Torque specifications for crankshaft/connecting rod (CBBB)
Yayo
Post30-07-2017, 14:12    Subject: Torque specifications for crankshaft/connecting rod (CBBB) Quote
Good day.
Thank you in advance for your help and contributions. Unfortunately, I've reached the limits of my search capabilities, and I hope you might be able to provide me with the information I need.
My vehicle is a Passat 6B with a 2.0 TDI engine and 170 horsepower (the engine code is CBBB).
After the update from VW was performed, I initially experienced problems with the regeneration of the particulate filter and a significantly increased fuel consumption. The whole story ended with an engine failure that VW doesn't want to cover.
We have already completely disassembled the engine and are now in the process of reassembling it. However, we are missing the torque specifications for the crankshaft itself.
Could someone perhaps send me a list?
Sincerely,
Yayo
Yayo likes this.
Post30-07-2017, 14:49    Subject: Torque specifications for crankshaft/connecting rod (CBBB) Quote
Connecting rod bearing cap: 30 Nm + 90° (lightly lubricate threads and contact surfaces).
Main bearing cover: 65 Nm + 90°.
EDIT: It's obvious for you, but for posterity, the maintenance report also states: "replace worn bearing shells."
No new posts Problem Kühlmittelanzeige, MKB CBAB, CBBB, CBDC, CBAA, CBBA Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Urgent Diesel Piston Needed Diesel Engine Technology
No new posts Connecting rod of a ship's diesel engine Diesel Engine Technology
No new posts AFN Engine: Head Gasket, Connecting Rod Issues? Diesel Engine Technology
No new posts AEL Crankshaft Counterweight - Replacement Diesel Engine Technology
