Climate leakage due to improper maintenance? Urgent!!
flightmaster
Post29-05-2003, 16:31    Subject: Climate leakage due to improper maintenance? Urgent!! Quote
Golf IV, 1999, ALH, Manual Climate Control
Hello, dear screw community
There, I went to VAG last week and had the air conditioning system serviced.
With dismay, I had to realize today that on the aluminum can, on the left, there is apparently a glowing green substance coming out in bubbles.
That seems to be refrigerant.
Apparently, 60% of the refrigerant was missing during the service.
Shouldn't they actually be doing a pressure test?
Could it be that the brothers at VW have overfilled the system, and now there is too much pressure?
I really need information, because I know these guys and they will probably try to tell me something different tomorrow, just to avoid having to take responsibility for the damage.
Thank you already.
Post29-05-2003, 16:39    Subject: Climate leakage due to improper maintenance? Urgent!! Quote
Bright green substance indicates a filled leak detection agent icon_smile.gif
What do you want to accuse the garage of having noticed that there wasn't enough coolant and that they had cautiously filled in a leak detection agent?
However, if something comes out of the dryer and exactly this one was replaced as part of the maintenance, it should be sealed and refilled free of charge.
Hello, Rainer
flightmaster
Post29-05-2003, 17:21    Subject: D.h. also, seal the dryer. Quote
I thought they sprayed it on the outside.
That means the leak detection agent will be filled in. I meant that the green liquid is the refrigerant itself.
I'm afraid I have no idea.
D.h. also, the dryer needs to be sealed. The leak detection fluid is coming out at the upper bracket. There is a 6mm Allen screw attached.
I
I believe that the entire chimney needs to be brought into service, the dryer needs to be replaced, the whole thing needs to be sealed, refilled, and reassembled.
What will this likely mean financially?
But thank you very much for the quick help.
KombiBlue
Post29-05-2003, 17:47    Subject: Climate leakage due to improper maintenance? Urgent!! Quote
Hello, yes, that's right, the leak detection agent is filled in. Because it fluoresces, the leak can be found using a UV lamp (black light), as the leaked substance will then glow. (Not every leak is as large as yours icon_biggrin.gif)
Gruss Ralf
Passat Var. 2.0 TDI 3/2009, 125kW, CBBB
Post30-05-2003, 8:52    Subject: Re: Meaning: Therefore, seal the dryer. Quote
flightmaster wrote:
That means, in other words, to seal the dryer. The leak detection fluid is coming out at the upper mounting bracket. There's a 6mm Allen screw there.
So, therefore, your dryer was not replaced as part of your climate service?
Since your climate is already over 3 years old and has been leaking for a long time, it might be a good idea to replace the old dryer as well.
Unfortunately, I cannot give you an exact figure for the costs; however, the range should be between 100 and 200 euros.
Hello, Rainer
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Battery Care: Tips for Checking and Maintenance Technical Articles
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate maintenance for the 1Z Diesel Engine Technology
No new posts Climate Change: Urgent Action Needed! Diesel Engine Technology
No new posts LuFI G3 undicht durch Beruehren Transmission, Chassis, Body & Interior
No new posts STG08 Climate - Function limitation due to MSG Transmission, Chassis, Body & Interior
