soto
Joined: 09/08/2010 Posts: 7 Karma: +0 / -0 Location: Hannover
03-10-2010, 9:37 Subject: Oil Light On? Troubleshooting & Solutions |
Hello... I'm at a loss and urgently need help! I have an Audi A6 Quattro Avant 2.5 TDI.
(Year 2000) I bought it a few months ago and thought I had bought something "good," but since then I've only had problems!  I'm seriously considering selling it again!
Okay, but now let's move on to my new problem, and hopefully someone here can help me with it!
For a few days now, the oil pressure warning light has been coming on repeatedly, even though there is enough oil. Then I stop the car, and the next day everything is okay again!
Unfortunately, I don't currently have the necessary "pocket money" to have the car checked by Audi.
WHAT COULD IT BE...? EXPENSIVE?
Dearest greetings,
Translated on 18-10-2026, 22:29.
Mpire Profi-Schrauber
Joined: 10/19/2009 Posts: 351 Karma: +192 / -0 Location: Oberpfalz 2019 Skoda Octavia Premium Support
03-10-2010, 18:25 Subject: Oil Light On? Troubleshooting & Solutions |
Hello.
Let's try replacing the oil pressure switch/sensor first. It's not very expensive and it's not a big job to replace.
Good luck!
Mpire.
Translated on 18-10-2026, 22:30.
Profile PM Garage |
Styrian
04-10-2010, 15:27 Subject: Oil Light On? Troubleshooting & Solutions |
...I don't want to worry you right now, but please search this forum for "A6 2.5 TDI" or the engine codes "AKN" or "AKE"... you might have just bought yourself a car that's a money pit (on the contrary).
Best regards, Styrian.
Translated on 18-10-2026, 22:31.
soto
04-10-2010, 15:30 Subject: Oil Light On? Troubleshooting & Solutions |
Hello...
Yes, I've been thinking about that too, because it only lights up when the engine is properly warm!
Thank you very much!
Can one change it oneself?
soto
04-10-2010, 15:33 Subject: Oil Light On? Troubleshooting & Solutions |
 ...Hello Greetz, Styrian.
...what does that exactly mean?
Translated on 18-10-2026, 22:32.
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
04-10-2010, 16:14 Subject: Oil Light On? Troubleshooting & Solutions |
You can easily spend a fortune on a 2.5 TDI...
It is considered relatively prone to certain issues, such as problems with the camshaft and fuel injection pump.
Before I move the car any further, I would first want to investigate the oil issue, preferably by measuring the oil pressure. The oil pressure is always lowest when the engine is warm.
Translated on 18-10-2026, 22:33.
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
05-10-2010, 6:40 Subject: Oil Light On? Troubleshooting & Solutions |
Also, let's also check what kind of oil is being used, or if you're unsure, switch to an approved type of oil.
Background: If oil that is currently too thin is being used, the oil pressure may also be slightly lower than normal, which could lead to these effects in a warm engine.
Greetings.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 18-10-2026, 22:34.
Profile PM Garage |
Herbert Profi-Schrauber
05-10-2010, 18:03 Subject: Oil Light On? Troubleshooting & Solutions |
The A6 2.5 TDI should also have a dynamic oil pressure control system (?).
When does the oil level warning light come on, even when idling, or only at a medium engine speed? In the latter case, the warning buzzer might also activate (which may be different in the A6).
"vg" is an abbreviation for "very good". It is often used in online forums and chat rooms to express agreement or approval.
Translated on 18-10-2026, 22:35.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
05-10-2010, 21:56 Subject: Oil Light On? Troubleshooting & Solutions |
It is known that the connectors on the oil pressure switch may not be making 100% contact, and bending them can often help.
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
Paule0123
12-10-2010, 15:47 Subject: Oil Light On? Troubleshooting & Solutions |
Hello Soto, I had the same problem with my A4 2.5 TDI.
After I replaced the oil pressure switch and sensor, the oil pressure indicator still lit up.
It keeps coming back on. There's a ground point located in the engine compartment, on the front left side, underneath the headlight. It's a bit difficult to reach.
Clean the contacts and cable terminals (which may be oxidized). In my case, a ground cable was even broken, which I replaced. And don't be stingy with contact cleaner. I haven't had any problems since then (about 2000 km).
Translated on 18-10-2026, 22:36.
Hannes Blaumann
Joined: 08/25/2002 Posts: 64 Karma: +6 / -0 Location: Graz
24-05-2017, 9:31 Subject: Oil Light On? Troubleshooting & Solutions |
I'm experiencing the same problem with the oil pressure sensor in my A6 (engine: BAU). My question is, where is this sensor located?
Hannes.
Audi Allroad quattro LR, 2004
Audi S6 Avant quattro, 1995
Translated on 18-10-2026, 22:37.
