Electric Heater Repair: Passat 3C TDI
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
matt109
Post24-12-2015, 20:58    Subject: Electric Heater Repair: Passat 3C TDI Quote
Yesterday, I ran a general scan and encountered the following problem.
Address 7D: Auxiliary Heater Label file: DRV\1K0-963-235.lbl
Part number SW: 1K0 963 235 E, Hardware number: 1K0 963 235 E.
Component: PTC element 0404
Revision: 00800000 Serial number:
Operating Number: WSC 00000 000 00000
VCID: 2D7E533DB49AC456C6-8078
"One error found:"
00361 - Heating element for auxiliary heater (Z35).
014 - defective
The error cannot be cleared. However, the electric auxiliary heater can be easily switched on and off using VCDS. It draws approximately 50 amps, and warm air comes out of the vents almost instantly.
Can someone tell me why the auxiliary heater isn't working during normal operation? Is the control unit defective?
By the way, a third-party radio was installed, which explains all the other issues.
Thank you and best regards,
Andreas.
Log-WVWZZZ3CZ6E133503.txt
 kompletter Log
kompletter Log
 File name:  Log-WVWZZZ3CZ6E133503.txt
 File size:  1009 Bytes
 Downloaded:  664 times
Translated on 04-09-2026, 15:06.
matt109
Post24-12-2015, 21:02    Subject: Electric Heater Repair: Passat 3C TDI Quote
Unfortunately, something went wrong with the attachment. Here is the complete scan:
Wednesday, December 23, 2015, 20:39:42:35834
VCDS -- A Windows-based VAG/VAS emulator. Runs on Windows 7 x64.
VCDS Version: RKS 15.7.1.0
Data as of: 20150914.
Vehicle type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 53 55 56 62 69
72 76 77 7D
Vehicle Identification Number: WVWZZZ3CZ6E133503
Mileage: 133,770 km
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-pin diagnostic interface -- Status: Error 0010.
Immobilizer system -- Status: Error 0010.
37-Navigation -- Status: unreachable 1100.
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: Error 0010.
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: Error 0010.
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking assist -- Status: OK 0000
77-Phone -- Status: Error 0010.
7D Auxiliary Heater -- Status: Error 0010.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module
Label file: DRV\03G-906-021-BMM.clb
Part number SW: 03G 906 021 MS, HW: 028 101 271 9.
Component: R4 2.0L EDC G000AG 9390
Revision: --H01--- Serial Number: VWZCZ000000000
Coding: 0000078
Operating number: WSC 52485 133 86045
VCID: 7CD8AE793F609DDE01-8028
No error codes found.
Readiness: 0 0 0 0 1 0
Address 02: Transmission Label file: DRV\02E-927-770.lbl
Part number SW: 02E 300 042 S, HW: 02E 927 770 AE.
Component: GSG DSG, part number 070 1127.
Revision: 04507000 Serial Number: 00000510290029
Encoding: 0000020
Operating number: WSC 44551 111 44551
VCID: 236AB505E25E022660-8076
Address 03: Brake Electronics
Label file: DRV\3C0-614-095-C2.clb
Part number SW: 3C0 614 095 Q, HW: 3C0 614 095 Q.
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658373722
Encoding: 0032037
Operating number: WSC 05311 000 00000
VCID: 30404A49A3A8A9BEED-8064
Address 08: Climate Control/Heating. Label file: DRV\3C0-907-044.lbl
Part number SW: 3C0 907 044 AC
Part number HW: 3C0 907 044 AC
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
VCID: 62E4F001BDC44B2E2B-8036
Address 09: Central Electronics
Label file: DRV\3C0-937-049-23-H.lbl
Part number SW: 3C0 937 049 J, Hardware number: 3C0 937 049 J.
Component: On-board network module H37 1301.
Revision: 00H37000 Serial Number: 00000005199889
Encoding: E78A8F0700041A00000A00000F000000000B5D435C0000
Subsystem 1 - Part number: 3C1 955 119
Label file: DRV\1KX-955-119.CLB
Part: Wiper VW461 012 0503.
Encoding: 00063445
Subsystem 2 - Part number: 1K0 955 559 T
Label file: DRV\1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Encoding: 00217165
Address 15: Airbag
Label file: DRV\3C0-909-605.lbl
Part number SW: 3C0 909 605 K, HW: 3C0 909 605 K.
Part: 0Q AIRBAG VW8R 029 2521
Revision: 10029000 Serial Number: 003A3PNMNMWY
Coding: 0012369
VCID: 2E7C5431B99CBF4EFF-807A
Subsystem 1 - Serial number: 6332MSME0C5F5C10L
Subsystem 2 - Serial number: 6342MSME0C3710724.
Subsystem 3 - Serial number: 6351HTS6I2I2E982$.
Subsystem 4 - Serial number: 6361HTS67SDESO825.
Subsystem 5 - Serial number: 0000000000000000
Subsystem 6 - Serial number: 0000000000000000
Address 16: Steering wheel electronics
Label file: DRV\3C0-953-549-SW20.lbl
Part number SW: 3C0 953 549 B, HW: 3C0 953 549 B.
Component: Steering column module 005 0010.
Revision: 00005000 Serial number: 3C9953507E
Encoding: 0001112
VCID: 2B7A5D258A8ECA66D8-807E
Subsystem 1 - Part number: XXXXXXXXXXX
Component: Steering wheel module 007 0050.
Address 17: Terminal block module.
unavailable
Address 17: Control panel module
Label file: DRV\3C0-920-xxx-17.lbl
Part number SW: 3C0 920 870 Q, HW: 3C0 920 870 Q.
Component: COMBINATION INSTRUMENT VD1 4240.
Revision: X0033000 Serial number: 00000000000000
Encoding: 0007105
Operating number: WSC 11111 111 11111
VCID: 31464F4DA8A2A0B6E2-8064
Address 19: Diagnostic interface
Label file: DRV\3C0-907-530-V1.clb
Part number SW: 3C0 907 530 C, HW: 3C0 907 951 A.
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05B070896
Encoding: 7FFDBC44C62002
VCID: 2166BF0DF842103672-8074
"One error found:"
01300 - Navigation control unit with CD drive (J401)
004 - No signal/communication.
Environmental conditions:
Error status: 01100100
Error priority: 2
Error frequency: 1.
Lost Count: 148
Mileage: 133,776 km
Time: 0.
Date: 2015.12.23
Time: 14:58:19
Address 25: Immobilizer
Label file: DRV\3C0-959-433-25.clb
Part number SW: 3C0 959 433 K, HW: 3C0 959 433 K.
Component: IMMO 038 0367
Revision: 00038000 Serial Number: VWZCZ000000000
Operating number: WSC 131071 1023 2097151
VCID: 32444041ADA49BAE9B-8066
Subsystem 1 - Part number: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
3 error codes found:
02823 - Low Voltage (ELV) locking conditions not met.
000 - - - Sporadically
Error status: 00110000
Error priority: 7
Error frequency: 1.
Lost Count: 169
Mileage: 133,301 km
Time: 0.
Date: 2015.12.09
Time: 06:38:16
02827 - Wake-up request via ESP.
008 - implausible signal - sporadic.
Error status: 00101000
Error priority: 2
Error frequency: 1.
Lost Count: 169
Mileage: 133,301 km
Time: 0.
Date: 2015.12.09
Time: 06:38:17
02861 - Fault in the electronic steering column lock.
Error priority: 4.
Error frequency: 1.
Lost Count: 158
Mileage: 132,996 km
Time: 0.
Date: 2015.11.27
Time: 06:30:05
Address 37: Navigation.
unavailable
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MAX2.lbl
Part number: 1K0 959 701 L
Component: Door seal 024 2461
Coding: 0000247
VCID: 3752715546C67E86AC-8062
Address 44: Steering Assist
Label file: DRV\1Kx-909-14x-44.clb
Part number: 1K1 909 144 J
Component: EPS_ZFLS, Size 5, D04 1606.
Address 46: Comfort System
Label file: DRV\3C0-959-433-46.clb
Component: KSG PQ46 ELV 038 0455
Encoding: 0091020851030E763804941570084F0E703900
Subsystem 1 - Part number: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Component: NGS, not mounted.
Subsystem 3 - Component: IRUE, not mounted.
Address 52: Door electric, passenger side.
Label file: DRV\1K0-959-702-MAX2.lbl
Part number: 1K0 959 702 L
Encoding: 0000246
VCID: 385072694BD871FEA5-806C
2 error codes found:
01553 - Motor for central locking system, passenger door (V57); LOCK.
012 - Electrical fault in the circuit - Intermittent.
00121 - Exterior warning light / door exit light, passenger side.
Address 53: Parking brake
Label file: DRV\3C0-907-801-53.clb
Part number SW: 3C0 907 801 B, HW: 3C0 907 801 B.
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
Address 55: Headlight range control. Label file: DRV\5M0-907-357-V1.lbl
Part number SW: 5M0 907 357 Hardware number: 5M0 907 357
Component: AFS Control Unit X016
Revision: H09 Serial Number:
Encoding: 0000001
VCID: 71C68F4D6822E0B6A2-8024
Subsystem 1 - Part number: 7L6 941 329
Label file: 3D0-941-329.CLB
Component: AFS-List Module l X017
Encoding: 00000035
Subsystem 2 - Part number: 7L6 941 330.
Component: AFS-Lst. module r X017
Encoding: 00000035
Address 56: Radio.
unavailable
Address 62: Door electric, left/right.
Label file: DRV\1K0-959-703-GEN2.lbl
Part number: 3C9 959 703.
Component: Door seal 021 2505
Encoding: 0000144
VCID: 70C08A496328E9BEAD-8024
Address 69: Trailer
Label file: DRV\1K0-907-383-MY7.lbl
Part number SW: 1K0 907 383 Part number HW: 1K0 907 383
Component: ANHAENGERELEKTR 001 0020
Encoding: 0000001
Operating number: WSC 05314 000 00000
VCID: 6AF4982145F4136EE3-803E
Address 72: Door electric strike, right side.
Label file: DRV\1K0-959-704-GEN2.lbl
Part number: 3C9 959 704.
Encoding: 0000144
Address 76: Parking Assist
Label file: DRV\3C0-919-283.lbl
Part number SW: 3C0 919 283 B, HW: 3C0 919 283 B.
Component: Parking Assist System, 8-Channel, Part Number 004 0011.
Revision: 00004000 Serial number: 82930530201678
Encoding: 0011024
VCID: 2870A2299B78E17E35-807C
Address 77: Telephone
Label file: DRV\3C0-035-729.lbl
Part number SW: 3C0 035 729 E, Hardware number: 3C0 035 729 E.
Component: Telephone 6009
Revision: 00008000 Serial number: 0000000678326
Encoding: 0016043
VCID: 256EAB1DEC6AFC160E-8070
00385 - Positive audio output channel for voice/telephone.
011 - Interruption.
Error status: 01101011
Error priority: 3
Error frequency: 1.
Lost Count: 143
Mileage: 121947 km
Time: 0.
Date: 2014.12.14
Time: 00:00:06
00386 - Negative audio output channel for voice/telephone.
011 - Interruption.
Error priority: 3
Error frequency: 1.
Lost Count: 143
Mileage: 121947 km
Time: 0.
Date: 2014.12.14
Time: 00:00:06
01042 - Control unit not coded.
000 - -
Error status: 01110000
Error priority: 3
Error frequency: 0.
Lost Count: 0
Time: 1 minute.
"One error found:"
014 - defective
End----------------------------(Duration: 01:44)-----------------------------
Translated on 04-09-2026, 15:44.
dieselschrauber likes this.
Post24-12-2015, 22:32    Subject: Passat TDI Electric Heater Problem Quote
matt109 wrote:
By the way, an aftermarket radio was installed, which is why there are so many other errors.
It probably has nothing to do with the auxiliary heater, but please fill in the missing control units from the installed parts list. icon_wink.gif You might also experience problems with the quiescent current this way.
Translated on 04-09-2026, 15:45.
matt109
Post24-12-2015, 22:37    Subject: Electric Heater Repair: Passat 3C TDI Quote
Thank you for the tip, Michael.
Can the control units be easily removed and re-registered?
Sorry, I'm a beginner with VCDS...
Andreas
Translated on 04-09-2026, 15:46.
Post24-12-2015, 23:31    Subject: Electric Heater Repair: Passat 3C TDI Quote
Yes, address 19 -> building list -> you can then set and remove the checkmarks accordingly. icon_wink.gif
dieselheinz
dieselschrauber and RedR32 likes this.
Post26-12-2015, 18:20    Subject: Electric Heater Repair: Passat 3C TDI Quote
Hello.
I also once had error code 14 in the auxiliary heater of my 3C.
Helping to fix the issue was resoldering the five larger resistors on the circuit board, which likely had cold solder joints.
The heating system has been working again since then.
The heater is installed in the driver's footwell, on the right-hand side, just above the accelerator pedal.
Perhaps this tip will be helpful to you.
Translated on 04-09-2026, 15:47.
Back to top Profile PM Email
matt109
Post27-12-2015, 17:31    Subject: Electric Heater Repair: Passat 3C TDI Quote
Thank you for the tip. Today, I removed my auxiliary heater and resoldered the connections of the heating elements, and after that, the auxiliary heater started working again.
The installation and removal were quite a hassle. I still have the old version with the integrated control unit; it would be a shame to get rid of it.
You made my day!!
Translated on 04-09-2026, 15:48.
matt109
guste100 likes this.
Post31-12-2015, 11:40    Subject: Setback: Definition, Causes & How to Overcome Quote
After the auxiliary heater started working again, it stopped functioning yesterday and brought back the old, unerasable error message, just like at the beginning.
In another online forum, it was suggested to resolder some SMD resistors. I tried this as a last resort today, and since then, the auxiliary heater has been working again. I don't know how long this will last; hopefully, it will continue to work. If not, I'll probably need to replace it.
Attached is the image showing the resistors that are affected.
Andreas
 Nachgelötete WiderstĂ€nde / MELFs (anderer Zuheizer aber Ă€hnlich)
 File size:  3.11 MB
 Viewed:  16954 times
Translated on 04-09-2026, 15:49.
DieselBĂ€r30x
Avatar-DieselBĂ€r30x
Post31-12-2015, 12:13    Subject: Electric Heater Repair: Passat 3C TDI Quote
Thank you again for your feedback.
These are MELF resistors, not SMD resistors; SMDs are rectangular, while MELFs are round.
Please keep us updated on whether the MELFs are actually causing the problem.
Best regards from Munich!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
Translated on 04-09-2026, 15:50.
matt109
Post31-12-2015, 13:53    Subject: Electric Heater Repair: Passat 3C TDI Quote
Happy New Year to everyone, and always a zero-error, complete scan! icon_biggrin.gif
Andreas
PS: MELFs are also considered SMD components, but MELF is, of course, the precise term. icon_smile_thumb_up.gif
Translated on 04-09-2026, 15:51.
Post31-12-2015, 14:37    Subject: Electric Heater Repair: Passat 3C TDI Quote
Daß der Zuheizer jetzt zum zweiten Mal nach Aus- und Einbau wieder funktioniert bzw. keinen Fehler liefert, lenkt den Verdacht auch auf die Steckverbindung oder die Verkabelung. Let's wait and see.
matt109
Post02-01-2016, 13:45    Subject: Electric Heater Repair: Passat 3C TDI Quote
I hope this continues to be the case, let's see.
The wiring is likely not the issue, as only 2 wires are connected for the CAN bus in addition to the power lines, and the CAN bus has always worked.
Andreas
Translated on 04-09-2026, 15:52.
beatle1971
2006 Volkswagen Passat
Post18-01-2018, 19:33    Subject: Electric Heater Repair: Passat 3C TDI Quote
I'm having the same problem with the auxiliary heater.
However, I'm now unable to get it past the center console and the lower steering wheel cover.
Does anyone have any advice, please?
Marc.
Translated on 04-09-2026, 15:53.
beatle1971
Post19-01-2018, 13:47    Subject: Electric Heater Repair: Passat 3C TDI Quote
So, I ended up having to remove the entire center console, and then I had enough space.
All the best.
No new posts Passat 2000: Sun Visor Light Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Heater Error 02085: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3 BG 1.6 electric radiator fan Electrical Systems, Vehicle Electronics, Multimedia
No new posts 7D - Auxiliary heater malfunction Electrical Systems, Vehicle Electronics, Multimedia
No new posts Polo Glow Plug Error: Get Help Now! Diesel Engine Technology
No new posts Glow Plug Circuit Fault: P0672 & P0673 Codes Diesel Engine Technology
