Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
29-08-2017, 11:28 Subject: Vacuum Brake Booster: Low Assist at Idle |
Hi there!
Here's the translation:
"This is about the car belonging to my house and groundskeeper."
Volkswagen Passat Variant 3BG 4-Motion with a 1.9 TDI engine (131 hp), first registration in 2002.
It has insufficient vacuum at idle for the brake booster, which means you have to press the pedal very hard, but otherwise everything is normal during regular driving.
Yesterday evening, I meticulously checked the two-part pipe from the tandem pump to the brake vacuum booster (BKV) for cracks on all sides – everything was okay. When pulling it out at the BKV, you could clearly hear the vacuum escaping, so it seems that part is also sealed. All the vacuum hoses for turbocharger pressure regulation, EGR, etc., are new.
"Now, it seems like the tandem pump is the only option left for me. The connection there is also quite loose, but I haven't yet figured out how the pipe is attached."
What are these guys talking about?
Best regards, Rüdi. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 11-08-2026, 20:46.
Profile PM Garage |
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: München & Passau
dieselschrauber likes this. |
29-08-2017, 13:55 Subject: Vacuum Brake Booster: Low Assist at Idle |
Hi Rudi!
Look at this: https://community.dieselschrauber.org/en/viewtopic.php?t=28847
Here's another tip from the link above regarding the connection stub of the tandem pump:
Mpire wrote: | Hello.
Check the connection stub on the tandem pump. It's made of steel and either cast or pressed in – depending on the pump manufacturer – and it might be loose, which could cause air leaks.
What many people don't realize is that the so-called "connection" of the vacuum hose to the main control valve (BKV) in the injection wall isn't actually a direct connection.
This is a rubber connector with a sleeve design, into which one cable from the engine side and one cable from the battery control unit (BCU) are inserted on each side.
This fitting is prone to cracking, becoming brittle, and allowing air leaks into the system.
The part number for the AVF/AWX engine in the 3BG is 8D0611743B. The price is approximately €5.28, depending on the retailer.
Just replace it; my one in the A4 looked fine on the outside back then, but replacing it fixed the problem .
Greetings Mpire | .
Best regards from Munich! 1. S.verlängerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
Translated on 11-08-2026, 20:49.
29-08-2017, 14:09 Subject: Vacuum Brake Booster: Low Assist at Idle |
Thanks for the info; this part can be replaced occasionally, and it doesn't cost much. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 11-08-2026, 20:51.
Profile PM Garage |
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
29-08-2017, 19:47 Subject: Vacuum Brake Booster: Low Assist at Idle |
Evening.
I'm not really a fan of constantly replacing parts.
"Please measure the vacuum pressure at idle and at higher RPM. Then, use a vacuum pump to check if the vacuum control valve (BKV) maintains the correct vacuum level and doesn't drop."
Thilo Kaum macht man es richtig, funktioniert es!
Translated on 11-08-2026, 20:52.
Profile PM Garage |
