Performance loss at higher speeds under load Peugeot B
Koja79
2004 Volkswagen T5
Post14-01-2017, 17:28    Subject: Performance loss at higher speeds under load Peugeot B Quote
Hi there...
I have a problem with our Peugeot Boxer, manufactured in 2012, with engine code AQV.
The car initially runs normally, but when it gets warm under load, the power completely drops out or goes into limp mode. I turn the ignition off and on again, and it runs perfectly normally.
"The error code reads 'Foreign air in the system'." Now I had already replaced the air-to-water cooler because it had a hole, and I thought that would fix the problem. I then let the car run for about an hour while stationary, and no error occurred. Then I wanted to drive home, but it went back into limp mode. I have inspected all the hoses, and I haven't found any cracks or anything like that.
What could it be? Previously, there was also a defective LLM, which I had replaced, and since then there have been no more error entries.
Can it be that the air intake sensor now also has a way or what else could it be?
Detailed diagnostic tests on the AGR and VTG systems were successfully completed. He also builds up the loading pressure until the error.
Best regards
Post14-01-2017, 19:37    Subject: Performance loss at higher speeds under load Peugeot B Quote
Go ahead and take a look at the air intake system.
Koja79
2004 Volkswagen T5
Post15-01-2017, 9:46    Subject: Performance loss at higher speeds under load Peugeot B Quote
Unfortunately, I don't have a way to shorten the intake length. Go to the garage again tomorrow and take a picture of the error code. I forgot to write it down.
Should I perform another measurement? Why does it run normally again after the ignition is switched off?
Best regards
Post15-01-2017, 10:51    Subject: Performance loss at higher speeds under load Peugeot B Quote
The fault code will be reset when the ignition is turned off/on, as the engine control unit hopes that the car has been repaired. icon_wink.gif
Best regards, Rainer
Koja79
2004 Volkswagen T5
Post08-02-2017, 7:44    Subject: Performance loss at higher speeds under load Peugeot B Quote
Hi...
Wanted to follow up. The car seems to have a remarkable self-healing ability. I planned to go to the workshop the next day to read the error code again, but the error was gone. I have now driven the car for 4000 km and there have been no further problems. I've never experienced anything like this before.
I was able to delete the errors before, but they kept reappearing. Now, everything is quiet. I can't say what it was, but I'm happy to say so! icon_biggrin.gif
Best regards, Jan
Post08-02-2017, 7:52    Subject: Performance loss at higher speeds under load Peugeot B Quote
This is the wonderful electricity of the French. She has biological self-healing abilities... unfortunately, this also makes her just as vulnerable icon_biggrin.gif
Post08-02-2017, 8:44    Subject: Performance loss at higher speeds under load Peugeot B Quote
Thank you for the feedback!
No new posts Review and Installation: Kenwood KDC-DAB 4551U in a Peuge... Troubleshooting & Guides
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Document: Tapping Noises Below 1600 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance Issues at High Speeds Diesel Engine Technology
No new posts Sudden Loss of Power at High Speeds Diesel Engine Technology
This topic is locked, you cannot edit or reply. Reduce Smoke at High RPMs Diesel Engine Technology
No new posts Low RPM Performance Issues: Troubleshooting Guide Diesel Engine Technology
