Adjust Odometer/Mileage for Car Dashboard
Mrriceguy
Karma: +0 / -1   Thank you, like it!
Post29-12-2016, 23:17    Subject: Adjust Odometer/Mileage for Car Dashboard Quote
I work in a country where driving on the left is the norm, and I was wondering if it's possible to use VCDS to adjust the tire circumference settings so that my instrument cluster would display theoretical mileage figures.
I have a Seikel suspension system, and I know that you can use different wheel sizes with it, which means you need to adjust the speedometer accordingly. The idea is to change the tires so that my speedometer displays miles instead of kilometers.
Is that possible? Or, where can I adjust the tire circumferences?
Greetings.
Translated on 20-10-2026, 19:44.
Post30-12-2016, 0:40    Subject: Adjust Odometer/Mileage for Car Dashboard Quote
What kind of vehicle are we even talking about?
For some vehicles, it is possible to adjust the display values in the instrument cluster to a few different options. It would be quite a coincidence if those options happened to match.
In many newer vehicles, the display can be switched directly between kilometers and miles in the Multifunction Display (MFA), either by changing the setting directly on the speedometer or by displaying the corresponding speed in kilometers or miles simultaneously within the MFA.
Greetings.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 20-10-2026, 19:45.
Mrriceguy
Post30-12-2016, 18:11    Subject: Adjust Odometer/Mileage for Car Dashboard Quote
Sorry, I forgot to mention that. It's a T5.2 model from 2011 with the standard speedometer (see picture).
I know that newer vehicles already have a switch in the speedometer. However, I was hoping I wouldn't also have to replace the speedometer.
If anyone has experience or contacts regarding the conversion of vehicles for left-hand traffic, we would be very happy to hear from them.
Okay, here's the translation:
Thank you.
EDIT: Image removed, please respect copyright!
T5.2 CAAC 4Motion
Translated on 20-10-2026, 19:47.
bloesch
dieselschrauber likes this.
Post31-12-2016, 9:42    Subject: Adjust Odometer/Mileage for Car Dashboard Quote
Try this:
Press the left button on the dashboard repeatedly until the mileage starts to blink, then press the right button.
"In my Polo, for example, the mileage display is activated in this way. However, you can only see it while the car is moving; when the car is stationary, the odometer reading is displayed."
Translated on 20-10-2026, 19:48.
Post31-12-2016, 10:30    Subject: Adjust Odometer/Mileage for Car Dashboard Quote
I've removed the image above; I don't think you had the rights to it. icon_wink.gif
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tire Size Adjustment for VW T4 On-Board Diagnostics (OBD)
No new posts Modify STG 46 settings On-Board Diagnostics (OBD)
No new posts MKB BKD: Engine Control Unit Tuning/Remapping On-Board Diagnostics (OBD)
No new posts AGR Adjustment Fails: What Went Wrong? On-Board Diagnostics (OBD)
