Change Tax ID: How to Do It Easily.
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
michael_golf
Post05-03-2017, 17:19    Subject: Change Tax ID: How to Do It Easily. Quote
Hello everyone,
I'm having a problem where the control unit for the instrument panel insert in my VW Up! (year 2012) has a value of 999999 entered under the device number.
Without changing this value, it is not possible to make any changes to the control unit.
Can I change the device number of the control unit using VCDS, and if so, how?
Thank you.
 File size:  139.51 KB
 Viewed:  5111 times
 File size:  132 KB
 Viewed:  2745 times
Translated on 18-08-2026, 18:20.
Post05-03-2017, 20:53    Subject: Change Tax ID: How to Do It Easily. Quote
As is often the case in these situations, an automatic scan would be helpful so that a proper answer can be provided to your question. Please perform this scan and post the results before taking any further action.
Within the VCDS program settings, on the "Interface and Identification" tab, you can enter the operating number, dealer/importer number, and device number. This data will then be used when making changes.
If it were my car, I would personally select the values from the car scan that are relevant to me and enter them there. Of course, the actual values from the respective system or tool should be included.
Translated on 18-08-2026, 18:21.
michael_golf
Post06-03-2017, 9:52    Subject: Change Tax ID: How to Do It Easily. Quote
Thursday, March 2, 2017, 7:49:05 PM.
VCDS - A VAG/VAS emulator based on Windows - runs on Windows 7 x86.
VCDS version: RKS 17.1.3.0
Data as of: 20170220 DS267.3
Vehicle Identification Number (VIN): WVWZZZAAZCD03xxxx License plate:
Mileage: 92,000 km. Repair order:
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: AA (6N0)
Scan: 01 03 09 10 13 15 17 19 25 44 56 AD
Vehicle Identification Number (VIN): WVWZZZAAZCD03xxxx Mileage: 92,000 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist System 2 -- Status: OK 0000
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
Steering assist - Status: OK 0000.
56-Radio -- Status: Error 0010.
Brake system AD sensors -- Status: OK 0000.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module (J623-CHYB)
Label file: 04C-906-020-CHY.clb
Part number SW: 04C 906 020 A, HW: 04C 907 309.
Component: 1.0L R3 MPI, Part Number H01 6463.
Revision: U7H01--- Serial number:
Encoding: 00110012022400000000
Operating number: WSC 16347 002 1048576
ASAM Dataset: EV_ECM10MPI01104C906020A 001014
ROD: EV_ECM10MPI01104C906020.rod
VCID: 193E0077184152890E-804C
No error codes found.
Readiness: 0000 0000
Address 03: Brake Electronics (J104)
Label file: 1S0-614-517.clb
Part number SW: 1S0 614 517 C. Hardware: 1S0 614 517 C.
Component: EBC 460 ESP H08 0004
Serial number: 0070170.
Encoding: 12BF247189B002F9480224F891AB404058B000
Operating number: WSC 31414 790 00001
ASAM Dataset: EV_Brake1UDSESP 015024
FILE: EV_Brake1UDSESP.rod
VCID: 2F6ADEAF76C5AC3940-807A
Address 09: Central Electronics (J519)
Label file: 1S0-937-08x-09.clb
Part number SW: 1S0 937 087, Hardware: 1S0 937 087.
Component: PQ25 BCM H57 0512
Revision: -9------ Serial Number: 1009069000
Encoding: 24B8290000010000000000042C28ACD000C0400C60020000200000420100
VCID: 76E42BCBC11FDDF1C3-8022
Address 10: Parking Assist System 2 (J446) Label file: 1Sx-919-475.clb
Part number SW: 1S0 919 475, HW: 1Q0 919 475.
Part: PARKING ASSIST 3K H03 0006
Revision: -------- Serial Number: 32961206200274
Encoding: 100001
ASAM Dataset: EV_EPHVA14VW1200000 001004
FILE: EV_EPHVA14VW1200000.rod
VCID: 77FA26CFCE15A4F9D8-8022
Address 15: Airbag (J234)
Label file: DRV\5K0-959-655.clb
Part number SW: 1S0 959 655, Hardware: 1S0 959 655.
Part number: VW10Airbag009 H02 0005
Revision: -------- Serial Number: 003G3001BK6H
Encoding: 0000000000000000000000000000000
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 7BF23AFFF23D8099BC-802E
Crash sensor for driver-side side airbag:
Serial number: 3575HRB405N173JOA9NV
Crash sensor for side airbag, passenger side.
Serial number: 3585HRB405F17754789J.
Front airbag crash sensor (driver side):
Serial number: 3555NRB404V0OOR8DGCR
Address 17: Terminal block module (J285)
Label file: DRV\1Sx-920-xxx-17.clb
Part number SW: 1S0 920 860 B, Hardware: 1S0 920 860 B.
Component: COMBINATION H08 0021
Revision: X0008006 Serial Number: 00000000000000
Encoding: 114800
Operating number: WSC 79791 146 999999.
ASAM Dataset: EV_KombiUDSMM9RM10 A04708
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
Address 19: Diagnostic interface (J533)
Label file: DRV\6N0-909-901-6R.clb
Part number SW: 6N0 909 901, HW: 1S0 937 087.
Component: GW-K-CAN TP20 H57 0512
Revision: -9------
Encoding: 001000
Operating number: WSC 78130 025 411142
VCID: 70E81DD3A37BF3C119-8024
Address 25: Immobilizer (J334)
Label file: DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234, HW: 1S0 920 860 B.
Component: IMMO H08 0021
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW01.rod
VCID: 6ADC0FBB8DA7091157-803E
Address 44: Steering Assist (J792)
Label file: DRV\1Sx-909-144-44.clb
Part number SW: 1S1 909 144 G. Hardware: 1S1 909 144 G.
Component: EPS_ECU H30 1503
Encoding: 0001000101000000
ASAM Dataset: EV_SteerAssisNSK 009004
ROD: EV_SteerAssistNSK_009.rod
VCID: 377AE6CF8E9564F918-8062
Address 56: Radio (J503) Label file: DRV\5M0-035-1xx-56.clb
Part number SW: 1S0 035 156 A, Hardware: 1S0 035 156 A.
Component: Radio H35 0045
Revision: R0000000 Serial Number: VWZAZ1M2715247
Encoding: 0000040802
VCID: 295E30B74021C2099E-807C
Address AD: Sensors for braking systems (J939)
Label file: 1S0-907-201.clb
Part number SW: 1S0 907 201, HW: 1S0 907 201.
Component: CV-SENSOR H06 0450
ASAM Dataset: EV_CVSen 001001
FILE: EV_CVSen.rod
VCID: 67DA768F9EB5347948-8032
End----------------------------(Duration: 02:06)-----------------------------
Translated on 18-08-2026, 18:43.
michael_golf
Post06-03-2017, 18:30    Subject: Change Tax ID: How to Do It Easily. Quote
Hello Rainer,
I just tried it, but it didn't work. You can't code or customize anything because of that "999999" number.
Ich habe noch herausgefunden, dass dieser Zustand, d.h. weil das MotorsteuergerÀt auch einen anderen Werkstattcode besitzt als die anderen SteuergerÀte, auf eine mögliche Tachomanipulation hindeuten kann. Na super! icon_eek.gif
There has to be a way to change this number, somehow.
Translated on 18-08-2026, 19:08.
Post06-03-2017, 19:05    Subject: Change Tax ID: How to Do It Easily. Quote
I also found out that this condition, i.e., because the engine control unit also has a different workshop code than the other control units, could indicate a possible speedometer manipulation. Great! icon_eek.gif
It's possible that 999999 is unusual, but I don't want to rule out the possibility that it's normal, since the numbers on my vehicles are completely random.
For example, my wife's A3 was brand new and I picked it up myself, and it also has different identifiers. Similarly, my A6 was picked up with 0 km from Audi in Ingolstadt.
It would have been more interesting to know which values you have now configured in the VCDS program settings.
Translated on 18-08-2026, 19:09.
michael_golf
Post06-03-2017, 22:14    Subject: Change Tax ID: How to Do It Easily. Quote
Well...
"In any case, this is what I found in an engine scan from another VW up that I found online. It also shows 'WSC 31414 790 00001' in the engine control unit, as well as in the dashboard module. (And like me, it appears in almost all other control units)."
I also had this code configured in VCDS, but as I said, it seems like nothing can be done with that "999999" value.
And I can't imagine that this value of 999999 could be considered normal; otherwise, VCDS would certainly be able to handle it, see...
Error message in the image at the very beginning.
Translated on 18-08-2026, 19:11.
Post07-03-2017, 10:57    Subject: Change Tax ID: How to Do It Easily. Quote
It would have been more interesting to know which values you have now entered in the VCDS program settings.
And once again...
Translated on 18-08-2026, 19:12.
michael_golf
Post07-03-2017, 11:22    Subject: Change Tax ID: How to Do It Easily. Quote
31414 790 00001
Company registration number 31414.
VZ 790
Device number: 00001.
Translated on 18-08-2026, 19:13.
Post07-03-2017, 13:59    Subject: Change Tax ID: How to Do It Easily. Quote
Perhaps the speedometer was indeed tampered with and this is a result of that botched repair.
Could you please share what information is displayed when you access the "Extended ID" section?
Translated on 18-08-2026, 19:14.
michael_golf
Post07-03-2017, 16:29    Subject: Change Tax ID: How to Do It Easily. Quote
Tuesday, March 7, 2017, 3:18:41 PM.
Address 17: Control panel module.
Control unit part number: 1S0 920 860 B.
Component and/or version: KOMBI H08 0021.
Encoding: 114800
Company number: WSC 79791
Enhanced Identification / CONCLUSION
Serial number: 00000000000000
Identification: MM7-KEC
Revision: X0008006
Date: March 14, 2012.
Manufacturer part number: 0705.
Test item number: 3955.
Flash status.
Programming attempts (application): 0/0/0
Successful attempts (applications): 0/0/0
Programming status: 00000000
Flash Date: 00.00.00
Software.
CAN: 02.04.06
ISO15765: 02/01/12
HiSpd Net: 01.12.01
Miscellaneous.
Hardware number: 1S0 920 860 B
System abbreviation: J285
Equipment level for band ends: ------------------
ASAM Dataset Revision: A04708
Vehicle Information.
Vehicle Identification Number: WVWZZZAAZCD03xxxx
VCDS Info:
Translated on 18-08-2026, 19:17.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Tax Device Number: What it is & How to Find Diesel Engine Technology
No new posts Modify STG 46 settings On-Board Diagnostics (OBD)
No new posts VAG-COM: Adjust Fuel Injection Amount Diesel Engine Technology
No new posts Adjust idle speed On-Board Diagnostics (OBD)
