BMW 1 Series: Sudden Smoke & No Power?
Cha.oZ
Post15-09-2017, 12:28    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
Hi!
Yesterday, I drove my 1996 Passat as usual.
This morning, when I started it, I noticed that the engine was running a little rough. I gave it some gas, but the RPMs didn't increase much, and it filled the whole street with white smoke.
Does anyone have any ideas?
What surprises me is that there was nothing yesterday.
The diagnostic scan revealed no errors.
Translated on 31-07-2026, 23:07.
vag-driver
Post15-09-2017, 12:50    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
Have you checked all the fluids yet? Especially the coolant?
Andreas
Translated on 31-07-2026, 23:08.
Cha.oZ
Post15-09-2017, 13:00    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
Fit.
If you're talking about the exhaust manifold, it doesn't smoke when idling, and I can't imagine something like that would break down overnight.
Translated on 31-07-2026, 23:09.
vag-driver
Post15-09-2017, 13:11    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
What information is stored in the error memory?
Andreas
Cha.oZ
Post15-09-2017, 13:31    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
Intermittent idle signal.
(The tachometer has been malfunctioning for the past few days, occurring 1-3 times.)
Nothing else.
Post15-09-2017, 15:32    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
1Z suddenly started smoking and has no power.
Here's the translation:
There is a lot of information available here regarding the crankshaft bolt. icon_idea.gif
If you had VCDS, you could compare the actual and target values for the start of injection.
Translated on 31-07-2026, 23:10.
Cha.oZ
Post15-09-2017, 15:38    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
Update:
The oil pressure light is not turning off, and I can smell burning oil coming from the exhaust pipe when idling. The engine hesitates or is reluctant to accelerate. However, I don't hear any knocking sounds.
And that happened overnight? That's somehow illogical.
Translated on 31-07-2026, 23:11.
Post15-09-2017, 15:41    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
Cha.oZ wrote:
Update:
The oil pressure light is not turning off, and I can smell burning oil coming from the exhaust when the engine is idling. The engine hesitates or is reluctant to accelerate. However, I don't hear any knocking sounds.
And that overnight? It's somehow illogical.
Mileage? If very high, consider the possibility of a piston failure...
With VCDS, you can check the idle speed control in the engine control unit. icon_idea.gif
Translated on 31-07-2026, 23:12.
Karma: +647 / -0   Thank you, like it!
Post15-09-2017, 15:46    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
Check valve timing.
Translated on 31-07-2026, 23:13.
Cha.oZ
330,000 km. But a crack overnight? It was running at full power yesterday.
I don't have the "killer screw" installed; I checked it before, and it's already the harder version.
I only have VAGCOM available.
Karma: +1353 / -0   Thank you, like it!
Post15-09-2017, 18:16    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
Translated on 31-07-2026, 23:14.
Post16-09-2017, 5:17    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
Even without a faulty bolt, the shock absorber can sometimes fail abruptly, and this issue can manifest overnight after starting the engine.
Post16-09-2017, 10:24    Subject: BMW 1 Series: Sudden Smoke & No Power? Quote
Cha.oZ wrote:
330,000 km. But a crack overnight? Yesterday it was still running at full power.
You can participate in the Diesel Mechanic Diagnostic Contest. icon_wink.gif
Translated on 31-07-2026, 23:15.
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger/Compressor System No Power - P2263 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Again, problems with V6 TDI engine: knocking, smoking, lo... Diesel Engine Technology
No new posts A6 96 No Power: Troubleshooting & Fixes Diesel Engine Technology
No new posts TDI Engine Problems: Intermittent Power Loss Diesel Engine Technology
No new posts A3 TDI: No Power? Troubleshooting Guide. On-Board Diagnostics (OBD)
