Cha.oZ
15-09-2017, 12:28 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Hi!
Yesterday, I drove my 1996 Passat as usual.
This morning, when I started it, I noticed that the engine was running a little rough. I gave it some gas, but the RPMs didn't increase much, and it filled the whole street with white smoke.
Does anyone have any ideas?
What surprises me is that there was nothing yesterday.
The diagnostic scan revealed no errors.
Translated on 31-07-2026, 23:07.
vag-driver Profi-Schrauber
15-09-2017, 12:50 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Have you checked all the fluids yet? Especially the coolant? Viele Grüße
Andreas
Translated on 31-07-2026, 23:08.
Cha.oZ
15-09-2017, 13:00 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Fit.
If you're talking about the exhaust manifold, it doesn't smoke when idling, and I can't imagine something like that would break down overnight.
Translated on 31-07-2026, 23:09.
15-09-2017, 13:11 Subject: BMW 1 Series: Sudden Smoke & No Power? |
What information is stored in the error memory? Viele Grüße
Andreas
Cha.oZ
15-09-2017, 13:31 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Intermittent idle signal.
(The tachometer has been malfunctioning for the past few days, occurring 1-3 times.)
Nothing else.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
15-09-2017, 15:32 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Quote: | | 1Z suddenly started smoking and has no power. |
Here's the translation:
There is a lot of information available here regarding the crankshaft bolt.
If you had VCDS, you could compare the actual and target values for the start of injection.
Translated on 31-07-2026, 23:10.
Profile PM WWW Garage |
Cha.oZ
15-09-2017, 15:38 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Update:
The oil pressure light is not turning off, and I can smell burning oil coming from the exhaust pipe when idling. The engine hesitates or is reluctant to accelerate. However, I don't hear any knocking sounds.
And that happened overnight? That's somehow illogical.
Translated on 31-07-2026, 23:11.
15-09-2017, 15:41 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Cha.oZ wrote: | Update:
The oil pressure light is not turning off, and I can smell burning oil coming from the exhaust when the engine is idling. The engine hesitates or is reluctant to accelerate. However, I don't hear any knocking sounds.
And that overnight? It's somehow illogical. |
Mileage? If very high, consider the possibility of a piston failure...
With VCDS, you can check the idle speed control in the engine control unit.
Translated on 31-07-2026, 23:12.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +645 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
15-09-2017, 15:46 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Check valve timing. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 31-07-2026, 23:13.
Profile PM Garage |
Cha.oZ
330,000 km. But a crack overnight? It was running at full power yesterday.
I don't have the "killer screw" installed; I checked it before, and it's already the harder version.
I only have VAGCOM available.
Herbert Profi-Schrauber
15-09-2017, 18:16 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Quote: | | I only have VAGCOM available. |
Please see the forum rules.
Herbert. Horch A4 8K CJCD
Translated on 31-07-2026, 23:14.
16-09-2017, 5:17 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Even without a faulty bolt, the shock absorber can sometimes fail abruptly, and this issue can manifest overnight after starting the engine. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Profile PM Garage |
16-09-2017, 10:24 Subject: BMW 1 Series: Sudden Smoke & No Power? |
Cha.oZ wrote: | 330,000 km. But a crack overnight? Yesterday it was still running at full power.
You can participate in the Diesel Mechanic Diagnostic Contest.
Translated on 31-07-2026, 23:15.
