ESP Warning Light: Car Brakes in Turns?
bruckgraber
Post11-04-2017, 22:06    Subject: ESP Warning Light: Car Brakes in Turns? Quote
Hello.
I'm new here and I have a big problem.
I have a Ford Galaxy WA6, model year 2008, with a 2.0-liter engine and 140 horsepower.
"Recently, the ESP (Electronic Stability Program) light has been illuminating in certain left-hand curves, and it's cutting off the throttle (acceleration). I can also hear a grinding noise, but I've checked everything and there's nothing visibly grinding."
What could be the reason for that?
Could it be because I have summer tires installed now?
Thank you in advance for your help.
Translated on 30-09-2026, 13:12.
Turbinchen
Karma: +74 / -0   Thank you, like it!
2014 Audi A4 Avant
Post14-04-2017, 9:43    Subject: ESP Warning Light: Car Brakes in Turns? Quote
The grinding noise will be caused by the brakes engaging when the light comes on.
The fact that it happened with the summer tires is quite suspicious. Please check the tires, as well as the rims, especially the front right one. I once had a deformed inner rim flange after a foreign object hit it on the highway. There was no noticeable imbalance while driving, but the ESP (Electronic Stability Program) still intervened during fast left turns.
Translated on 30-09-2026, 13:13.
No new posts Document Transporter 7D, vehicle braking unevenly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP - active in left turns after wheel bearing replacement Diesel Engine Technology
No new posts Motor loses power at a certain RPM Diesel Engine Technology
No new posts ESP is activating on its own. Help! On-Board Diagnostics (OBD)
No new posts Does the Sharan brake automatically? Is the ESP system re... On-Board Diagnostics (OBD)
