Licensed Interface Required
alexandererlangen
Post25-06-2017, 7:27    Subject: Licensed Interface Required Quote
I purchased the VCDS Ross Tech V2 HEX-NET (unlimited) interface and downloaded the VCDS software from the shop.
However, when I run the "VCDS DRV 17.1" application and perform an Autoscan, I always get the message "This function requires a licensed interface." I have already registered, though.
How can I solve this problem? Restarting the computer didn't help.
 Lizensiert
 File size:  169.29 KB
 Viewed:  2598 times
 Registriert
 File size:  120.35 KB
 Viewed:  4122 times
 Fehlermeldung
 File size:  191.49 KB
 Viewed:  2629 times
Schöne Grüße
Alexander
Translated on 13-09-2026, 3:43.
Karma: +805 / -0   Thank you, like it!
Post25-06-2017, 15:52    Subject: Licensed Interface Required Quote
Hello Alexander,
Could you please go to "Settings" in the main VCDS menu, then "Connection Test", "Save", and then in the main menu, click on "About..."?
Please email me a Screenshot of the "About..." dialog. In the Screenshot, there should be green text next to the serial number of the diagnostic cable, indicating that the interface is licensed.
I'm pretty sure I checked that already, but you never know.
It's possible that clicking "Connection Test" in the program settings will already resolve the issue.
Translated on 13-09-2026, 3:44.
alexandererlangen
Post26-06-2017, 14:10    Subject: Licensed Interface Required Quote
Hello Rainer,
It says "not licensed" there.
Best regards.
Alexander.
 nicht aktiviert
 File size:  216.37 KB
 Viewed:  2605 times
Schöne Grüße
Alexander
Translated on 13-09-2026, 3:45.
Post26-06-2017, 14:14    Subject: Licensed Interface Required Quote
That's bad; HEX-NET should already have a license from Ross-Tech. I'll inquire about it.
alexandererlangen
Post27-06-2017, 7:02    Subject: Licensed Interface Required Quote
OK. Thank you for the email.
I'll wait and see if they can manage it.
So, the serial number is different in the German and English versions.
Schöne Grüße
Alexander
Translated on 13-09-2026, 3:46.
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts Quantity setting device and control path generator: Function Technical Articles
No new posts What interface is required On-Board Diagnostics (OBD)
No new posts Passat Tire Wear: 3B Sedan, 98, 110 HP AFN Transmission, Chassis, Body & Interior
No new posts Piston Retraction Tool: Do You Need It for VAG? Transmission, Chassis, Body & Interior
No new posts Russia Problems: Urgent Help Needed! Diesel Engine Technology
