Turbocharger Boost, Engine BMR Values Needed
Woenckhaus
Post09-08-2017, 21:07    Subject: Turbocharger Boost, Engine BMR Values Needed Quote
I need the values for the position sensor of the vacuum manifold for a BMR TDI 2.0.
Here are the values I need:
Control Unit 01
Measurement blocks 043 (voltage values)
Without running the motor
Valve N75 in the closed position. All hoses are connected normally.
Vacuum chamber, hose disconnected, idle. N75 Does not create a vacuum in the container (VTG rod in contact at the bottom)
Vacuum chamber, tube directly connected to vacuum (Vtg bar is at its maximum position)
Thank you for your efforts.
Jürgen
No new posts P2563 - Positionsgeber für Ladedrucksteller: unplaus. Si... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Erwin - Looking for a repair manual for VAG vehicles Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dodge Journey mit BWD-Motor, Werte der VTG benötigt Diesel Engine Technology
No new posts Positionsgeber für Ladedrucksteller G581 abfragen Diesel Engine Technology
No new posts Daten zum AYQ-Motor gesucht Diesel Engine Technology
No new posts AGR Engine: Boost Pressure Logging Services Needed Diesel Engine Technology
