Preheat lamp flashing during driving - and then turning off?
Go to page: 1, 2  Next
Audi_A4_haza
Post07-02-2008, 20:30    Subject: Preheat lamp flashing during driving - and then turning off? Quote
Hello!
First, here's some information about my vehicle:
Audi A4 1Z with VNT17 turbocharger, 0.232 injectors, 16-bit ECU, switchable software, 300kPa sensor, approximately 160 horsepower.
Today, I was driving normally on the highway with a warm engine at approximately 62 mph (100 km/h). Suddenly, the check engine light started flashing without any warning. I didn't notice any loss of power or anything similar. After about 10-15 minutes, the light stopped blinking.
Back home, I started the engine again for a check – and it ran without any problems.
I've used the search function, but I couldn't find anything relevant.
I've only encountered the infamous Relais 109 a few times.
Could this be the reason, or is there a sporadic fault in the engine control unit?
Best regards.
P.S. I installed a remote control system about a week ago, and during the installation, I removed the cover under the steering wheel and the side panel.
Translated on 15-07-2026, 3:43.
Audi_A4_haza
Post07-02-2008, 20:58    Subject: Preheat lamp flashing during driving - and then turning off? Quote
The error log says the following:
VAG-COM version: DRV 311.3-S.
'2 errors found:'
01265 - Exhaust gas recirculation valve (N18).
31-10 - Interruption / Short circuit to ground - Interrupted.
00741 - Brake pedal monitoring.
27-00 - implausible signal.
Translated on 15-07-2026, 3:45.
DieselBär30x
Avatar-DieselBär30x
Post07-02-2008, 21:10    Subject: Preheat lamp flashing during driving - and then turning off? Quote
Hi Haza!
Regarding error code "N18", the only solution is to trace the wiring to that valve using a circuit diagram and check the connectors. Since it doesn't say "intermittent," the error appears to be permanent and relatively easy to locate.
Zu "Bremspedalßberwachung" wirst Du im Bremsensteuergerät ebenfalls einen Fehler eingetragen haben. Schau bitte mal in Gruppe 03 (ABS) in den Fehlerspeicher. Wenn dort "Bremsdruckgeber ... unplausibles Signal - sporadisch" steht, schau als nächstes unten am Bremspedal nach, ob Du einen oder zwei Schalter oben am Bremspedal-Lagerstock hast. Wenn dort ein Schalter verbaut ist, den tauschen. Do not attempt to fix it yourself; it costs approximately 10 EUR at a professional repair shop, and it's a known issue.
Hope I was able to help you, and please keep us updated!
Best regards from Munich!
Translated on 15-07-2026, 3:47.
Audi_A4_haza
Post07-02-2008, 21:12    Subject: Preheat lamp flashing during driving - and then turning off? Quote
Error code: 741.
Brake pedal monitoring - implausible signal.
Possible causes:
Brake light switch (F) defective.
Brake pedal switch (F47) defective.
Switching points of both switches are not synchronized.
What's the best way to proceed now? Or, what's most likely broken?
Translated on 15-07-2026, 3:48.
DieselBär30x
Avatar-DieselBär30x
Post07-02-2008, 21:14    Subject: Preheat lamp flashing during driving - and then turning off? Quote
Translated on 15-07-2026, 3:49.
Audi_A4_haza
Post07-02-2008, 21:32    Subject: Preheat lamp flashing during driving - and then turning off? Quote
hello schmäh.. *g* oops, no, I mean dieselbär icon_smile.gif!
Thank you very much for the answer! You really helped me out!
Best regards from Haza.
P.S. you were too quick with the last post icon_wink.gif, I'm having some internet problems.
DieselBär30x
Avatar-DieselBär30x
Post07-02-2008, 21:40    Subject: Preheat lamp flashing during driving - and then turning off? Quote
"insult"? ...I'll help you right away icon_wink.gif.
Oh, so I was basically too fast - that's what my friend always says *laughs*.
Okay, what I forgot to mention about the brake light switch (you might want to search the forum!): Rotate it 45 degrees, and the old one will come out; With the new one, FIRST pull the pin at the front all the way out, and THEN insert it while the brake pedal is NOT pressed (!) - it might be a little difficult, and the gray pin will slide to the correct length - insert it straight and lock it in place, and then problem number 2 should be gone.It is known that the preheating indicator light flashes when something is not working correctly.
Regarding error 1, please keep us updated and check if you accidentally unplugged or disconnected anything in the cable clutter.
Translated on 15-07-2026, 3:51.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post07-02-2008, 22:43    Subject: Green brake light switch, 4-pin Quote
DieselBär30x wrote:
"Rotate 45 degrees, then the old one will come out; To install the new one, FIRST pull the pin completely out from the front, and THEN insert it while the brake pedal is NOT pressed (!). It might be a little difficult, and the gray pin will slide to the correct length. Insert it straight and lock it, and then problem 2 should be solved."
Warning! Caution! There is now a newer version that MUST be installed when the pedal is not being used. Before installation, apply special grease to the tip. I think it's green - I'll check in the basement.
"Edit."
Okay, the green one is labeled 1C 0 945 511 A and it's chunkier.
The old man was black and thin.
The fat: Urea fat.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 15-07-2026, 3:53.
DieselBär30x
Avatar-DieselBär30x
Post07-02-2008, 23:01    Subject: Subject: Green brake light switch, 4-pin Quote
teileklaus wrote:
the fat: urea fat
"...You're not serious, are you?"
Since when have they been putting "PippiSchmiere" in there? *fg*
Greetings!
P.S.: Did I write anywhere that he should press the pedal at the same time? icon_wink.gif
Translated on 15-07-2026, 3:55.
Audi_A4_haza
Post08-02-2008, 2:13    Subject: Preheat lamp flashing during driving - and then turning off? Quote
Thank you for the answers!
P.S. The thing about the AGR is perfectly normal since I don't have one anymore icon_cool.gif.
Translated on 15-07-2026, 3:56.
DieselBär30x
Avatar-DieselBär30x
Post08-02-2008, 5:04    Subject: Preheat lamp flashing during driving - and then turning off? Quote
Yes, like "without EGR".
You know, all that stuff about the operating license, registration, insurance coverage, *blah blah blah*, and *boring legal jargon*.
AND: You environmental jerk, dude! *dirty laugh*
Okay, the main thing is to avoid EGR sludge in the intake manifold. And there are no oil-damaged poultry icon_smile.gif there either.
Okay, please replace the brake light switch as described above, and that should fix your problem in about 95% of cases.
But please, let's try to stay on topic!
Greetings from Munich!
Translated on 15-07-2026, 3:57.
Audi_A4_haza
Post08-02-2008, 15:03    Subject: Preheat lamp flashing during driving - and then turning off? Quote
Yes, like 'without EGR'?
I only have 2 blind plates instead of the EGR pipe and EGR valve, and 'AGR sludge' is a foreign word to me icon_cool.gif.
I think you almost fell asleep while reading the sentence above (especially considering the time! *lol*).
Grüße aus München!
This morning I drove to work without any problems. What are the consequences if you don't replace this switch? My brakes are working normally.
Translated on 15-07-2026, 3:59.
DieselBär30x
Avatar-DieselBär30x
Post08-02-2008, 16:57    Subject: Preheat lamp flashing during driving - and then turning off? Quote
Well, in my car, the EGR valves are still there - more or less functional!
...because I don't have time to finally tackle that icon_cool.gif.
Just a quick note about the brake light switch:
When you press the brake pedal, information is transmitted via a (2-pole button, 1 normally open contact, 1 normally closed contact... I think) to both the main control unit (MSG) and the braking control unit. The brake lights also illuminate at this time, but its primary function here is to monitor whether the information from the ELECTRONIC accelerator pedal is plausible or not.
Try driving normally and maintaining a speed of 60 km/h - regardless. Then, simultaneously with your left foot, gently apply the brakes. After about 2 seconds, the MSG will immediately reduce the boost, no matter how much further you press the accelerator, because it thinks the gas pedal is falsely transmitting "accelerate," even though you don't want it to. Because simultaneous braking and acceleration doesn't happen in practice.
The system monitors the brake PRESSURE within the line. When you press the brake pedal, brake pressure must be generated.
Since the switch occasionally triggers prematurely and the target brake pressure has not yet been reached, an error code is stored, indicating, for example, that the brake pressure sensor is defective (due to an implausible signal - intermittent).
Yeah, there are even VAG workshops that diligently replace the brake pressure sensor instead of the brake pedal switch. *Shakes head*
I hope I explained it to you in a way that makes sense icon_wink.gif.
Best regards!
Translated on 15-07-2026, 4:02.
Audi_A4_haza
Post08-02-2008, 20:15    Subject: Preheat lamp flashing during driving - and then turning off? Quote
Wow, thanks for the thorough explanation!
So, if I can summarize:
- When accelerating while lightly applying the brakes at the same time, the braking system electronically disengages, meaning you cannot brake.
Translated on 15-07-2026, 4:04.
kfz_al
Registered VCDS User
Post08-02-2008, 20:20    Subject: Preheat lamp flashing during driving - and then turning off? Quote
Audi_A4_haza wrote:
- When accelerating and applying the brakes
lightly at the same time, the brake is electronically released, meaning that I cannot brake }.
Sure, here's the translation:
"Conversely!!!"
"The accelerator is released," but the braking power remains constant!!!
Translated on 15-07-2026, 4:05.
Audi_A4_haza
- When the accelerator pedal is pressed simultaneously with a LIGHT touch on the brake pedal, the braking system is electronically engaged.
withdrawn, i.e., I can't brake normally.
My question regarding this is: What happens if I brake HARD?
-> Is there a serious risk of not being able to brake?
- The brake pressure is not being reached, which means the braking control becomes less precise.
Would you classify this problem as very critical, or only conditionally critical/harmless? (Unfortunately, I won't be able to get it to a workshop this weekend.)
P.S.: On my way home, I didn't notice anything unusual! There were also a few instances of harder braking.
P.P.S: je frĂźher der AGR Mist weg ist umso wohler wirst du dich nachher fĂźhlen! Udependent
Translated on 15-07-2026, 4:07.
No new posts Glow plug light flashing Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf5 Getriebe schaltet während d. Fahrt nicht in alle G... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI engine cut out while driving and hasn't started s... Diesel Engine Technology
No new posts AHF Failure: Troubleshooting & Solutions Diesel Engine Technology
No new posts Motor geht während der Fahrt aus Diesel Engine Technology
No new posts 1Z engine keeps stalling while driving Diesel Engine Technology
