Hello everyone,
I'd like to provide a brief update.
Thanks to the expert articles in this forum and a few videos from YouTube, as well as a S101 model from autodia, I was able to successfully replace the seal under the MSW.
Important: The menu navigation in the S101 is quite archaic, meaning it is not as user-friendly as in VCDS.
However, it was possible to "deduce" that in the engine management system, within measurement block 1 where the engine speed is displayed, my reading was 861 RPM. Also, the displayed fuel quantity of 0005.00 mg/H likely indicates 5.0 mg per stroke.
Then there's the mechanics, which have been described and shown countless times:
- Use the diagnostic tool to record the current values, and I will take photos with my phone.
- Make sure to clean everything thoroughly.
- Mark the approximate position of the MSW (Mandibular Sacroiliac Joint) with a needle or similar tool.
- Unscrew the return line.
- Slightly loosen the inlet valve and turn it off.
- Unscrew the securing point for the electrical cables.
- Completely cover and seal the area with rags or paper, and collect any spilled diesel fuel.
- Then, unscrew the MSW (main system module). A special screw from Bosch is included, and there are many solutions available online.
- Out with the old, in with the new.
- and now comes the tricky part, threading the needle. I practiced a few times until I was sure I had caught the small hole properly.
- The engine started immediately, but it ran very roughly.
- Tighten the screws and use the diagnostic device to correct the position. After the initial adjustment, the engine immediately ran better, and it was almost acceptable at 2.0 mg/H.
Beginner's luck. I managed to get the original setting of 5.0 mg/H back.
Let's see if this gasket actually seals the leak in the ESP (Electronic Stability Program) system.
Peter
Now I'm thinking about VCDS, because a diagnostic tool like the S101, which costs around €130, can be significantly cheaper than the VCDS software. The S101 is borrowed from a colleague who uses VCDS... he doesn't have any older models like mine anymore, and in his Golf I Cabrio, the heart is a 1.8T Audi engine... a somewhat inflated heart
