Audi A6: Troubleshooting Error Codes (V6 3.0 TDI)
Go to page: 1, 2, 3  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
vag-driver
Post05-01-2017, 12:42    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
Hello everyone,
Wishing everyone a happy, healthy, and accident-free year.
This concerns the Audi mentioned above, with the engine code "ASB". The engine has been remapped, supposedly increasing the power from 171 kW to 210 kW.
Here is the complete car scan:
Thursday, January 5, 2017, 11:35:04:19385
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 16.8.3.4
Data as of: 20161130 DS267.0
Vehicle Identification Number: WAUZZZ4F27N161475
License plate: xyz
Mileage: 213920 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53
55 56 61 62 72 76 77
Mileage: 213,920 km
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: Error 0010.
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
05-Access/Startup Report -- Status: Error 0010.
07-Control panel/interface -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: OK.
0E-Media Player 1 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
1E-Media Player 2 -- Status: OK 0000
Immobilizer system -- Status: Error 0010.
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: Error 0010.
46-Comfort System -- Status: Error 0010.
47-Sound System -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking assist -- Status: OK 0000
77-Phone -- Status: OK 0000
Address 01: Engine Control Module
Label file: DRV\059-907-401-ASB.clb
Part number SW: 4F0 910 402 D, HW: 4F0 907 401 C.
Part: 3.0L V6 TDI, part number G000AG, serial number 0030.
Revision: --H04--- Serial Number:
Encoding: 0011372
Operating number: WSC 01286 386 08256
VCID: 1E35E87DC9FC6CB2D3-804A
3 error codes found:
005658 - Spark plug, cylinder 1 (Q10)
P161A - 001 - Interruption.
Environmental conditions:
Error status: 01110001
Error priority: 0
Error frequency: 1.
Lost Count: 255
Mileage: 184,073 km
Time: 0.
Date: 2015.01.08
Time: 07:16:05
Speed: 924 RPM
Torque: 124.8 Nm
Speed: 0.0 km/h
Key ratio: 1.0%
Voltage: 13.68 V
Key press ratio: 24.1%
Temperature: 8.1°C
005660 - Spark plug, cylinder 3 (Q12)
P161C - 001 - Interruption.
Error priority: 0
Error frequency: 1.
Lost Count: 255
Mileage: 184,073 km
Time: 0.
Date: 2015.01.08
Time: 07:16:05
Speed: 924 RPM
Torque: 124.8 Nm
Speed: 0.0 km/h
Key ratio: 1.0%
Voltage: 13.68 V
Temperature: 8.1°C
005663 - Spark plug, cylinder 6 (Q15)
P161F - 001 - Interruption.
Error priority: 0
Error frequency: 1.
Lost Count: 255
Mileage: 207,750 km
Time: 0.
Date: 2016.08.22
Time: 16:28:24
Speed: 1323 RPM
Torque: 179.4 Nm
Speed: 10.1 km/h
Key press ratio: 13.9%
Voltage: 13.53 V
Key press ratio: 24.5%
Temperature: 18.9°C
Readiness: 0 0 0 0 0
Address 02: Transmission Label file: DRV\09L-927-760.lbl
Part number SW: 4F2 910 156 F, HW: 09L 927 156 C.
Part number: AG6 09L 3.0 TDI RdW 0030
Revision: --H01--- Serial Number: 4319838
Encoding: 0000001
Operating number: WSC 02325 758 00200
VCID: 2859CEA59BB8A202A9-807C
No error codes found.
Address 03: Brake Electronics
Label file: DRV\4F0-910-517.lbl
Part number SW: 4F0 910 517 AD, HW: 4F0 614 517 AA.
Component: ESP8 quattro
Part number: H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
VCID: 66C5809D512C74725B-8032
Address 05: Access/Startup. Label file: 4F0-910-852.clb.
Part number SW: 4F0 910 852, HW: 4F0 905 852 B.
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100751424
Encoding: 0000003
Operating number: WSC 02323 758 00200
VCID: 63C39989A21E015ABC-8036
Subsystem 1 - Part number: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part number: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
"One error found:"
00956 - Key 2
002 - Lower limit exceeded - Intermittent.
Error status: 00100010
Error priority: 3
Error frequency: 1.
Lost Count: 66
Time: 0.
Address 07: Quantity/Control Unit
Label file: DRV\4F0-910-7xx-07-H.clb
Part number SW: 4F1 910 732 D, HW: 4E0 035 729.
Component: Interface box H43 5570.
Revision: 00000000 Serial number: 350DV077782349
Encoding: 0000006
Operating number: WSC 02334 758 00200
VCID: 2547C791ECAABF6A92-8070
Subsystem 1 - Part number: 4F0 910 609 E
Component: Control panel MMIC6H01 0060.
Subsystem 2 - Serial number: 00000000744022.
Subsystem 3 - Serial Number: 0125.04.070000000100011516.
Subsystem 4 - Serial number: 011516Ăż
Address 08: Climate Control/Heating. Label file: 4F0-910-043.clb.
Part number SW: 4F0 910 043 A, HW: 4F1 820 043 AF.
Component: CLIMATE CONTROL H30 0020
Revision: 00000052 Serial number: 00000000388311
Encoding: 0000022
VCID: 1C31E275DFE07EA23D-8048
"One error found:"
00797 - Photosensor for sunlight detection (G107)
009 - Intermittent short circuit to ground.
Error status: 00101001
Error priority: 3
Error frequency: 47
Lost Count: 71
Mileage: 212,748 km
Time: 0.
Date: 2016.12.24
Time: 11:37:26
Address 09: Central Electronics
Label file: DRV\4F0-910-279.lbl
Part number SW: 4F0 910 279 K, HW: 4F0 907 279.
Component: ILM Driver H17 0240
Revision: 00000000 Serial Number: 4F0907279
Encoding: 0002122
Operating number: WSC 02335 758 00200
VCID: 316F23C1A862E3CA7E-8064
Subsystem 1 - Part number: 4F1 910 113 C. Label file: DRV\1KX-955-119.CLB.
Part: Wiper blade, Audi C6, part number H05 0210.
Encoding: 00064784
Subsystem 2 - Part number: 4E0 910 557 A
Label file: DRV\8K0-955-559.CLB
Component: RAIN SENSOR H13 0090
Encoding: 00146221
Address 0E: Media Player 1 (R199)
Label file: DRV\4E0-035-785.lbl
Part number SW: 4E0 035 785 F, HW: 4E0 035 785 F.
Component: SG ext.Player H09 0850
Revision: 00000000
Encoding: 010000
Operating Number: WSC 00000 000 00000
VCID: 2B5331A94A4E891A44-807E
Address 15: Airbag
Label file: DRV\4F0-910-655-8R.clb
Part number SW: 4F0 910 655 E, HW: 4F0 959 655 B.
Part number: 42 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial Number: 0037LD0RF5AF
Encoding: 0013362
VCID: 295FCBA180B29B0AB6-807C
Subsystem 1 - Serial number: 6332CSME127D33381.
Subsystem 2 - Serial number: 6342CSME13173E0C3.
Subsystem 3 - Serial number: 6352QSME29661B27L
Subsystem 4 - Serial number: 6362QSME293C337BS.
Subsystem 5 - Serial number: 63734SME21732503O
Subsystem 6 - Serial number: 63834SME216B1C675.
Address 16: Steering Wheel Electronics
Label file: DRV\4F0-910-549.lbl
Part number SW: 4F0 910 549, HW: 4F0 953 549 A.
Component: Steering column module H08 0230.
Revision: 00H08000 Serial Number: 90025071080571
Encoding: 0002041
Subsystem 1 - Part number: XXXXXXXXXXX
Component: Steering wheel module H07 0090.
Address 17: Control panel module
Label file: DRV\4F0-910-xxx-17.lbl
Part number SW: 4F0 910 930 C, HW: 4F0 920 932.
Bauteil: KOMBIINSTR. M73 H20 0170
Revision: 00400000 Serial Number: 5HP530H47
Encoding: 2049148
Operating number: WSC 12345 001 136936.
VCID: 2343D989E29E415AFC-8076
Address 19: Diagnostic interface
Label file: DRV\4F0-910-468.clb
Part number SW: 4F0 910 468 A, HW: 4F0 907 468 D.
Component: Gateway H11 0070
Revision: 11 Serial number: 130080742083A3
Encoding: ECFE73C43B3104
VCID: 275BCD9996A6AD7AA0-8072
Address 1E: Media Player 2
Label file: DRV\4E0-910-111.lbl
Part number SW: 4E0 910 110 E, HW: 4E0 035 110 A.
Component: MP3 Changer H44 0390
Revision: 00044000 Serial Number: AUZ5ZBG3221022
VCID: 1A3DE46DD5D400922F-804E
Address 37: Navigation
Label file: DRV\4E0-910-88x-37.lbl
Part number SW: 4E0 910 887 T, HW: 4E0 919 887 M.
Component: MNS ECE H49 1030
Revision: 00000000 Serial Number: 364DU077674181
Operating number: WSC 06820 995 02093
VCID: 3E7508FD693C0CB2F3-806A
Address 42: Door electrical driver
Label file: DRV\4F0-910-793-42.lbl
Part number SW: 4F0 910 793 E, HW: 4F0 959 793 E.
Component: TSG FA H12 0210
Revision: 00000000 Serial number: Iˆi
Encoding: 0000522
Operating number: WSC 02327 758 00200
VCID: 2C5132B58F408E224D-8078
"One error found:"
02115 - Central locking unit.
008 - implausible signal - sporadic.
Error status: 00101000
Error priority: 3
Error frequency: 81
Lost Count: 71
Mileage: 212,748 km
Time: 0.
Date: 2016.12.23
Time: 19:28:04
Address 46: Comfort System
Label file: 4F0-910-289.lbl
Part number SW: 4F0 910 289 F HW: 4F0 907 289 F
Component: Comfort Device H22 0170.
Revision: 01700022 Serial number: 01041644010000
Encoding: 0131205
VCID: 2D573FB1B45A872A5A-8078
"One error found:"
00988 - Lamp for right brake light (M10).
Error priority: 3
Error frequency: 2.
Lost Count: 59
Mileage: 212,748 km
Time: 0.
Date: 2016.12.23
Time: 19:27:40
Address 47: Soundsystem (J525)
Label file: DRV\4F0-910-223-AS2.lbl
Part number SW: 4F0 910 223 M, HW: 4F0 035 223 N.
Component: Amp.-ASK-RD H07 0270
Revision: 08S00000
Encoding: 020000
Operating number: WSC 02399 823 56573
VCID: 2859CEA55BB8A202A9-807C
Address 4F: Central Electricity II
Label file: DRV\4F0-910-280.lbl
Part number SW: 4F0 910 280, HW: 4F0 907 280.
Component: ILM passenger side, H10 0080.
Revision: Serial number: 00000000251489
Encoding: 0001003
VCID: 5EB5A87D897C2CB293-800A
Address 52: Power door lock, front passenger side.
Label file: DRV\4F0-910-793-52.lbl
Part number SW: 4F0 910 793 E, HW: 4F0 959 792 E.
Component: TSG BF H12 0210
Revision: 00000000 Serial number: txg-
Encoding: 0000522
Address 53: Parking brake
Label file: DRV\4F0-910-801.clb
Part number SW: 4F0 910 801 C, HW: 4F0 907 801 A.
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000321
Operating number: WSC 02324 758 00200
VCID: 2049D685F3885A42E1-8074
Address 55: Headlight range control. Label file: DRV\8P0-907-357.lbl
Part number: 8P0 907 357 F
Component: Dynamic LWR, H02 0010.
Revision: 00000001 Serial number:
Encoding: 0000003
VCID: 3D770FF1643A17AAEA-8068
Address 56: Radio
Label file: DRV\4E0-910-541.lbl
Part number SW: 4E0 910 541 T, HW: 4F0 035 541 L.
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial Number: 394DZ077761825
Encoding: 0000001
Address 61: Battery Management
Label file: DRV\4F0-910-181.lbl
Part number SW: 4F0 910 181 E, HW: 4F0 915 181 A.
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000066249
Subsystem 1 - Part number: 4F0 915 105 D
Component: from VA0, part number 2704233432.
Encoding: 344630393135313035442056413032373034323333343332
Operating number: WSC 00000 384 00290
Address 62: Door electric, left/right.
Label file: DRV\4F0-910-795.lbl
Part number SW: 4F0 910 795 F, HW: 4F0 959 795 F.
Component: TSG HL H21 0050
Encoding: 0000002
VCID: 2F6B25B9BE56F53A68-807A
Address 72: Door electric, upper right.
Part number SW: 4F0 910 795 F, HW: 4F0 959 794 F.
Component: TSG HR H21 0050
Encoding: 0000002
Address 76: Parking Assist
Label file: DRV\4Fx-910-283.lbl
Part number SW: 4F0 910 283 F, HW: 4F0 919 283 F.
Component: Parking assist system, 4-channel, part number H09 0060.
Revision: 00H09000 Serial Number: 06230711305755
Encoding: 0001006
Address 77: Telephone Label file: DRV\4E0-910-336.lbl
Part number SW: 4E0 910 336 M, HW: 4E0 862 335.
Component: Mobile phone part 2, H16 1130.
Revision: 00000000 Serial number: 00000007656368
Encoding: 0010930
End----------------------------(Duration: 03:07)-----------------------------
After that, I wanted to read the DPF fill level.
License plate: xyz
Address 01: Engine Control Module (4F0 910 402 D)
11:40:27
-53.1°C Exhaust gas temperature before the particulate filter.
0 mbar differential pressure, particulate filter.
0.00 Oil ash volume.
0.0 Loading Russian - mass value.
Okay, here are my main points:
Are the glow plugs actually defective, or could it be the wiring?
2. Why is the engine control unit (ECU) not aware of the DPF's loading status? Was the DPF possibly deactivated?
Viele GrĂŒĂŸe
Andreas
*** Ein Ingenieur muss vordenken. Wenn er anfÀngt nachzudenken ist es schon zu spÀt. ***
Translated on 13-09-2026, 0:30.
chli1976
Post05-01-2017, 17:12    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
When the DPF is deactivated, the exhaust turbocharger temperature sensor should normally read -293°C; however, this may be different with this specific control unit.
VCDS
vag-driver
Post05-01-2017, 17:18    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
Interestingly, the car runs normally and starts well even in temperatures as low as -10°C.
Viele GrĂŒĂŸe
Andreas
chli1976
Post05-01-2017, 17:24    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
The glow plugs probably aren't completely defective yet.
The control unit detects when components are no longer functioning at 100%, consider the power consumption.
I'm not sure whether the 2.7 or the 3.0 model has the ceramic spark plugs.
As long as they are still working, you can try to burn off any excess fuel before replacing them. Whether that will actually help is another matter. Otherwise, use the thinnest synthetic oil you have, fill the holes where the glow plugs are located, get the engine really hot, and then try to see if they come out.
These are ceramic glow plugs, and when opening them, no more than 15 Nm of torque should be applied, otherwise the manufacturer warns of damage.
If ceramic spark plugs are installed, they should be replaced with steel ones. Do not attempt to start the engine without having the engine control unit reprogrammed beforehand.
Whether you have ceramic or steel candles inside, you need to do some research. There's a red and a white ring on the candles that distinguishes them.
VCDS
Translated on 13-09-2026, 0:32.
vag-driver
Post07-01-2017, 9:12    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
What about the DPF? Why are the readings showing as 0?
Vehicle Identification Number: License Plate: xyz
Mileage: 213,920 km
Repair order:
11:40:27
-53.1°C exhaust gas temperature upstream of the particulate filter.
Viele GrĂŒĂŸe
Andreas
Translated on 13-09-2026, 0:34.
chli1976
Post07-01-2017, 9:38    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
Please post the extended ID.
VCDS
Translated on 13-09-2026, 0:35.
vag-driver
Post07-01-2017, 9:54    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
The car belongs to my brother-in-law, whom I only see occasionally. Therefore, it would be helpful for me to know what data I should read out next time so that I can provide these values.
Viele GrĂŒĂŸe
Andreas
vag-driver
Post11-01-2017, 12:32    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
chli1976 wrote:
If ceramic spark plugs are installed, they should be replaced with steel ones, and the engine control unit should be reprogrammed before starting the engine.
Why do they need to be exchanged? Couldn't they just be replaced?
Viele GrĂŒĂŸe
Andreas
Translated on 13-09-2026, 0:36.
MichaelJ
dieselschrauber likes this.
Post12-01-2017, 10:46    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
The ceramic glow plugs were prone to failure, which could then lead to engine damage, and were therefore replaced with steel glow plugs. Because the control system for the steel glow plugs is different from that of the ceramic glow plugs, the engine control unit (!) must be adjusted.
Audi 80 TDI , MKB: 1Z, KM >455.000 r.i.p.
Passat 3B TDI, MKB: AJM, KM >331.000 r.i.p.
Audi A4 Cabrio Quadro, MKB: ASB KM> 119.000 -ZKD defekt, 6 Zylinder voller Riefen ATM 16tsd €! ATM 2 Tage vor Garantieende getauscht, da drei defekte Injektoren zwei Jahre lang nicht getauscht wurden.
vag-driver
Post12-01-2017, 11:03    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
I was therefore surprised because, in our technical article "Information about glow plug electrodes (spark plugs)," the ceramic variant was supposed to, at least in theory, last longer than the operating life of the engine. Apparently, this has not been confirmed in practice.
Is it correct that glow plugs with a red ring are made of steel, and those with a white ring are made of ceramic?
Viele GrĂŒĂŸe
Andreas
Translated on 13-09-2026, 0:37.
Post12-01-2017, 11:17    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
vag-driver wrote:
That's why I was surprised, because in our technical article "Information about glow plug electrodes (spark plugs)," the ceramic variant was supposed to, at least in theory, outlast the engine's operating life. Apparently, that hasn't been the case in reality.
"In my BRE system with ceramic glow plugs, one at the top was damaged and subsequently fell out. The remaining glow plugs showed 'erosion' and a 'corroded surface' in the same area. The mileage was approximately 265,000 km."
 KeramikglĂŒhkerzen
 File size:  734.34 KB
 Viewed:  2759 times
Translated on 13-09-2026, 0:38.
vag-driver
Post12-01-2017, 13:59    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
I'm surprised that yours doesn't have a color marking on it. That means the safest method is to remove one and check which version is installed to avoid any surprises.
Viele GrĂŒĂŸe
Andreas
Translated on 13-09-2026, 0:39.
vag-driver
Post23-01-2017, 15:51    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
Sure, go ahead...
Monday, January 23, 2017, 2:14:14:19385
License plate: xyz
Address 01: Engine Control Module.
Control unit part number: 4F0 910 402 D.
Component and/or version: 3.0L V6 TDI, G000AG, 0030.
Encoding: 0011372
Company number: WSC 01286
Enhanced identification.
Serial number:
Identification: BPG-810.
Revision: --H04---
Date: 2007-03-19
Test item number: 1316.
Manufacturer part number: 0340.
Flash Status
Programming attempts: 2.
Successful attempts: 2.
Programming status: 00000000
Requirements: 00000000
Flash Tool Number: 08256 386 01286
Flash Date: 25.07.11
Software.
A 4.7.7
Miscellaneous.
Hardware number: 4F0 907 401 C
WFS Challenge: 8C 8F 7E 89
Vehicle Information.
VCDS Info:
Readiness: Script not available.
As you can see, the engine has been tuned using a software map.
Viele GrĂŒĂŸe
Andreas
Translated on 13-09-2026, 0:42.
Wiesel
Post23-01-2017, 21:52    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
vag-driver wrote:
... As you can see, the engine has been tuned using a software map.
What conclusions do you draw from 'Flashcounter = 2'?
He might have received an update from a friendly source.
Translated on 13-09-2026, 0:46.
Blackfrosch
Post23-01-2017, 22:29    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
Yes, but the fact that the DPF is off and showing dead AGT/DPF values cannot be explained by that alone. Since the DPF is essentially acting as a "muffler" in this case, the car is almost designed for it...
Therefore, I'm sure that this doesn't have genuine software installed, but that doesn't change anything about your glow plug problem.
Translated on 13-09-2026, 0:47.
vag-driver
Post23-01-2017, 23:30    Subject: Audi A6: Troubleshooting Error Codes (V6 3.0 TDI) Quote
The spark plugs will be replaced soon.
"Still, I wonder what has changed that the engine control unit (ECU) doesn't know the DPF fill level. And it's cleverly designed so that the vehicle inspection (HU) doesn't present any problems."
As mentioned before, the engine has been chipped.
Viele GrĂŒĂŸe
Andreas
Translated on 13-09-2026, 0:48.
No new posts Touran 1T Workshop: Service & Repairs Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB & MSG Error Codes: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Various Driving Behavior Defects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Replacement: Strange Error Codes Explained Diesel Engine Technology
No new posts Galaxy in Emergency Mode: Error Codes & Fixes On-Board Diagnostics (OBD)
No new posts Various error codes Gasoline Engine Technology
No new posts 32B-JX: Questions and Answers Diesel Engine Technology
