Auxiliary Heater Coding: 30 Byte Solution
Go to page: 1, 2  Next
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post04-09-2011, 11:05    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
Hello everyone!
"Can anyone provide me with a coding overview for my vehicle's body control module (BCM)? I want to activate the original auxiliary heater, but unfortunately, the commonly shared code in byte 4, bit 0 doesn't work. It would also be interesting to know where the activation time and delay of the SRA (likely referring to a specific system or function) are located. Again, the overview that is often found online seems incorrect."
Thank you!
Dirk.
Address 09: Body Control Module (J519)
Label file: RKS\8P0-907-063.clb
Part number SW: 8P0 907 063 G, Hardware part number: 8P0 907 063 G.
Part number: BCM PQ35 M 107 0615.
Revision: 00107 AF
Encoding: 46000A2FA0051AC0207240E02000895C421F2BAA214DD12AE4008F840041
Operating number: WSC XXXXXX
VCID: xxxxxx
Part number SW: 8P1 955 119 F HW: 8P1 955 119 F
Part: Wiper blade AU350 H10 0040.
Encoding: 00DD13
Translated on 14-08-2026, 4:28.
Post04-09-2011, 11:17    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
Hello Dirk,
Please set up the automatic scan first; I suspect it's related to an Audi A3 (model 8PA).
Translated on 14-08-2026, 4:31.
brezelmann01
Post04-09-2011, 11:34    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
I'll do that right away with such fast service!
Ist der 8PA, ja! Date: October 7th.
For my background information: What can you see now through the Autoscan?
Autoscan8PA.txt
 File name:  Autoscan8PA.txt
 File size:  9.63 KB
 Downloaded:  1649 times
Translated on 14-08-2026, 4:32.
Ross-Tech-Support
Post04-09-2011, 12:36    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
According to the documentation, an original stand heater is not installed, so it makes little sense to activate it. Since an aftermarket device has been installed, no unlocking within the vehicle's network/body control module (BCM) is necessary.
brezelmann01
Post04-09-2011, 13:07    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
However, the vehicle should be equipped with an original heating system (including all original wiring and related components).
Therefore, I would like to know beforehand whether I can unlock the FIS menu and everything else, and whether the heating system can be completely integrated.
Translated on 14-08-2026, 4:33.
brezelmann01
Post05-09-2011, 20:13    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
If anyone has a coding overview here... where can I get one? Can Audi retrieve this information with the push of a button, or do they have to access it online via a diagnostic tool connected to the vehicle?
Is there something like that available at erwin-online? Specifically, for the exact vehicle network control unit I have?
As I mentioned before... I would like to order some parts of the STH, but until I have tested the coding, the risk of failure is too high for me.
Dirk.
Translated on 14-08-2026, 4:34.
Ross-Tech-Support
Post05-09-2011, 20:17    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
brezelmann01 wrote:
As I said...I would like to order some parts of the STH, but before I have tested the coding, the risk of failure is too high for me.
For us, it looks similar; no one will randomly pick out codings without knowing what components were actually installed. In my opinion, the problem won't be with the codings themselves; so far, we have been able to get everything working. icon_wink.gif
Translated on 14-08-2026, 4:35.
brezelmann01
Post05-09-2011, 20:19    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
What information do you need? I'm willing to do anything, I just need a little nudge in the right direction.
"LG" can be translated as "Best regards" or "Sincerely". It is a common abbreviation for "Liebe Grüße", which means "Warm greetings" in English.
Translated on 14-08-2026, 4:36.
Ross-Tech-Support
Post05-09-2011, 20:27    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
It would be helpful to perform a full system scan once everything is installed. Then we can see what functions are still missing or which error codes remain, and proceed step by step.
For example, the vehicle's body control module (BCM) doesn't necessarily need to be coded. This only applied to older A3/TT models up to mid-year 2009; everything from mid-year 2010 onwards with a new BCM likely recognizes it automatically based on the parts catalog. Essentially, this will involve updating the parts catalog and making corresponding changes in the air conditioning system.
Translated on 14-08-2026, 4:37.
brezelmann01
Post05-09-2011, 20:35    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
Ah. Okay. Verstanden. Das bedeutet also, es kommt auf einen ca.1200Euro teuren Versuch an?! Oops!
Do you mean the parts list within the CAN gateway? And is it also through the parts list that the menu in the FIS (Instrument Cluster) is activated?
I already tried enabling the STH in the parts list, but the menu didn't appear.
"Could the problem be solely due to the missing CAN connection of the head unit? That would mean the menu would disappear if the CAN bus were ever interrupted. Or does the climate control panel control the menu?"
I'm sorry for the many questions, and I really appreciate your help!
Best regards.
Dirk.
Translated on 14-08-2026, 4:38.
Ross-Tech-Support
Post05-09-2011, 20:39    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
The device list is like a directory, and the gateway acts as the postman. To ensure that all participants are included, the control units are registered. This allows messages to find their correct destination. However, for the menu to appear/function correctly, the head unit (SH) must also be present because it sends the content.
I wouldn't call this an experiment. You can find the necessary parts in a catalog or purchase compatible used parts, and then you shouldn't have any problems – at least none that are unsolvable. You're not the first person to do this kind of retrofit, perhaps not specifically on this model, but ultimately it shouldn't be an extremely difficult process.
Translated on 14-08-2026, 4:40.
brezelmann01
Post05-09-2011, 20:45    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
Okay, thanks for all the information! I'll start by ordering just the heating device, connecting it, and seeing what happens. That way, the risk and costs remain manageable.
May I also bother you now with a request regarding the SRA? Then you'll have created a completely satisfied pretzel man! X
Translated on 14-08-2026, 4:41.
Ross-Tech-Support
Post05-09-2011, 20:46    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
Just start shooting; a solution will definitely be found eventually.
brezelmann01
Post05-09-2011, 20:49    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
Furthermore, it would be interesting to know where the activation time and delay of the SRA are hidden. Again, the information available online seems inaccurate.
Translated on 14-08-2026, 4:42.
Ross-Tech-Support
Post05-09-2011, 21:00    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
The overview you're referring to is generally correct, but it doesn't apply to your specific vehicle or model year. Basically, everything known about the 8P/8J models up to and including model year 2009 should be disregarded. Instead, you should refer to the data and information related to the Golf 6.
Regarding the SRA (Steering Rack Assist), the activation times and delay are no longer adjustable through coding or adaptation; they are now hard-coded based on current knowledge, meaning neither VCDS nor VAS can modify them. This is likely intentional, following instances where many users have altered settings that are either legally prohibited or at least questionable.
brezelmann01
Post05-09-2011, 21:02    Subject: Auxiliary Heater Coding: 30 Byte Solution Quote
Okay, great. Thank you for everything *happy*.
I'll let you know as soon as the STH is electrically connected.
Translated on 14-08-2026, 4:43.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts PLC Programming: Your Guide to STG Coding On-Board Diagnostics (OBD)
No new posts MSG AKN Coding: Guide & Explanation On-Board Diagnostics (OBD)
No new posts STG Coding: Explained & How-To Guide Diesel Engine Technology
