ATJ Cylinder Head Washout: Causes & Repair
Matzepatze
Post23-06-2017, 20:52    Subject: ATJ Cylinder Head Washout: Causes & Repair Quote
Hello!
Today, I had to remove the cylinder head (a common issue with AJM/ATJ engines, causing coolant to leak).
On the 2nd pot, it was clearly visible where there was a leak. After cleaning the cylinder head, I'm now wondering whether I should have it re-planed or not. It has slight corrosion, which can be felt with the fingernail, but it also already has a 3mm gasket. How should the corrosion be assessed?
Matzepatze.
3B 4motion ATJ
Translated on 05-10-2026, 22:00.
dieselschrauber likes this.
Post24-06-2017, 10:23    Subject: ATJ Cylinder Head Washout: Causes & Repair Quote
Planning is actually not allowed, but in my experience, it's not critical up to 1/10mm. However, a thicker gasket is not used for this reason!
Translated on 05-10-2026, 22:01.
No new posts Document A6 4B, Fuel Leak at Cylinder Head Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Severe oil leak at the cylinder head, AJM engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AAZ Cylinder Head - Replacement & Repair Diesel Engine Technology
No new posts Cylinder Head Boring: Guide & Best Practices Diesel Engine Technology
No new posts Head Bolt Torque Specs AWX Engine Diesel Engine Technology
No new posts Cylinder Head Differences: A Comparison Guide Diesel Engine Technology
