Passat Diesel Filter Replacement
F B
Post13-09-2017, 16:18    Subject: Passat Diesel Filter Replacement Quote
Hi.
Passat with engine code AVF, 1.9 liters.
What is a 'Pumpe Düse'?
The diesel filter needs to be replaced.
Um, remove the filter, put in a new one.
Possibly fill the new filter with diesel.
Is there anything else I should be aware of?
Is there a pump inside that could break?
Best regards, Frank.
Translated on 02-10-2026, 11:37.
Post13-09-2017, 19:07    Subject: Passat Diesel Filter Replacement Quote
Remove the old filter, fill the new filter, and install it. After turning the ignition on, wait 15 seconds before starting the engine; there should be an electric fuel pump in the tank. icon_wink.gif
Translated on 02-10-2026, 11:38.
F B
Post14-09-2017, 0:08    Subject: Passat Diesel Filter Replacement Quote
I'm handling this motor for the first time, and I thought I'd better ask.
Thank you for the information.
Post14-09-2017, 5:54    Subject: Passat Diesel Filter Replacement Quote
Ideally, after changing and refilling the filter, you should run the pump in the tank using VCDS to remove any air.
F B
Post25-09-2017, 3:10    Subject: Passat Diesel Filter Replacement Quote
Ideally, after changing and filling the filter, the pump in the tank should be run using VCDS. This will remove all the air.
It's working, and thanks again.
The inlet pipe was connected, and the outlet pipe was purged of air using a transparent hose.
Turning the ignition on and off, etc., was sufficient.
I haven't been able to start the pump using only VCDS.
How do you start the pump using VCDS?
Translated on 02-10-2026, 11:39.
Post25-09-2017, 7:28    Subject: Passat Diesel Filter Replacement Quote
Default setting -> Channel 035.
Translated on 02-10-2026, 11:40.
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B ZR Replacement Diesel Engine Technology
No new posts Used ATL 35i Passat, engine 1Z Diesel Engine Technology
No new posts No power after timing belt/chain replacement / Passat TDI... Diesel Engine Technology
No new posts Diesel Filter: Which one is right? Diesel Engine Technology
