07-05-2009, 22:43 Subject: Audi A5 Headlight Wiring Diagram |
Hello.
Does anyone happen to have a wiring diagram for the headlights of an Audi A5 with bi-xenon and cornering lights? MfG. Michael
Translated on 05-08-2026, 21:45.
Profile PM Garage |
08-05-2009, 7:35 Subject: Audi A5 Headlight Wiring Diagram |
The headlights won't have a "schematic," they are "simple" devices.
It will only contain a plug, 2-3 cables, and many lamps.
"It's all controlled by the vehicle's network control unit."
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 05-08-2026, 21:46.
Profile PM Garage |
08-05-2009, 7:43 Subject: Audi A5 Headlight Wiring Diagram |
Well, it's connected to a 14-pin connector after all. MfG. Michael
Translated on 05-08-2026, 21:47.
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
08-05-2009, 8:16 Subject: Audi A5 Headlight Wiring Diagram |
wow, so that the Audi's "brain" is located in the headlights, and I would have bet like Martin that the commands come from the BNSG (German Federal Constitutional Court) and are implemented in the headlight. Probably each individual daytime running LED is controlled separately  .
Silly question aside, isn't the A5 also somehow an A4 or A6? Surely they don't develop a completely separate wiring harness just for it...
08-05-2009, 8:19 Subject: Audi A5 Headlight Wiring Diagram |
matthiasTDI96 wrote: | | Silly question aside, isn't the A5 also somehow an A4 or A6, at least they probably didn't bother developing a completely new wiring harness... |
Okay, let me see. The ballast for the xenon headlights is also from an Audi A4. It starts with an 8K number. MfG. Michael
Translated on 05-08-2026, 21:48.
Profile PM Garage |
08-05-2009, 8:25 Subject: Audi A5 Headlight Wiring Diagram |
Hmm?
The 3C also has a 12 or 14-pin connector attached to it.
Besides the xenon ballasts, there's nothing else intelligent about it.
Translated on 05-08-2026, 21:49.
Profile PM Garage |
08-05-2009, 8:29 Subject: Audi A5 Headlight Wiring Diagram |
dieselmartin wrote: | | The 3C also has a 12 or 14-pin connector attached to it. |
If I remember correctly, your Passat also has cornering lights, right? MfG. Michael
Translated on 05-08-2026, 21:50.
Profile PM Garage |
08-05-2009, 9:21 Subject: Audi A5 Headlight Wiring Diagram |
Do you have the wiring diagram for my Passat, or for an A4/A6? MfG. Michael
Profile PM Garage |
08-05-2009, 9:26 Subject: Audi A5 Headlight Wiring Diagram |
The 3C with xenon headlights has "everything".
- Static cornering light
- Dynamic cornering light
- Bi-Xenon (which includes the shutter mechanism).
- and even parking lights  .
[img]/download.php?id=2695[/img]
And yes, I have that "how-to" guide, and it contains battle plans.
I'll check on the weekend to see which one... Transparency, Teamwork
Translated on 05-08-2026, 21:51.
Profile PM Garage |
08-05-2009, 9:30 Subject: Audi A5 Headlight Wiring Diagram |
dieselmartin wrote: | And yes, I have that "how it's done" document, and it contains battle plans.
I'll check on the weekend which... |
Thank you in advance. MfG. Michael
Translated on 05-08-2026, 21:52.
Profile PM Garage |
12-05-2009, 19:18 Subject: Audi A5 Headlight Wiring Diagram |
Sorry.
The book only contains information about standard H7 bulbs, not xenon bulbs.
Translated on 05-08-2026, 21:53.
Profile PM Garage |
12-05-2009, 22:45 Subject: Audi A5 Headlight Wiring Diagram |
dieselmartin wrote: | Sorry,
m; |
"It's not that bad. By chance, I had a 3C in the shop yesterday for a tire change. Of course, I took advantage of the situation and measured some things on the headlight connector. The 3C also has a 14-pin connector, but only 8 pins are actually used." MfG. Michael
Translated on 05-08-2026, 21:54.
Profile PM Garage |
