Golf 7 GTI: Install Reverse Camera (Aftermarket)
Go to page: 1, 2, 3  Next
vag-driver
Post14-12-2017, 15:28    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
A colleague wants to retrofit a camera into his Volkswagen Golf GTI (7th generation) using a custom-made wiring harness.
Here, we are only concerned with the coding. Who has done the coding, and can at least give me a general idea of what needs to be coded?
I will send you the Autoscan results later.
Andreas
Translated on 27-08-2026, 12:08.
vag-driver
dieselschrauber likes this.
Post15-12-2017, 7:32    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
Attached, as previously announced, is the automated scan.
Thursday, December 14, 2017, 2:27:03 PM.
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 17.1.3.0
Data as of: 20170220 DS267.3
Vehicle Identification Number: WVWZZZAUZGW240602
License plate:
Mileage: 31863 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 3C 42 44 52 55 5F
A5 A9
Mileage: 31,863 km
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: Error 0010.
05-Access/Startup Report -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
Parking Assist 10 -- Status: Error 0010.
13-meter distance rule -- Status: OK 0000
14-inch damper -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
2B steering column lock. -- Status: OK 0000.
3C Lane Change -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
A5 Front/Forward-facing camera -- Status: Error 0010.
A9 body sound actuator -- Status: OK 0000
Address 01: Engine Control Module (J623-CXDA)
Label file: DRV\06K-907-425-V1.clb
Part number SW: 5G0 906 259 C, HW: 06K 907 425 B.
Component: 2.0l R4 TFSI, part number H13 0002.
Revision: --H13---
Encoding: 091D00322464052B3000
Operating number: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
ROD: EV_ECM20TFS0205G0906259C.rod
VCID: 2E5538BD715CFC314B-807A
No error codes found.
Readiness: 0010 0001
Address 02: Transmission (J743)
Label file: DRV\0D9-927-770.clb
Part number SW: 0D9 300 041 C, HW: 02E 927 770 AQ.
Part: DQ250-6F MQB H53 4902
Revision: 06253104 Serial number: TFK01512180862
Encoding: 0014
Operating number: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1839FE65E3D8128131-804C
Address 03: Brake Electronics (J104)
Label file: 5Q0-907-379-IPB-V1.clb
Part number SW: 3Q0 907 379 AB
Part number HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60146000000889
Encoding: 01FA6BA13424296C077D0600C1C5A980D62C94E0608395F7184250FAC289
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 7AFDC4EDFD94E091A7-802E
"One error found:"
16401 - Tire pressure warning.
C102D 00 [008] - -
Sporadically - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 1.
Lost Count: 74
Mileage: 30,516 km
Date: 2017.11.10
Time: 16:10:31
Address 05: Access/Startup Authorization (J518)
Label file: DRV\5Q0-959-435.clb
Part number SW: 5Q0 959 435 A, HW: 5Q0 959 435
Part number: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0393278004
Encoding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A7D04EDBD142091E7-806E
Address 08: Climate Control/Heating Unit (J255)
Label file: DRV\5G0-907-044.clb
Part number SW: 5G0 907 044 BD
Hardware number: 5G0 907 044 BD
Component: Climatronic
Part number: H03 1001
Revision: 00001K08
Encoding: 00020014200100011105000000101002
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6ADDF4AD8D34501157-803E
Control unit for the fresh air blower (front).
Refrigerant pressure and refrigerant temperature sensors:
Air quality sensor:
Address 09: Central Electronics (J519)
Label file: 5Q0-937-08X-HV1.clb
Part number SW: 5Q0 937 084 AS, HW: 5Q0 937 084 AN.
Component: BCM MQBAB H H24 0175
Serial number: 01061602703550
Encoding: 00111E46C24122FB0BA44080B11C072818000000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 091FAB21A872FB09BE-805C
Wiper motor control unit:
Subsystem 1 - Part number SW: 5G1 955 119 A, HW: 5G1 955 119 A, Label file: DRV\5QX-955-119-V1.CLB.
Component: WWS 160109 043 0551
Serial number: 160127082118
Encoding: 0E4DDD
Rain and light sensor:
Subsystem 2 - Part number SW: 5Q0 955 547 A, HW: 5Q0 955 547 A, Label file: DRV\5Q0-955-547.CLB.
Component: RLHS 037 0059
Serial number: S4Y16M02D04H15M52S26
Encoding: 90A8DD
Sensor for anti-theft system:
Subsystem 3 - Part number SW: 5Q0 951 172, HW: 5Q0 951 172.
Component: Sensor, DWA 005 0316.
Serial number: 000000000ZY160131MGW
Alarm horn:
Subsystem 4 - Part number SW: 5Q0 951 605 A, HW: 5Q0 951 605 A.
Component: Siren, DWA 005 0313.
Serial number: 00000000000034450253
Control unit for sunroof.
Subsystem 5 - Part number SW: 8V3 959 591 A, HW: 8V3 959 591 A.
Component: J245 PS73.403 H03 0004.
Serial number: 0000FST000RIXPV00000.
Encoding: 181801
2 error codes found:
204290 - Radio key 1.
B1479 18 [009] - Current too high.
Error priority: 4.
Error frequency: 1.
Lost Count: 172
Mileage: 27561 km
Date: 2017.08.29
Time: 15:20:11
262912 - Sensor for anti-theft system.
B1330 F5 [008] - Note: Emergency sharpening, level 1.
Error priority: 7
Error frequency: 1.
Lost Count: 113
Mileage: 31,546 km
Date: 2017.12.01
Time: 17:16:17
Address 10: Parking Assist 2 (J791)
Label file: 5Q0-919-298.clb
Part number SW: 5Q0 919 298 K, HW: 5Q0 919 298 K.
Part: PARKHILFE PLA H12 0054
Revision: -------- Serial Number: 39491535004262
Encoding: 0031065051
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 479B6D19FEE64D7968-8012
"One error found:"
13638913 - Data bus, missing message.
U1121 00 [008] - -
Error priority: 4.
Error frequency: 1.
Lost Count: 130
Mileage: 31724 km
Date: 2017.12.09
Time: 11:20:14
Address 13: Distance Control (J428)
Label file: 5Q0-907-572-V1.clb
Part number SW: 5Q0 907 572 F. Hardware: 5Q0 907 572 F.
Component: ACC Bosch MQB H05 0400
Serial number: 21121504404976
Encoding: 001C1700FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_VW26.rod
Address 14: Wheel Damping (J250)
Label file: 5Q0-907-376.clb
Part number SW: 5Q0 907 376 A, Hardware: 5Q0 907 376 A.
Component: SOUND DAMPENING MATERIAL H17 0120
Serial number: 10011641350035.
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC.rod
VCID: 377B1DD98E063DF918-8062
Address 15: Airbag (J234)
Label file: DRV\5Q0-959-655.clb
Part number SW: 5Q0 959 655 D, HW: 5Q0 959 655 D.
Component: Airbag VW20 015 0388
Serial number: 003F6R1EXTPO
Encoding: 98CCC000000000005C0000CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 418F7301D0C27349A6-8014
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 480 000 102 16
Component: SideSensor_Df 001 0887
Serial number: 35767000000E66BCE81E
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: ----------- HW: 480 000 202 16
Component: SideSensor_Pf 001 0887
Serial number: 35867000000BAB91B815
Encoding: 2D2D2D
Rear side airbag crash sensor (driver's side).
Subsystem 3 - Part number: SW: ----------- HW: 480 400 202 16
Component: SideSensor_Dr 001 6149
Serial number: 3516502A518166C2B3CD
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 480 400 202 16
Component: SideSensor_Pr 001 6149
Serial number: 3526502B518166C362DB
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: ----------- HW: 480 402 701 16
Component: FrontSensor_D 001 6149
Serial number: 35565029D1E9F0E5636Z
Encoding: 2D2D2D
Address 16: Steering wheel electronics (J527)
Label file: DRV\5Q0-953-549.clb
Part number SW: 5Q0 953 507 HN
Part number HW: 5Q0 953 549 E
Bauteil: Lenks. Module 003 0120.
Revision: -------- Serial Number: 01111504220516
Encoding: 0C10
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_SK48.rod
Address 17: Control panel module (J285)
Label file: DRV\5G0-920-XXX-17.clb
Part number SW: 5G1 920 756 A, HW: 5G1 920 756 A.
Part: KOMBI 302 6420
Encoding: 07AD09187F9C000801887E0B5400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2B5331A9424E89196C-807E
Address 19: Diagnostic Interface (J533)
Label file: DRV\5Q0-907-530-V1.clb
Part number SW: 5Q0 907 530 AJ, HW: 5Q0 907 530 F.
Component: GW MQB High, Part Number: 128 1244.
Revision: -------- Serial Number: 0004453042
Encoding: 030100043F085900FB00027A9C0F000100010500000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013.rod
VCID: 79FFDBE1F892EB89AE-802C
Generator:
Control unit for multifunction steering wheel:
Subsystem 2 - Part number SW: 5G0 959 442 N HW: 5G0 959 442 N Label file: DRV\3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160000124650066033.
Encoding: 2DFFFF
Battery monitoring control unit:
Subsystem 3 - Part number SW: 5Q0 915 181 G, HW: 5Q0 915 181 G.
Part: J367-BDM, Hella, H04 8050.
Serial number: 2696499003
Address 2B: Steering column lock. (J764)
Label file: DRV\5Q0-905-861.clb
Part number SW: 5Q0 905 861 A. Part number HW: 5Q0 905 861 A.
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial Number: 16000013383010
Encoding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 34612AD59F70D6E13D-8060
Address 3C: Lane Change (J1086)
Label file: None.
Part number SW: 5Q0 907 686 B. Part number HW: 5Q0 907 686 B.
Component: HRE_Master H12 0071
Serial number: 0392980154
Encoding: 02011103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella.rod
VCID: 3C7102F5B7201EA1F5-8068
Control unit 2 for lane change assist.
Address 42: Door Electric Driver (J386)
Label file: 5QX-959-X93-42.clb
Part number SW: 5Q0 959 593 E, HW: 5Q0 959 593 B.
Component: TSG FS 020 0041
Serial number: 161215ELF07274.
Encoding: 003F1220D000040000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43837909CADE6159B4-8016
Rear door control module, driver's side.
Subsystem 1 - Part number SW: 5Q0 959 811 HW: 5Q0 959 811 Label file: DRV\5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000008812328
Encoding: 110000
Address 44: Steering Assist (J500)
Label file: DRV\5Q0-909-144.clb
Part number SW: 3Q0 909 144 J, HW: 3Q0 909 144 H.
Part number: EPS_MQB_ZFLS 505 5063
Coding: 9303
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 397F1BE1B8122B89EE-806C
Address 52: Power door lock, front passenger side (J387)
Label file: 5QX-959-X92-52.clb
Part number SW: 5Q0 959 592 E, HW: 5Q0 959 592 B.
Part number: TSG BFS 020 0041.
Serial number: 171215ELH00615
Encoding: 003F1020DE00040000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428D7C0DD5C46851BF-8016
Door control module, rear passenger side:
Subsystem 1 - Part number SW: 5Q0 959 812 HW: 5Q0 959 812 Label file: DRV\5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000008790227
Encoding: 090000
Address 55: Headlight range control (J745) Label file: DRV\7P6-907-357.clb
Part number SW: 7P6 907 357 D, HW: 7P6 907 357 A.
Component: AFS-ECU H07 0090
Revision: -------- Serial Number: --------------
Encoding: 029203104F000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 40897605DBC87A41A9-8014
Headlight module, left side:
Subsystem 1 - Part number SW: 3D0 941 329 D, HW: 3D0 941 329 D, Label file: 3D0-941-329.CLB.
Part: LeiMo left side, H01 0002.
Coding: 900000
Headlight module, right side:
Subsystem 2 - Part number SW: 3D0 941 329 D, HW: 3D0 941 329 D, Label file: 3D0-941-329.CLB.
Component: Right-hand LeiMo, part number H01 0002.
Coding: 900000
Address 5F: Information selection. I (J794)
Label file: 5G0-035-MIB-STD2.clb
Part number SW: 3Q0 035 846 Hardware: 3Q0 035 846
Component: MU-S-N-ER 820 0624
Serial number:
Encoding: 02730001FF00000051110001000808031F0203C4012001008F
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6ED5F8BDB1DCBC310B-803A
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 3G0 919 605 D, HW: 3G0 919 605 D.
Component: ABT_Std-2_Nav H43 4063
Serial number: VWZ6Z9S0331827
Storage devices:
Subsystem 2 - Part number SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Serial number: --------------------
Address A5: Front/Forefield camera (R242)
Label file: DRV\5Q0-980-653.clb
Part number SW: 5Q0 980 653 G, HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000492475
Encoding: 0101020001020306000400010100000100
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
"One error found:"
1123593 - Data bus received error value.
U1123 00 [008] - -
Error priority: 6
Error frequency: 48.
Lost Count: 132
Mileage: 27556 km
Date: 2017.08.29
Time: 15:11:35
Engine control unit temperature: 42 °C.
Outdoor temperature: 23.0 °C
Vehicle speed: 0.00 km/h
Voltage at terminal 15: 13.5 V.
System runtime: 4.4 s
Address A9: Body sound actuator (J869)
Label file: 4H0-907-159.clb
Part number SW: 5G0 907 159, HW: 4H0 907 159 A.
Component: SAS-GEN 2 H06 0014
Serial number: 151113200472.
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X_VW26.rod
VCID: 6BD3F1A982CE49192C-803E
End----------------------------(Duration: 05:26)-----------------------------
Andreas
Translated on 27-08-2026, 12:58.
Post15-12-2017, 9:09    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
I haven't done it myself yet, but I found this information about it.
It's best to verify this again using the labels in VCDS.
Select STG 5F (Infotainment).
STG Long Encoding -> Function 10.
Byte 19.
Enable bit 4.
"...if parking assistance is available, it must also function as follows:..."
to be adapted.
Select STG 10 (Parking Assist).
Byte 2
Enable bit 4.
vag-driver
Post15-12-2017, 11:35    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
Another question that just occurred to me: Is a simple coding sufficient, or is an additional key also required to be purchased from VW?
Andreas
Translated on 27-08-2026, 13:00.
vag-driver likes this.
Post15-12-2017, 12:29    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
As far as I understand, you can have it done at VW by assigning it a measurement code, which is equivalent to a factory installation. However, some dealers cause problems if you install it yourself and then want it to be activated. Of course, they want to make money, so they tend to doubt that the customer has installed it correctly.
However, it's not a mandatory requirement, unlike, for example, the post-purchase activation of speech recognition, which is exclusively sold as a Software as a Product (SwaP). The included encoding is usually sufficient for the functionality.
vag-driver
Post15-12-2017, 13:17    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
In this example, the encoding was sufficient: http://www.golfmk7.com/forums/showthread.php?t=7618
Andreas
Translated on 27-08-2026, 13:01.
vag-driver
Post18-12-2017, 11:39    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
If things progress, meaning the hardware upgrade is complete, I will report back.
Andreas
vag-driver
Post21-12-2017, 13:59    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
The delivery time for the camera set is February/March icon_eek.gif.
Andreas
Post21-12-2017, 14:50    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
Wow...
Well, anticipation is the sweetest joy icon_wink.gif.
Translated on 27-08-2026, 13:02.
vag-driver
Post22-12-2017, 7:09    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
Roger wrote:
Oha...
The colleague is extremely excited and can hardly wait icon_lol.gif.
Andreas
vag-driver
Post18-01-2018, 18:08    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
I have coded:
Byte 19.
Enable bit 4.
Byte 2.
Enable bit 4.
After that, the display shows a message indicating that the parking assist system has been deactivated. Attempting to activate the parking assist system results in an error message: "Invalid value range."
Obviously, more needs to be done besides the changes mentioned above.
Andreas
Translated on 27-08-2026, 13:03.
dieselschrauber and vag-driver likes this.
Post18-01-2018, 19:25    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
Would you like me to compare the codings point by point with yours? Perhaps that will reveal something that helps you.
"On mine, the RFK was pre-installed from the factory."
Saturday, November 25, 2017, 2:09:10:39733 PM.
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x64.
VCDS Version: RKS 17.8.0.1 HEX-V2 CB: 0.4407.4
Data as of: 20171117 DS276.6
Vehicle Identification Number: WVWZZZAUZJW043xxx Vehicle registration plate:
Mileage: 6266 km. Repair order:
Vehicle type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 29 32 39 42 44 47 4B 52 5F A5
A9 D6 D7
Mileage: 6266 km
03-Brake electronics -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
29-Channel lighting control, left side -- Status: OK 0000
32-pin electronics -- Status: OK 0000
39-Light control, right side -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B Multifunction Device -- Status: OK 0000
A5 Front/Forward-facing camera -- Status: OK 0000
D6-Left lighting control 2 -- Status: OK 0000
D7-Light control, right side, 2 -- Status: OK 0000
Address 01: Engine Control Module (J623-DLBA)
Label file: None.
Part number SW: 5G0 906 259 N, HW: 06K 907 425 J.
Revision: --H13---
Encoding: 091900322444050B2000
ASAM Dataset: EV_ECM20TFS0205G0906259N 002003
ROD: EV_ECM20TFS0205G0906259N_002_VW37.rod
VCID: 392EDDFF99D0219F5C4-806C
Readiness: 0000 0000
Label file: .5Q0-907-379-IPB-V1.clb
Part number SW: 5Q0 614 517 CE, HW: 5Q0 614 517 AC.
Component: ESC, Part Number: H25 0413.
Revision: 00000000 Serial number: 51877000001042
Encoding: 01FA6BA15424216F4779060340CB6980D62A84E26002967734405079C009430000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
VCID: 76B416C3E84E8EE7716-8022
Label file: | DRV\5G0-907-044.clb
Part number SW: 5G0 907 044 CF
Hardware: 5G0 907 044 CF
Component: Climatronic. Part number: H04 1801.
Revision: 00001K08
Encoding: 0002000420011001110500000010102A
ASAM Dataset: EV_ACClimaBHBVW37X 006145
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 6D8639AF9D184D3F80C-8038
Air quality sensor:
Label file: .DRV\5Q0-937-08X-V2.clb
Part number SW: 5Q0 937 084 CP, HW: 5Q0 937 084 CF.
Component: BCM MQBAB M+ H36 0253.
Serial number: 01001720101525
Encoding: 0000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 0848683B92BA881713A-805C
Component: WWS 170617 043 0551
Serial number: 170711204521
Encoding: 0E4DDD
Subsystem 2 - Part number SW: 5Q0 955 547 B HW: 5Q0 955 547 B Label file: DRV\5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y17M07D28H22M25S05.
Encoding: 00A8DD
Serial number: 000000000ZY1716506KC
Alarm horn:
Component: Siren, DWA 005 0314.
Serial number: 00000000000069858935
Address 10: Parking Assist 2 (J791) Label file: | DRV\5Q0-919-298.clb
Part number SW: 5QA 919 298 C, HW: 5QA 919 298 A.
Component: PLA 3.0 12KH07 0045
Serial number: 000308417617202
Encoding: 0271163841
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 50F8805B2A6A80D78BA-8004
Label file: * None
Part number SW: 5Q0 907 572 J, HW: 3QF 907 572.
Part number: ACC BOSCH MQB H10 0654.
Encoding: 2B0060C159FFC728949C810560400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
ROD: EV_ACCBOSCHVW416.rod
VCID: 3E24CEE380FE06A7696-806A
Address 15: Airbag (J234) Label file: | DRV\5Q0-959-655.clb
Part number SW: 5Q0 959 655 BH, Hardware number: 5Q0 959 655 BH.
Part: Airbag VW21 005 0336
Serial number: 003VVR3463M1
Encoding: 98CCC000000000005C0000CF000800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002158
VCID: 074A6B079FA4876F1A0-8052
Subsystem 1 - Part number: SW: ----------- HW: 480 001 907 17
Serial number: 35700000000360380620
Encoding: 2D2D2D
Subsystem 2 - Part number: SW: ----------- HW: 480 002 307 17
Serial number: 358000000007922C062D
Encoding: 2D2D2D
Subsystem 3 - Part number: SW: ----------- HW: 480 401 407 17
Component: SideSensor_Dr 000 6149
Serial number: 3510001B12552CE233B
Encoding: 2D2D2D
Subsystem 4 - Part number: SW: ----------- HW: 480 400 807 17
Component: SideSensor_Pr 000 6149
Serial number: 3520001B925F58824712.
Encoding: 2D2D2D
Subsystem 5 - Part number: SW: ----------- HW: 480 401 507 17
Component: FrontSensor_D 000 6149
Serial number: 3550001C32620985E54+
Encoding: 2D2D2D
Address 16: Steering Wheel Electronics (J527)
Label file: .DRV\5Q0-953-549.clb
Part number SW: 5Q0 953 507 FT, HW: 5Q0 953 549 F.
Bauteil: Lenks. Module 003 0140.
Revision: -------- Serial Number: 23071708490248
Encoding: 0400
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_VW37.rod
VCID: 0D46592FFDD8ED3F20C-8058
Label file: | DRV\5G0-920-XXX-17.clb
Part number SW: 5G1 920 791 A, HW: 5G1 920 791 A.
Component: COMBINATION UNIT 407 3193
Encoding: 07A511006F84000801886B031401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
VCID: 2A0CF2B36C769A0725E-807E
Label file: .DRV\3Q0-907-530-V1.clb
Part number SW: 3Q0 907 530 G, HW: 3Q0 907 530 C.
Component: GW MQB High, Part Number: 433 4303.
Revision: -------- Serial Number: 0006485201
Encoding: 030100047F085900FB00027B080F000100010700000000000000000000000
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 3332EFD7BBBCDBCF968-8066
Generator:
Serial number: 29170001418950087264
Encoding: 2CFFFF
Subsystem 3 - Part number SW: 5Q0 915 181 K, HW: 5Q0 915 181 K.
Part: J367-BDM Hella H10 9070
Serial number: 8884144704
Address 29: Left-hand light control (J1018)
Label file: 8V0-907-399.clb
Part number SW: 8V0 907 399 D, HW: 8V0 907 399 D.
Component: LCM_MLBevoH08 0014
ASAM Dataset: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW37.rod
VCID: 47CAAB07DF24476FDA0-8012
Address 32: Keypad electronics (J492)
Label file: *DRV\0CQ-907-554.clb
Part number SW: 0CQ 907 554 E, HW: 0CQ 907 554 E.
Component: Crossbar
H52 8042
Serial number: HA1-00019.04.17.
Encoding: 0001
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
Address 39: Right-hand light control (J1023)
ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 42: Door Electric Driver (J386) Label file: |5QX-959-X93-42.clb
Serial number: 290617EFT00898
Encoding: 003F0220D000040000001000
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 43D2BF17EB1C6B4F068-8016
Subsystem 1 - Part number SW: 5Q0 959 811 D, HW: 5Q0 959 811 D.
Component: FOND_FHSG_DRV 005 0007
Serial number: 00000000000015578084
Encoding: 110000
Label file: | DRV\5Q0-909-144.clb
Part number SW: 3Q0 909 144 K, HW: 3Q0 909 144 H.
Part number: EPS_MQB_ZFLS 506 5072
Coding: 9307
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 3A2CC2F39CD62A8755E-806E
Address 47: Soundsystem (J525) Label file: | DRV\5Q0-035-456.clb
Part number SW: 5Q0 035 456 A. Hardware: 5Q0 035 456 A.
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial Number: VWZ8Z1HMD00S1AI
Encoding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI_VW37.rod
VCID: 2E04FEA3509EF627F96-807A
Address 4B: Multifunction module (J745) Label file: * None
Part number SW: 3Q0 907 338 Hardware: 3Q0 907 338
Component: FCM MQB Low, part number: 002 0286.
Serial number: 24061710802469
Encoding: 000000050100164A01204F01020000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 001010
ROD: EV_MultiModulContiVW48X_VW37.rod
VCID: 72BC2AD3842692C75DE-8026
Address 52: Power door lock, front passenger side (J387) Label file: | 5QX-959-X92-52.clb
Serial number: 300617EFU22635
Encoding: 003F0020DE00040000801000
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 42DCBA13F40662470DE-8016
Subsystem 1 - Part number SW: 5Q0 959 812 D, HW: 5Q0 959 812 D.
Component: FOND_FHSG_PSG 005 0007
Serial number: 00000000000015585843
Encoding: 090000
Address 5F: Information Selection. I (J794)
Label file: | 5G0-035-MIB-STD2.clb
Part number SW: 3Q0 035 874 C, Hardware: 3Q0 035 874 C.
Component: MU-S-ND-ER 851 0842
Serial number:
Encoding: 02731001000000004111010200880A231F0503F4012000008F
VCID: 323CEAD344A6D2C79DE-8066
Subsystem 1 - Part number SW: 5G6 919 605 B, HW: 5G6 919 605 B.
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT2022318
Storage devices:
Subsystem 2 - Part number SW: 3G0 919 866 BJ HW: -----------
Component: ECE1 2018 --- 0915
Address A5: Front/Forefield Camera (R242)
Label file: | DRV\3Q0-980-65X-A5.clb
Part number SW: 3Q0 980 654 H, HW: 3Q0 980 654 A.
Component: MQB_B_MFK H07 0272
Serial number: 21071711P23110
Encoding: 000307000000040100221344C150A90090000E300040
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_VW36.rod
VCID: 3C20C4EB96E214B7472-8068
Part number SW: 5G0 907 159 G, HW: 4H0 907 159 A.
Component: SAS-GEN 2 H07 0001
Serial number: 170614204404
Address D6: Left lighting control 2 (A31)
Label file: None
Part number SW: 7P5 941 572 A. Hardware: 7P5 941 572 A.
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481_VW37.rod
Address D7: Right-side lighting control 2 (A27)
Label file: None.
Part number SW: 7P5 941 572 A. Hardware part number: 7P5 941 572 A.
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End -------- (Duration: 01:47, Battery voltage start/end: 12.1V/12.1V) --------
Translated on 27-08-2026, 13:46.
vag-driver
Post18-01-2018, 19:36    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
I will do that. Thank you very much.
Andreas
vag-driver
Post19-01-2018, 7:50    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
The codings at addresses 10 and 5F differ significantly and in multiple places. I can only verify this by examining the vehicle directly.
I suspect these are adaptation channels that are not documented in VCDS.
@RogerViewing profile: Roger
I live in Münster icon_cool.gif.
Andreas
Translated on 27-08-2026, 13:47.
Post19-01-2018, 9:54    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
vag-driver wrote:
The codings at addresses 10 and 5F differ significantly and in several places. I can only verify this by looking at the vehicle directly.
An update to the current version 17.8.1 might help, if it hasn't been done already. In some cases, I even use the 17.12 beta version because version 17.8.1 still lacks some of the Tube adjustments for AID.
If that's the Münster church near Dieburg, you can see it for yourself if you want.
Translated on 27-08-2026, 13:48.
vag-driver
Post19-01-2018, 11:26    Subject: Golf 7 GTI: Install Reverse Camera (Aftermarket) Quote
The installed VCDS version is 17.8.1, but it's using the older interface from before version 2.
Yes, Münster near Dieburg.
I just received information that my colleague was at VW and there seems to be a power outage. It apparently happens more often because the production is in the Czech Republic. Now he has to find the cause of the problem first.
Andreas
Translated on 27-08-2026, 13:49.
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Upgrade Thermotop T with genuine T70 Transmission, Chassis, Body & Interior
No new posts Audi A3 8V: Install Tow Hitch (Original) Electrical Systems, Vehicle Electronics, Multimedia
No new posts Roof Antenna for VW Golf 3 Variant - Original Fit Transmission, Chassis, Body & Interior
No new posts Reverse Camera Replacement Audi A3 8V Electrical Systems, Vehicle Electronics, Multimedia
