Oil Pressure Sensor 1.6L CAYC
bordones
Post19-03-2017, 22:08    Subject: Oil Pressure Sensor 1.6L CAYC Quote
I measured an oil pressure of 1.7 bar in the aforementioned engine at 2000 RPM. According to the manufacturer's specifications, this is too low. Even when increasing the engine speed, the pressure does not change significantly. The measurement was also taken while driving.
I assume that even a cheap pressure gauge will display the correct value. At the beginning of the problem, there was a significant oil leak at the oil filter housing. This was initially replaced. Subsequently, the oil pump, including the suction strainer, was renewed (all original equipment parts).
Unfortunately, there's been no improvement. The timing belt for the oil pump drive was also okay. Bearing noises are not currently present.
Does anyone have any other ideas?
Translated on 04-08-2026, 18:37.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil pressure on 1.6 TDI Golf6 CAYC 105 hp Diesel Engine Technology
No new posts Oil pressure dropping to 1 bar at 2500 RPM on a 1.6L TDI ... Diesel Engine Technology
No new posts DPF for Audi A3 CAYC - Diesel Particulate Filter Diesel Engine Technology
No new posts Retrofitting a auxiliary heater to a B7 1.6 TDI CAYC Electrical Systems, Vehicle Electronics, Multimedia
