alexander_924
Joined: 01/26/2017 Posts: 4 Karma: +0 / -0 Location: Einbeck
27-01-2017, 9:07 Subject: Passat 1.9 TDI Battery Replacement (BLS) |
Hello, hello!
Mein Name ist Alexander, ich bin 35 Jahre alt und fahren den o.g. Car.
After nine years, it seems like it's time to replace the battery.
My question is, since I don't own a diagnostic tool (am I still eligible?), whether the battery in this model can simply be replaced, or if it needs to be registered.
It's the standard Bluemotion model, not the Bluemotion Technology version, so it doesn't have features like start/stop functionality, regenerative braking, or a special battery.
Thank you in advance!
Alexander.
Translated on 08-10-2026, 9:12.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
27-01-2017, 11:01 Subject: Passat 1.9 TDI Battery Replacement (BLS) |
Hello Alexander,
It is sufficient to install a battery with the same technology, capacity, and starting current as the one that was previously installed.
See also:
The vehicle's body control module (BCM) only needs to be reprogrammed when switching to a different battery technology or capacity, see:
Translated on 08-10-2026, 9:14.
Profile PM WWW Garage |
alexander_924
28-01-2017, 8:43 Subject: Passat 1.9 TDI Battery Replacement (BLS) |
Hello Rainer,
Thank you very much!
But that would mean that if I don't want to program anything, I have to remove a battery from a VW somewhere to get an exact replacement, right?
What would happen if I installed a different one, but the replacement part wouldn't arrive for a few days?
Alexander.
Translated on 08-10-2026, 9:15.
matthiasTDI96 Profi-Schrauber
28-01-2017, 9:03 Subject: Passat 1.9 TDI Battery Replacement (BLS) |
You can install any battery with more or less the same capacity. This is not a problem.
alexander_924
10-02-2017, 10:09 Subject: Passat 1.9 TDI Battery Replacement (BLS) |
Hi!
Okay, I'll try that.
Alexander.
alexander_924
12-02-2017, 10:46 Subject: Passat 1.9 TDI Battery Replacement (BLS) |
Hi!
Now, I need to ask again:
Can I install a battery with 77Ah and 770A cold cranking current without needing to reprogram anything, considering the original battery has 72Ah and 680A cold cranking current?
Alexander.
Translated on 08-10-2026, 9:16.
12-02-2017, 10:51 Subject: Passat 1.9 TDI Battery Replacement (BLS) |
There is nothing that needs or can be coded, your vehicle does not have a battery management control unit (STG) or anything similar.  MfG. Michael
Translated on 08-10-2026, 9:17.
Profile PM Garage |
