pp_2000
15-08-2006, 10:22 Subject: ESP Sensor Replacement: Calibration Needed? |
Hello everyone,
I've been browsing the forum, trying to find an answer to my question.
Is a zero-point calibration necessary after replacing the ESP transverse acceleration sensor?
I haven't found a definitive answer on this topic yet. I replaced the sensor in my Golf IV TDI because the error log indicated it was defective. After the installation and clearing the error memory, the error no longer appeared, and the ESP light also remained off. Do I need to perform a "zero offset" now, or does the sensor need to be "calibrated"? I don't want the light to just be off, but I don't actually have ESP functionality  .
Thank you.
pp_2000
Translated on 09-10-2026, 14:04.
15-08-2006, 16:03 Subject: ESP Sensor Replacement: Calibration Needed? |
You can display the values in VAGCOM.
Laptop connected, display -> should show 0, shake the cart -> values are not equal to zero.
EDIT: I suspected as much. I'm only aware of a zero-offset calibration for the steering angle sensor on the steering wheel, and a zero for accelerations is always physically present (unlike the zero for driving straight).
But Sebastian probably knows better.
Translated on 09-10-2026, 14:06.
Profile PM Garage |
15-08-2006, 16:29 Subject: ESP Sensor Replacement: Calibration Needed? |
After replacing individual sensors, a zero calibration is required, even if the measuring devices appear to be displaying correct values.
pp_2000
Jens21_thomas likes this. |
16-08-2006, 7:10 Subject: ESP Sensor Replacement: Calibration Needed? |
Thank you for the information.
Where exactly can I see the values displayed?
Kann ich den Nullabgleich selbst machen mit VAG-COM? If so, how?
Thank you.
pp_2000
Translated on 09-10-2026, 14:07.
sportdiff
18-12-2017, 11:48 Subject: Rotation Sensor Zero Offset Calibration (ESP) |
What prerequisites must be met to perform the calibration of the crankshaft position sensor (ESP)?
Currently, VCDS v17.8.1 is only showing "not available" as an error message in the basic settings menu under the "Brake Electronics" control unit.
Login code has been entered and accepted previously.
The vehicle was also parked on a flat surface.
"Thank you!"
The vehicle is an Audi A4 8K with a sport differential (equipped with two wheel speed sensors).
Here's the car scan:
Code: |
Mittwoch,13,Dezember,2017,16:37:03:39616
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 7 x64
VCDS Version: RKS 17.8.1.0
Datenstand: 20171208 DS276.6
http://shop.dieselschrauber.org/en
Fahrzeug-Ident.-Nr.: WAUZZZ8K4BA0xxxxx KFZ-Kennzeichen:
Kilometerstand: 187740km Reparaturauftrag:
Fahrzeugtyp: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 22 42 46 47 52 53 55 56
5F 62 72
Fahrzeug-Ident.-Nr.: WAUZZZ8K4BA0xxxxx Kilometerstand: 187740km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
18-Standheizung -- Status: i.O. 0000
22-Allrad -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CCWA) Labeldatei:| DRV\059-907-401-V1.clb
Teilenummer SW: 8R0 907 401 J HW: 8K1 907 401 A
Bauteil: 3.0TDI EDC17 H08 0008
Revision: 15H08---
Codierung: 010C002C241F0120
Betriebsnr.: WSC 06335 123 12345
ASAM Datensatz: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 397F43A9B8C3528E96-806C
Readiness: 0 0 0 0 0
Adresse 02: Getriebe (J217) Labeldatei:| DRV\0B5-927-156.clb
Teilenummer SW: 8K1 927 156 H HW: 0B5 927 156 F
Bauteil: 0B5 30 TDIRdW H06 0004
Revision: --H06--- Seriennummer: 0000001318
Codierung: 000001
Betriebsnr.: WSC 06335 000 00000
ASAM Datensatz: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 3A7D5CA5BDC559969F-806E
Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\8K0-907-379-V1.clb
Teilenummer SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Bauteil: ESP8 quattro H04 0050
Revision: -------- Seriennummer: --------------
Codierung: 1C4D0A
VCID: 020DE4459D95D15687-8056
Adresse 05: Zugangs-/Startber. (J393) Labeldatei:. DRV\8K0-907-064-05.clb
Teilenummer SW: 8K0 907 064 CP HW: 8K0 907 064 CP
Bauteil: BCM2 2.0 H04 0430
Revision: 00002001
Codierung: 010200
VCID: 0009EE4D9399C34691-8054
Subsystem 1 - Teilenummer SW: 8T0 959 754 D HW: 8T0 959 754 D
Bauteil: FBSAUDIB8 IDG H50 0070
Seriennummer: 0510000038201013
Subsystem 2 - Teilenummer SW: 8K0 905 852 D HW: 8K0 905 852 D
Bauteil: J764 ELV MLB H37 0042
Seriennummer: 0210000108053012
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei:. DRV\8Tx-820-043-3Z.clb
Teilenummer SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Bauteil: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Seriennummer: 01150620100762
Codierung: 36180000
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\8K0-907-063.clb
Teilenummer SW: 8K0 907 063 P HW: 8K0 907 063 P
Bauteil: BCM1 1.0 H29 0392
Revision: 10029001 Seriennummer: 00000000698174
Codierung: 260050914034AF212701000300001D0D0F9CC74802010141000000
VCID: 3C715ABDBFF167A68D-8068
Subsystem 1 - Teilenummer SW: 8K1 955 119 A HW: 8T1 955 119 Labeldatei: DRV\1KX-955-119.CLB
Bauteil: WWS 110610 H06 0070
Seriennummer: SWF10060115099
Codierung: 00FD11
Subsystem 2 - Teilenummer SW: 8K0 955 559 HW: 8K0 955 559 Labeldatei: DRV\8K0-955-559.CLB
Bauteil: RLS H04 0003
Seriennummer: 10946551
Codierung: 035028
Subsystem 3 - Teilenummer SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Bauteil: E1 - LDS H08 0090
Seriennummer: 00000000000906102017
Adresse 10: Einparkhilfe 2 (J446) Labeldatei:. DRV\8K0-919-475.clb
Teilenummer SW: 8K0 919 475 Q HW: 8K0 919 475
Bauteil: PARKHILFE 4K H06 0070
Revision: 11001001 Seriennummer: 51231017005327
Codierung: 100103
Betriebsnr.: WSC 50385 001 104857
VCID: 479B3551F637347E10-8012
Adresse 15: Airbag (J234) Labeldatei:| DRV\8K0-959-655.clb
Teilenummer SW: 8K0 959 655 J HW: 8K0 959 655 J
Bauteil: AirbagVW-AU10 H41 0610
Seriennummer: 003GKD0H4XL+
Codierung: 30343435363030303030554A304C384B3053
ASAM Datensatz: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 4481225DCF011F66F5-8010
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 6334MSME5431255B9
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 6344MSME543506120
Crashsensor für Seitenairbag hinten Fahrerseite:
Seriennummer: 6352QSME49573C2EX
Crashsensor für Seitenairbag hinten Beifahrerseite:
Seriennummer: 6362QSME4C66103CM
Crashsensor für Frontairbag Fahrerseite:
Seriennummer: 63732SME0265253AW
Crashsensor für Frontairbag Beifahrerseite:
Seriennummer: 63832SME02654504Q
Adresse 16: Lenkradelektronik (J527) Labeldatei:. DRV\8K0-953-568.clb
Teilenummer SW: 8K0 953 568 G HW: 8K0 953 568 G
Bauteil: Lenks.Modul H16 0014
Revision: -------- Seriennummer: 90315JF9000C8
Codierung: 000037
VCID: 3E7550B5A9ED75B6A3-806A
Bauteil: E221 - MFL H02 0010
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:. DRV\8T0-920-xxx-17.clb
Teilenummer SW: 8K0 920 930 N HW: 8K0 920 930 N
Bauteil: KOMBIINSTR. H31 0261
Revision: 00000000 Seriennummer: NW671FE4G
Codierung: 0F1F110083000008000001
VCID: 387946AD8BC94B8669-806C
Adresse 18: Standheizung (J364) Labeldatei:. DRV\8R0-265-105.clb
Teilenummer SW: 4H0 265 105 A HW: 4H0 265 105 A
Bauteil: Standheizung H20 0230
Revision: 34003004 Seriennummer: 20100601224312
Codierung: 5D2000
VCID: 20498ECD33592346B1-8074
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\8T0-907-468.clb
Teilenummer SW: 8T0 907 468 AD HW: 8T0 907 468 K
Bauteil: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Seriennummer: 5600E106070415
Codierung: 00C303
VCID: 0303E141828FD85E8C-8056
Subsystem 1 - Teilenummer SW: 8K0 915 181 E HW: 8K0 915 181 E
Bauteil: J367-BDM H07 0170
Seriennummer: 1001EA99070610
Adresse 22: Allrad (J492) Labeldatei: 8K0-907-163.clb
Teilenummer SW: 8K0 907 163 A HW: 8K0 907 163 A
Bauteil: 4 Wheel Drive H10 0025
Seriennummer: 002805100001073
ASAM Datensatz: EV_AllWheelDiffeQSPCAN 003016
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2E5560F5718D853633-807A
Adresse 42: Türelektr. Fahrer (J386) Labeldatei:. 8K0-959-793.clb
Teilenummer SW: 8K0 959 793 M HW: 8K0 959 793 M
Bauteil: TSG FA H12 0357
Revision: Seriennummer: 0000105518558
Codierung: 011C02204000410001
VCID: 4A9D0C65E525C9160F-801E
Adresse 46: Komfortsystem (J393) Labeldatei:. DRV\8K0-907-064-46.clb
Revision: 00002001 Seriennummer: 0131250415
Codierung: 0100062020B904148120023280000000
Betriebsnr.: WSC 50385 001 1048576
Subsystem 1 - Teilenummer SW: 8K0 959 591 A HW: 8K0 959 591
Bauteil: J245 PS133 H06 0041
Subsystem 2 - Teilenummer SW: 8K0 959 591 A HW: 8K0 959 591
Bauteil: J394 PS229 H06 0041
Adresse 47: Soundsystem (J525) Labeldatei:. DRV\8T0-035-223-BOM.clb
Teilenummer SW: 8T0 035 223 H HW: 8T0 035 223 AK
Bauteil: DSP Prem H10 0120
Revision: 00010001 Seriennummer: 34882002988601
VCID: 3363718192AFA8DE5C-8066
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei:. 8K0-959-792.clb
Teilenummer SW: 8K0 959 792 M HW: 8K0 959 792 M
Bauteil: TSG BF H12 0357
Revision: Seriennummer: 0000105484907
Codierung: 011C02204C00410001
VCID: 499F3369E023C20E06-801C
Adresse 53: Feststellbremse (J540) Labeldatei: DRV\8K0-907-801-V1.clb
Teilenummer SW: 8K0 907 801 H HW: 8K0 907 801 H
Bauteil: EPB Audi B8 H09 0100
Revision: 00000003 Seriennummer: 00000000667938
VCID: 3461729D97A1AFE645-8060
Adresse 55: Leuchtweitenreg. Labeldatei: DRV\8K0-907-357.clb
Teilenummer: 8K5 907 357
Bauteil: Dynamische LWR H01 0010
Revision: 00000001 Seriennummer:
Codierung: 0000004
Betriebsnr.: WSC 06334 000 00000
VCID: 77FB8591065784FEA0-8022
Adresse 56: Radio (R) Labeldatei:. DRV\4F0-035-0xx-56.clb
Teilenummer SW: 4G0 035 053 H HW: 4G0 035 053
Bauteil: Radio U Basic H51 0134
Revision: AB001007 Seriennummer: 496F/0A7513581
Codierung: 010003010000000001
VCID: 234381C1224F385EAC-8076
Adresse 5F: Informationselek. I (J794) Labeldatei:. DRV\4E0-035-6xx-5F.clb
Teilenummer SW: 8T1 035 666 M HW: 8T1 035 666 E
Bauteil: H-BN-EU H51 0187
Revision: -------- Seriennummer: 483CX0BB009900
Codierung: 010100010006A3ED05000F1E000000030000
Betriebsnr.: WSC 28100 141 90975
VCID: 4481225DC7011F66F5-8010
Subsystem 1 - Teilenummer: 8R0 060 884 EM
Bauteil: EUR 2017/2018 2503
Subsystem 2 - Teilenummer SW: 8F0 919 604 HW: 8F0 919 604
Bauteil: DU7 High H42 0098
Seriennummer: 9466FP0A0021780
Subsystem 3 - Teilenummer SW: 8T0 919 609 F HW: 8T0 919 609 F
Bauteil: E0380 Bedient H08 0100
Seriennummer: 00000000566038
Subsystem 4 - Teilenummer: 8R0 060 961
Bauteil: CD-Database 1886
Adresse 62: Türelektr. hi. li. (J388) Labeldatei:. 8K0-959-795.clb
Teilenummer SW: 8K0 959 795 F HW: 8K0 959 795 F
Bauteil: TSG HL H11 0357
Revision: Seriennummer: 0000105598815
Codierung: 010C02204000210001
VCID: 45873F59CC3B266EE2-8010
Adresse 72: Türelektr. hi. re. (J389) Labeldatei:. 8K0-959-795.clb
Bauteil: TSG HR H11 0357
Revision: Seriennummer: 0000105598824
Ende----------------------------(Dauer: 03:29)----------------------------- |
VCDS-User Lkr. Cham
Translated on 09-10-2026, 14:08.
Joined: 04/12/2002 Posts: 18138 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
18-12-2017, 11:59 Subject: ESP Sensor Replacement: Calibration Needed? |
What ESP are we talking about?
Therefore, please always perform a full scan.
Translated on 09-10-2026, 14:09.
Profile PM WWW Garage |
sportdiff
18-12-2017, 15:11 Subject: ESP Calibration: Zero Offset Adjustment |
The previous post has been updated to include information about the automatic scan and vehicle type.
The ESP is version/generation 8.0.
VCDS-User Lkr. Cham
18-12-2017, 16:20 Subject: ESP Sensor Replacement: Calibration Needed? |
Quote: | What prerequisites must be met to perform the calibration of the rotational speed sensor (ESP).
Currently, VCDS v17.8.1 displays "not available" as the only error message in the basic settings menu under the "Brake Electronics" control unit.
Login code was previously entered and accepted. |
Okay, assuming that there are no errors in the relevant control units and that everything is functioning as it should.
Did you enter the correct code to unlock the default settings?
Could you please post a picture showing the basic settings channels you have?
Translated on 09-10-2026, 14:10.
sportdiff
20-12-2017, 10:08 Subject: ESP Sensor Replacement: Calibration Needed? |
Okay, sounds silly, but everything seems plausible. I'll check with the manufacturer.
Screenshot: The "Print" key, located above the "Insert" key, copies the screen content to the clipboard. Then, simply open any graphics program, paste it, and you're done. You don't even need to install a program for this.
Translated on 09-10-2026, 14:12.
21-12-2017, 8:40 Subject: ESP Sensor Replacement: Calibration Needed? |
Please follow up in a few days to make sure it's not forgotten.
What was the actual reason why the sensor needs to be re-calibrated?
Translated on 09-10-2026, 14:13.
sportdiff
21-12-2017, 13:28 Subject: ESP Sensor Replacement: Calibration Needed? |
Hello Rainer,
Thank you in advance for your efforts so far.
I will definitely follow up again, because...
The topic remains relevant.
The reason for relearning the sensor is...
Do not mention the ESP system's apparent settings.
understandable braking interventions.
Sure, everything without any error messages or flashing indicators.
Lights are located within the AI system and therefore not easily accessible.
My assumption is that the ABS/ESP system is malfunctioning due to implausible...
"which is supplied with sensor data, but which is within the tolerance range."
"Garbage in, garbage out" principle.
Some of my log entries fuel this suspicion.
(e.g., different rotation speeds of sensor 1 and sensor 2,
Rotation rates that deviate from the set value by no more than 2°/s during operation.
Tolerance limit is far away.
Sure, here's the translation:
"Please, no tips like: brake firmly, brake hose, etc..."
I've already been through all that hardware hassle.
with success = 0
VCDS-User Lkr. Cham
Translated on 09-10-2026, 14:14.
21-12-2017, 14:02 Subject: ESP Sensor Replacement: Calibration Needed? |
Ah, okay... and what do the wheel speed sensors indicate when the vehicle is stationary?
Translated on 09-10-2026, 14:16.
sportdiff
21-12-2017, 14:49 Subject: ESP: Vehicle Yaw Rate While Stationary |
The rotation rate of a vehicle at standstill.
is less than 1°/s for both sensors.
(approximately 0.07°/s to 0.9°/s)
The tolerance range for a stationary vehicle is:
According to VCDS, +/- 3.5°/s.
VCDS-User Lkr. Cham
Translated on 09-10-2026, 14:17.
21-12-2017, 15:54 Subject: ESP Sensor Replacement: Calibration Needed? |
Okay... as I said, I'll check with the manufacturer again; as far as I can see, it should actually work. Whether that will be helpful in your case is, of course, another matter.
Have the ABS rings and sensors been checked for dirt or rust particles, and have they been cleaned?
Translated on 09-10-2026, 14:18.
sportdiff
21-12-2017, 18:49 Subject: ESP Sensor Replacement: Calibration Needed? |
This vehicle does not have ABS rotors; instead, it uses active wheel speed sensors that capture the signal via the wheel bearing (magnetic ring).
And as I mentioned, all the hardware related to the wheels and brakes has already been done and checked.
The two rotational speed sensors seem the most plausible to me at the moment.
VCDS-User Lkr. Cham
