Resetting the inspection service on a 2016 Tiguan using VCDS
William
Post08-10-2017, 21:53    Subject: Resetting the inspection service on a 2016 Tiguan using VCDS Quote
Hello everyone,
I'm having a problem. I can't reset the inspection service reminder on my father's Volkswagen Tiguan, which is a 2016 model with a 2.0 TDI engine.
The car is brand new, and the message appeared now after the first 15,000 kilometers (approximately 9,300 miles).
I tried it first through the automatic service interval reset function, and then also through the control unit 17 (switch panel module), using the adaptation function (10). Neither of those methods worked.
What else can I try? I don't have any ideas right now, and I haven't found anything suitable online either.
I would be very grateful for helpful answers!
William.
Translated on 19-07-2026, 22:31.
Post09-10-2017, 9:49    Subject: Resetting the inspection service on a 2016 Tiguan using VCDS Quote
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Translated on 19-07-2026, 22:32.
William
Post10-10-2017, 12:09    Subject: Resetting the inspection service on a 2016 Tiguan using VCDS Quote
Thank you very much, Rainer, for the reply!
Translated on 19-07-2026, 22:33.
No new posts FSE PREMIUM in Passat, Golf, Tiguan nachrüsten Troubleshooting & Guides
No new posts CNG service reset, gas tank Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Longlife Service Audi Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Service- / Inspektions-Anzeige zurücksetzen (BJ um '98) On-Board Diagnostics (OBD)
No new posts Tiguan 12/2016, Towing Hitch Error On-Board Diagnostics (OBD)
No new posts Service reset failed on Golf Sportsvan 2016 On-Board Diagnostics (OBD)
No new posts Service zurücksetzen Audi A3 8p On-Board Diagnostics (OBD)
