Oily Turbocharger Boost Hose: Causes & Fixes
skodaben
Post18-07-2017, 16:17    Subject: Oily Turbocharger Boost Hose: Causes & Fixes Quote
Hello everyone,
I drive a Skoda Octavia 1Z3 with a 1.9 TDI BLS engine, 77 kW, and 229,9xx kilometers. It's been chipped, and I've been experiencing a loss of power for quite some time now.
VCDS Autoscan does not report any engine control unit errors.
The AGR (Abgasrückführung) system was expanded and completely cleaned. It was completely clogged with oil. After the procedure, there was a slight improvement in acceleration at partial load.
"Since I recently had a crack in the vacuum hose of the BKV (boost control valve), it was replaced. During the replacement, I noticed that the charge pressure hose, which connects to the turbocharger, is completely oily. Unfortunately, I don't know where this oil is coming from."
I have attached the pictures of the oily hose in the attachment.
Where did the oil come from, and could the turbocharger have been damaged?
Best regards, Ben.
 So von vorne ..
 File size:  472.71 KB
 Viewed:  5095 times
 So sieht der Schlauch von oben aus ..
 File size:  1.42 MB
 Viewed:  2307 times
Translated on 25-09-2026, 7:07.
Post20-07-2017, 9:37    Subject: Oily Turbocharger Boost Hose: Causes & Fixes Quote
It looks like the clamp that's supposed to hold the LD hose to the turbo outlet is missing.
Greetings.
Guste.
Translated on 25-09-2026, 7:09.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replace the charging hose at the turbo (AMF) Diesel Engine Technology
No new posts Loud clicking engine noise Seat Ibiza 6j 1.4 TDI BMS PD Diesel Engine Technology
No new posts Where to attach the boost pressure hose Diesel Engine Technology
No new posts What adhesive should be used to glue a turbocharger boost... Diesel Engine Technology
