwort war, dass der Brenneinsatz getauscht werden muss, da sich die Glühkerze der TT-V nicht wechseln lässt. Kosten: ca. 200 Euro für einen neuen Brenneinsatz sowie ca. 100 Euro für Montage und Prüfstandstest.
Laut Internet-Recherche lässt sich bei der TT-V anscheinend tatsächlich die Glühkerze nicht wechseln.
Außerdem hat die Recherche ergeben, dass bei einem neuen Brenneinsatz auch die Dichtungen getauscht werden sollten. Darüber wurde aber vom obigen Fachbetrieb nichts gesagt...
Weiß jemand wie das mit den Dichtungen ist?
Als nächsten Schritt werde ich die Standheizung entriegeln, um das weitere Vorgehen zu entscheiden. Laut Webasto Werkstatthandbuch muss man dazu an den Heizgerätekabelbaum ran, um die 20 A Sicherung zu entfernen. Weiß jemand, wo ich den beim Golf 5 finde?
Merci! |
Profile PM Garage |
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
dieselschrauber likes this. |
02-11-2016, 20:51 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] Hallo,
Zu den Dichtungen kann ich nix sagen.
Was das Entriegeln angeht: Die von dir beschriebene Vorgehensweise ist eigentlich für nachgerüstete Heizungen. Deine hängt am CAN und sollte daher über Diagnose entriegelt werden können.
Bevor du die zerlegst, guck dir mal den Widerstand in den Messwerten an. Unter Ansteuerung kannst du auch die Kerze ansteuern und dabei den Widerstand des Flammwächters beobachten. Dabei Ladegerät verwenden.
Gruss
Brezelmann Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
[VERKAUFT] Polo 6NF 1.4TDI (AMF) mit nachgerüstetem DPF, STH+FFB, Bj. 2000, 222tkm |
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
03-11-2016, 7:29 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] dieter.bayern wrote: | Habe erst jetzt wieder Zeit, mich dem Thema zu widmen.
Merci! |
So ist es.Wenn der Code 1412 wieder kommt und es weiterhin Startprobleme, Betriebsstörungen, Rauchentwicklung usw. mit der Webasto gibt, dann muss genau dass gemacht werden, was Du da schon geschrieben hast.
Der neue Brennereinsatz kommt zusammen als Kit mit der Dichtung zur Heizkammer und den 3 Schrauben.
Das ist das übliche Fehlerbild bei diesem Heizungstyp. Besitzer von Touran Zuheizern können ein Lied davon singen. Passat Variant BGW 2005
2024 Dacia Duster blue dci 115 |
dieter.bayern
11-11-2016, 22:34 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] Ich war inzwischen bei einem freundlichen VCDS-User, der sehr viel Geduld mitbringt, obwohl er ehrlich mitgeteilt hat, dass er sich mit Standheizungen nicht auskennt.
Vor dem Entriegeln hatten wir die folgenden Einträge:
Code: | Adresse 18: Standheizung Labeldatei: DRV\1K0-815-007.clb
Teilenummer: 1K0 815 007 BT
Bauteil: Standheizer 022 3907
Revision: 00022000 Seriennummer: 09020188000000
Codierung: 0031112
Betriebsnr.: WSC 66565 257 00032
VCID: 77FBA8A806DCDBFAF3-8022
4 Fehlercodes gefunden:
01299 - Diagnose-Interface für Datenbus (J533)
004 - kein Signal/Kommunikation
Umgebungsbedingungen:
Fehlerstatus: 01100100
Fehlerpriorität: 6
Fehlerhäufigkeit: 10
Verlernzähler: 7
Kilometerstand: 180055 km
Zeitangabe: 0
01408 - Unterspannungsabschaltung (Festwert)
000 - - - Sporadisch
Fehlerstatus: 00100000
Fehlerpriorität: 7
Fehlerhäufigkeit: 6
Verlernzähler: 114
Zeitangabe: 0
Vollast
Temperatur: 78.0°C
Temperatur: -48.0°C
01412 - Glühkerze mit Flammenüberwachung (Q
008 - unplausibles Signal - Sporadisch
Fehlerstatus: 00101000
Fehlerpriorität: 3
Fehlerhäufigkeit: 12
Verlernzähler: 117
Kilometerstand: 215311 km
Zeitangabe: 0
Start
Temperatur: 66.0°C
Temperatur: 63.0°C
02251 - Heizgerät verriegelt
000 - -
Fehlerstatus: 01100000
Fehlerpriorität: 2
Fehlerhäufigkeit: 1
Verlernzähler: 77
Zeitangabe: 0 |
Nach dem Löschen der Fehler und Entriegeln, konnte man die SH anders als bisher starten und man hörte eine Flamme in der Brennkammer. Nach ca. 2 Minuten schaltete sie sich jedoch ab und die Taste am Klimabedienteil leuchtete nicht mehr. Erneutes Auslesen ergab die beiden Fehler 01299 und 01412. Wir starteten die SH auch ein zweites und drittes Mal, allerdings schaltete sie sich jedes Mal erneut ab und das sogar schon nach ca. 1 Minute. Auffallend waren die Abgase, die selbst für Diesel zu verqualmt waren, wenngleich nicht so drastisch wie in manchen Threads schon gelesen.
Ich bat dann den VCDS-User auf meine Verantwortung hin eine Stellglieddiagnose der Glühkerze zu starten, um die Glühkerze "freizubrennen". Allerdings stand dazu nur die Umwälzpumpe zur Verfügung.  Den selektiven Stellgliedtest konnte man nicht auswählen, da dieser ausgegraut war. Der VCDS-User sieht die Ursache möglicherweise im Fehler 01299, wenngleich ihm dieser Fehler nichts sagt.
Kann sich das hier jemand erklären, warum eine Stellglieddiagnose nicht möglich ist? |
Profile PM Garage |
Joined: 04/12/2002 Posts: 18063 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
11-11-2016, 23:06 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
möglicherweise ist die Elektronik im Eimer. Kannst Du das Standheizungssteuergerät permanent ansprechen (gibt es da z.B. einen Messwertblock) und beim Laufen der Heizung schaust du, ob die Verbindung zur Heizung abbricht?
01299 ist ein Kommunikationsfehler.
PS: Die jeweils möglichen Arten vom Stellgliedtest, sequentiell oder selektiv, gibt das jeweilige Steuergerät vor.
Profile PM WWW Garage |
dieter.bayern
11-11-2016, 23:32 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] Hallo Rainer,
Quote: | | Kannst Du das Standheizungssteuergerät permanent ansprechen (gibt es da z.B. einen Messwertblock) und beim Laufen der Heizung schaust du, ob die Verbindung zur Heizung abbricht? |
das müsste ich den VCDS-User fragen, da VCDS für mich absolutes Neuland ist.
Quote: | | PS: Die jeweils möglichen Arten vom Stellgliedtest, sequentiell oder selektiv, gibt das jeweilige Steuergerät vor. |
Das macht es für mich leider umso rätselhafter: Heißt das, dass die Stellglieddiagnose der Glühkerze ausschließlich über den selektiven Stellgliedtest möglich ist?
Heißt das außerdem auch, dass manche Standheizungs-Besitzer Glück (=Steuergerät unterstützt den selektiven Stellgliedtest) und andere Pech (=Steuergerät unterstützt nur den sequentiellen Stellgliedtest) haben, obwohl die gleiche SH Webasto TT-V verbaut ist?
Wenn das tatsächlich so ist, dann ist das echt bitter... Mein Golf 5 hat EZ 10/2005, evtl. gibt es deshalb keinen selektiven Stellgliedtest?
Gruß,
Dieter |
Profile PM Garage |
12-11-2016, 12:06 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] Quote: | Das macht es für mich leider umso rätselhafter: Heißt das, dass die Stellglieddiagnose der Glühkerze ausschließlich über den selektiven Stellgliedtest möglich ist?
Heißt das außerdem auch, dass manche Standheizungs-Besitzer Glück (=Steuergerät unterstützt den selektiven Stellgliedtest) und andere Pech (=Steuergerät unterstützt nur den sequentiellen Stellgliedtest) haben, obwohl die gleiche SH Webasto TT-V verbaut ist? |
Hallo Dieter,
ich weiss es nicht, ob alle Webasto Steuergeräte diesbezüglich gleich sind. Bei Motorsteuergeräten (besser gesagt Steuergerät-Generationen) gibt es die beschriebenen Unterschiede.
Wenn die Reihenfolge halbwegs intelligent gewählt ist, spielt es keine Rolle, ob man die Glühkerze direkt ansteuern kann oder vorher noch ein paar mal "weiter" klickt.
Freibrennen wird vermutlich nicht helfen, hier im Forum sollten einige Beiträge zum Zerlegen zu finden sein.
dieter.bayern
12-11-2016, 20:03 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
im Idealfall schreibt vielleicht noch ein in Bezug auf Standheizungen kundiger User hier etwas rein. Mein nächster Schritt wäre ansonsten nochmal mit dem VCDS-User in Kontakt zu treten und zu beobachten, ob das Standheizungssteuergerät permanent angesprochen werden kann.
dieselschrauber wrote: | | Freibrennen wird vermutlich nicht helfen, hier im Forum sollten einige Beiträge zum Zerlegen zu finden sein. |
Du raubst mir fast schon meine letzte Hoffnung.
Es gibt sogar bei Youtube ein Video, in welchem die TT-V zerlegt wird: IQ-lRnmGzLg
Zwar erscheint es trivial, aber ich habe doch einigen Respekt vor dem Zerlegen, denn wenn man da als Laie etwas falsch macht, fackelt am Ende womöglich die ganze Karre ab.
Habe auch schon bei einem Online-Fachbetrieb angefragt und da würde der Austausch des Brennsatzes inkl. Prüfstandsdurchlauf 300 Euro kosten. Theoretisch könnte zusätzlich aber auch das Steuergerät eine Macke haben und da dieses bei der einfachen Einparkhilfe schon ca. 100 Euro kostet, will ich gar nicht wissen wieviel ein Neues für die Standheizung kostet...
Es gibt außerdem zwei Anbieter, die günstige Reparaturen versprechen:
-Der erste heißt Standheizungen R., der vorgibt ein Service-Center für Webasto und Eberspächer zu sein. Allerdings wird er auf der offiziellen Webasto-Seite nicht gelistet, wenn ich seine Adresse eingebe. Außerdem ist das schicke Foto vom 01.03.2016 mit dem am Auto angeschlossenen Laptop aus einem englischsprachigen Forum entnommen worden... Mein Gefühl rät mir davon ab, hier eine Reparatur in Auftrag zu geben. Wie seht ihr das?
-Der zweite heißt Standheizung-D. und macht einen seriöseren Eindruck. Auch schreibt er, dass sich viele Defekte an den Steuergeräten ohne teure Neuteile beheben lassen und womöglich hat bei mir das Steuergerät einen Schaden. Außerdem lautet das Fazit in den Internet-Foren zwar, dass sich die Glühkerze der Webasto TT-V nicht austauschen lässt und ein neuer Brenneinsatz her muss, allerdings macht es wohl Sinn, sich dennoch mal die Meinung darüber von der "Standheizung-D." einzuholen, zumal er ja auch Reparaturen zum Festpreis verspricht. Was haltet ihr davon?
Wenn der ein oder andere erfahrene User hier eine andere Vorgehensweise einschlagen würde, so lasst es mich bitte wissen.
Gruß,
Dieter |
Profile PM Garage |
13-11-2016, 15:18 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
Ich bat dann den VCDS-User auf meine Verantwortung hin eine Stellglieddiagnose der Glühkerze zu starten, um die Glühkerze "freizubrennen". |
Die Prozedur für den Zwangsstart geht bei dem Modell nicht über die Stellglieddiagnose. Probiere folgendes:
Vorraussetzung:
-Batterie geladen (vermeiden von Abschaltung durch Unterspannung)
-Motor nicht betriebswarm.
Los gehts:
-Verbinden mit Stg.18
- Standheizung Entriegeln (mit VCDS, nicht durch ziehen von Sicherungen)
-Fehler löschen
-Funktion Grundeinstellung
-Kanal 11-
-Start
Jetzt sollte sie starten.
Der Testlauf wird wieder beendet mit Grundeinstellung Kanal 33.
Vermutlich wird sie auch hier wieder nach kurzer Zeit verriegeln und ausgehen. Weil das Problem ja noch besteht.
Bei verkokten Heizgeräten kann der Zwangsstart sehr rauchig werden.
Üblicherweise ist bei dem Fehlerbild der Brenner mit Glühkerze breit. Passat Variant BGW 2005
13-11-2016, 15:30 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
Dieter |
Lass das sein. Die Ersatzteile für die OE verbauten Webasto Heizungen gibt es ohnehin exclusiv im Autohaus und nicht im Handel.
Das ist das Erste, was Du merken wirst wenn Du so eine Heizung selber überholen willst.
Wir haben solche Autos als Betriebsfahrzeuge für die Aussendienstler. Wenn die Zuheizer dann hinüber sind,bringen wir die Heizgeräte zu VW.Also Heizgerät raus, Wasserschläuche mit Verbinder (Gates 28605 zb) verbinden und bei VW abgeben. Die schicken das zum Überholen da intern ein.
Da war fast immer der Brenner mit Kerze kaputt. Und das kam auch fast immer um die 300 Euro. Die Heizungen haben alle hinterher funktioniert. Da hast Du den wenigsten Stress. Allerdings gibt es da durchaus Wartezeiten. Besonders um diese Jahreszeit. Da merken nämlich jedes Jahr auch ganz viele andere Autofahrer, dass ihre Zuheizer/Standheizungen kaputt sind. Passat Variant BGW 2005
dieter.bayern
13-11-2016, 17:25 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] Vielen Dank, Steffen, für die ausführliche Antwort.
Steffen W wrote: | Los gehts:
-Entriegeln (mit VCDS, nicht durch ziehen von Sicherungen)
-Fehler löschen
-Kanal 11-
-Start
Der Testlauf wird wieder beendet mit Grundeinstellung Kanal 33. |
Dazu zwei Fragen:
-Was ist mit Stg.18 gemeint (der VCDS-User wird das vermutlich wissen, dennoch möchte ich das vorher abklären, um evtl. keine Zeit zu verlieren)?
-Entspricht dieser Testlauf 1:1 dem was passiert, wenn man die SH mit VCDS entriegelt und über das Klimabedienteil startet?
Steffen W wrote: | Lass das sein. Die Ersatzteile für die OE verbauten Webasto Heizungen gibt es ohnehin exclusiv im Autohaus und nicht im Handel.
Das ist das Erste, was Du merken wirst wenn Du so eine Heizung selber überholen willst. |
Dass Ersatzteile für die OE verbaute Webasto nur bei VW verfügbar sind meinten auch ein paar Werkstätten, bei denen ich unverbindlich nachgefragt habe. Allerdings habe ich dann im Internet einen Anbieter in Jessen OT Kleindröben gefunden (glaube es wird im Forum nicht gerne gesehen, wenn man Links zu Angeboten einfügt, deshalb verzichte ich vorsichtshalber drauf?), der sämtliche Ersatzteile selbst für die Webasto TT-V anbietet.
Wie kann das sein?
Steffen W wrote: | | Wir haben solche Autos als Betriebsfahrzeuge für die Aussendienstler. Wenn die Zuheizer dann hinüber sind,bringen wir die Heizgeräte zu VW.Also Heizgerät raus, Wasserschläuche mit Verbinder (Gates 28605 zb) verbinden und bei VW abgeben. Die schicken das zum Überholen da intern ein. |
Da das für mich Neuland ist:
-Mit dem Verbinder schließe ich den durch die ausgebaute SH nun offenen Wasserkreislauf, oder?
-Wie schließe ich dann die Leitung für die Kraftstoffzufuhr?
-Mehr müsste dann nicht geschlossen werden, damit das Auto trotz ausgebauter SH fahrbereit ist, oder?
Steffen W wrote: | | Da war fast immer der Brenner mit Kerze kaputt. Und das kam auch fast immer um die 300 Euro. |
Der Preis wäre OK (erscheint mir für VW-Verhältnisse sogar günstig  ) und beinhaltet Material und Arbeit, oder? |
Profile PM Garage |
13-11-2016, 18:17 Subject: Button for the heater (Webasto TT-V) flashes briefly and then goes out |
Translating... |
[Translating...] Stg 18 ist das Steuergerät der werksseitig verbauten Standheizung.
Die Wasserschläuche werden verbunden, damit Du ohne Heizgerät fahren kannst bis es repariert ist. Für die Dieselleitung nimmst Du eine kleine Schraube, M4 ist da ganz gut.
Der Zwangsstart ist ein mit dem Tester aufgerufener Heizungsstart. Die Heizung macht einen Testlauf. Wenn selbiger wegen der vorhandenen Defekte nicht möglich ist, dann verriegelt sie und geht aus.
Du kannst auch jederzeit per Kanal 33 den Lauf manuell beenden.
Wenn man zuvor den Fehlerspeicher gelöscht hat, dann steht jetzt der aktuelle Fehler drin und man weiss wo man ansetzen muss. In Deinem Fall ist der Punkt schon erledigt, Deine Codes sind klar.
Ich hatte aber schon mal einen Touran dessen Zuheizer beim Zwangslauf gequalmt (und gestunken) hat wie ein alter Misthaufen den man angebrannt hat. Das Gequalme hat sich dann nach mehreren Heizungsläufen zwar gegeben, aber der Brennereinsatz war trotzdem fällig.
Wo der Typ aus dem Internet seine Teile bezieht, das weiss ich auch nicht.
Vielleicht hat er im Autohaus eine gute Kundennummer. Aber das ist rein spekulativ.
Bei Webasto machen sie jedenfalls sofort zu und wollen einen ins Autohaus schicken, sobald sie merken, dass es um eine OE VW Heizung geht. Passat Variant BGW 2005
