Last week, I installed a complete technical package from a 2003 Audi A3 1.9 TDI with an ASZ engine and a 6-speed gearbox into my A3 8L, 1.9 TDI with an AHF engine (built in June 1999). I had problems with the gearbox in the 5th gear, and I was simply intrigued by the idea of the conversion.
The entire wiring harness, including control units, engine, and transmission, was replaced. In short, everything was changed except for the body and chassis. The wiring harnesses for the doors were also not transferred over.
The donor vehicle had an accident on the driver's side, and the airbags were deployed. Therefore, the airbag control unit was also replaced with a used one that had not been deployed (the coding from the old unit was transferred to the new one).
Since I have an external audio system in the car, the cables for the speakers and the wiring to the Nokia subwoofer, etc., have been removed from the car's wiring harness. Only the black 8-pin connector for supplying power to the radio, the antenna cable, and the red ISO connector remain.
In addition, the wiring harness was reduced from the 5-door version to a 3-door version (the rear doors were only wired to the front doors and could be relatively easily removed).
However, the wiring harness for an electric sunroof was still installed.
The donor vehicle, or my car, now has a parking assist system (the control unit is not connected, as it is not needed) and a phone preparation system (also not connected). However, this should not be related to my problems.
Furthermore, I can say that the engine is running and the car drives (currently without the intercooler, as it still needs some optimization). This is why there are error messages for intake manifold pressure and temperature in the engine control unit. Currently, the rear hatch is missing, which means the wiring harness for the rear hatch is loose and unconnected inside the car.
I have already checked the continuity of the Low/High CAN lines from the KI (instrument cluster) to the ABS/ESP control unit and the engine control unit. When the ignition is switched on, there are approximately 2.3 to 2.6 volts between each line and ground.
Unfortunately, I don't have much experience when it comes to the "Can" thing.
I have attached the error log to this email.
I am encountering problems with the entries in the central control unit, the dashboard panel, and the ABS control unit.
Regarding this issue, I can say that the error code in the central locking control unit can be cleared. However, after a short time, the central locking pump briefly activates, and the error code reappears.
The "Corporate Data Bus Fault" error can also be cleared, but it reappears after a short time.
As far as I could tell from the wiring diagrams, I only see the two corporate data bus lines from the instrument cluster to the radio connector, which are currently disconnected. (But that shouldn't be a problem, since they essentially function as disconnected even when the radio isn't connected?)
Sunday, June 4, 2017, 12:59:27:04527
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 8.1 x64.
VCDS Version: RKS 17.1.3.0
Data as of: 20170224 DS267.4
Vehicle Identification Number: WAUZZZ8L83A070907
License plate: CHA A255
Mileage: 209,210 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 8L (8L - Audi A3/S3 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Mileage: 209,210 km
Address 01: Engine Control Module
Label file: DRV\038-906-019-ASZ.lbl
Part number: 038 906 019 FT
Component: 1.9L R4 EDC G000SG 1577
Encoding: 00002
Operating number: WSC 06435
VCID: 6ED7B7AC2A86AA310B-4B18
WAUZZZ8L83A070907 AUZ5Z0C0147051
2 error codes found:
17569 - Intake air temperature sensor (G72).
P1161 - 35-00 - Open circuit/short circuit after positive terminal.
17564 - Intake manifold pressure sensor (G71)
P1156 - 35-10 - Short to ground / Open circuit - Intermittent.
Readiness: 0 0 X X X
Address 03: Brake Electronics
Label file: DRV\1C0-907-37x-ESP-F.lbl
Part number: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Operating number: WSC 06435 000 00000
VCID: 346365C4542AC0E13D-515A
"One error found:"
01314 - Engine Control Unit.
013 - Please read the error memory.
Address 08: Climate Control/Heating. Label file: DRV\8L0-820-043-1D.lbl
Part number: 8L0 820 043 H
Component: A3, CLIMATE CONTROL UNIT, 0105.
Encoding: 00041
Operating number: WSC 00656
VCID: 2D5570A0E700912972-259E
"One error found:"
00787 - Temperature sensor, fresh air intake duct (G89).
29-10 - Short circuit to ground - Intermittent.
Address 15: Airbag
Label file: DRV\8L0-959-655-AI8.lbl
Part number: 8L0 959 655 J
Component: Front and side airbag 4008.
Encoding: 00104
VCID: 458528005FB049699A-5178
No error codes found.
Address 17: Control panel module
Label file: DRV\8L0-920-xxx-17.lbl
Part number: 8L0 920 900 K
Component: COMBINATION INSTRUMENT + TRIP COMPUTER. M73 D05.
Encoding: 04040
Operating number: WSC 00050
VCID: 336166D80124C7D924-4B18
"One error found:"
01336 - Corporate Data Bus Comfort.
37-10 - defective - intermittent.
Address 35: Central Locking
Label file: DRV\8D0-862-257.lbl
Part number: 8LO 862 257 D
Component: Central locking pump, radio. D03.
Encoding: 12864
Operating number: WSC 65535
VCID: 55A5F840AF10F9E9EA-4F02
"One error found:"
01366 - Opening via crash signal.
35-00 - -
Address 76: Parking Assist
Label file: DRV\4B0-919-283.lbl
Part number: 4B0 919 283.
Component: Parking system A3 RDW D18.
Encoding: 00103
VCID: 66C7CF8C0276627173-520C
"One error found:"
01543 - Parking assist warning buzzer (H15)
31-00 - Short circuit to ground / Interruption.
End----------------------------(Duration: 03:3
