Disable Audi A4 8W Start Stop System
Thomas-S
dieselschrauber likes this.
Post01-08-2017, 7:29    Subject: Disable Audi A4 8W Start Stop System Quote
Air conditioning / Module 08 > Adaptation > Channel IDE03253 - A/C comfort parameter for start-stop function > Old value: 5 > New value: 0.
The adjustment has successfully disabled the SSA.
In the AI system, whenever the SSA would normally become active, a white symbol indicating "not available" is displayed (a crossed-out starter icon).
There are no further issues, no stuttering, or anything like that.
The button (and the LED inside it) still function as intended, but their effect is not noticeable.
Despite the remaining negative effect (or, conversely, good for TÜV icon_wink.gif), if the climate control unit is completely switched off (using the separate "off" button), the SSA function will also work normally again (in which case, the SSA deactivation button can be used).
"A/C off" alone can be used, while SSA remains "unavailable."
"Note:"
HEX-V2 with VCDS 17.8.
I have an "Audi A4 Avant Sport B9 2.0 TFSI ultra with S-Tronic transmission" that has a "three-zone climate control system."
Translated on 20-08-2026, 9:02.
No new posts Audi A2 to A6 Good Will Policy, Electrical System Area Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Superb 3T: Start-Stop System On-Board Diagnostics (OBD)
No new posts Disable System Start/Stop Feature Electrical Systems, Vehicle Electronics, Multimedia
No new posts Start/Stop is unavailable, what does the measurement bloc... On-Board Diagnostics (OBD)
No new posts Hand-made Start-Stop / general start behavior Diesel Engine Technology
