Passat 3BG MFL: Parts & Accessories
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Coldrule
2001 Volkswagen Golf Consumption
Post19-12-2016, 13:48    Subject: Passat 3BG MFL: Parts & Accessories Quote
I installed an aftermarket 2-DIN radio in my 2003 Passat (model 3BG).
But I also need an adapter for the original multifunction steering wheel.
It has a Quad-Lock output; it previously had a Delta unit installed.
Used the search function already, but unfortunately, I haven't found anything icon_sad.gif.
Sure, I'll translate the text from German to English while preserving all the icon_mrgreen.gif exactly. Just provide the text and I will give you only the translation, without any explanations.
Thank you in advance }.
Translated on 23-08-2026, 10:01.
haithamina
Post19-12-2016, 15:37    Subject: Passat 3BG MFL: Parts & Accessories Quote
Hi there,
When installing a (compatible) Blaupunkt radio, this adapter was often available as an accessory. Based on my experience, I would say that the steering wheel control functionality doesn't necessarily work with every radio. Did you check that beforehand?
haithamina
Translated on 23-08-2026, 10:02.
Turbinchen
Karma: +74 / -0   Thank you, like it!
2014 Audi A4 Avant
Post21-12-2016, 18:52    Subject: Passat 3BG MFL: Parts & Accessories Quote
There are compatible adapters available from AIV and ACV, but it depends on the manufacturer of your radio; they are not universal. Some manufacturers, such as Kenwood or Alpine, also offer these adapters directly.
Occupancy: http://www.passatplus.de/umbauteile/stecker/stecker4.htm
Translated on 23-08-2026, 10:03.
Coldrule
Post26-12-2016, 21:17    Subject: Passat 3BG MFL: Parts & Accessories Quote
haithamina wrote:
When installing a (compatible) Blaupunkt radio, this adapter was often available as an accessory. Based on my experience, I would say that the ability to control the radio via the multifunction steering wheel isn't necessarily supported by every radio. Did you check that beforehand?
haithamina
I checked today, and the JVC radio has a cable for steering wheel control.
But I can't find the pins for the MFL on the Quadlock connector. (not even the website turns up anything icon_sad.gif).
Does the Quadlock connector have multiple pins for the MFL, or just one?
If so, I guess I'll need an adapter, right?
Thank you in advance icon_smile.gif.
Golf IV Variant 1.9 TDI
MKB:ALH
GKB:EGR
Translated on 23-08-2026, 10:04.
Turbinchen
2014 Audi A4 Avant
Post27-12-2016, 19:18    Subject: Passat 3BG MFL: Parts & Accessories Quote
Given the year your Passat was manufactured, it will use the CAN bus system. Without an adapter, nothing will work.
Translated on 23-08-2026, 10:05.
Coldrule
Post05-04-2017, 20:48    Subject: Passat 3BG MFL: Parts & Accessories Quote
Okay, I've finally found the solution! icon_smile_thumb_up.gif (thanks to you and vocational school).
A CAN adapter is needed to filter and convert the CAN signals so that the car radio can communicate with the multifunction steering wheel (MFL).
And I found the matching part at ARS24 icon_biggrin.gif.
Works perfectly!
Thank you for the help icon_smile_thumb_up.gif.
MKB:ALH
GKB:EGR
Translated on 23-08-2026, 10:06.
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
No new posts Fuel Pump for VW Passat AFN Engine Diesel Engine Technology
No new posts Passat 3C TDI Motoren Diesel Engine Technology
