I've been having a problem with my Seat Ibiza FR 2.0, 143 hp (year 2011, approximately 140,000 km) for about 5 weeks.
The following "errors" occur consistently:
- After each trip, the radiator fan runs at full speed.
- LL speed approximately 1000 RPM.
- very hot exhaust gases
- Very high fuel consumption (between 7.5 and 8.3 liters per fill-up in the last 5 times, otherwise around 5 liters).
- Power consumption while idle: 1.2 liters per hour.
- Fuel consumption reading is normal (last fill-up according to the car's computer: 4.3 liters, actual consumption at the gas station: 7.5 liters).
- no indicator light
As I interpret it, these are signs of DPF regeneration, but it hasn't stopped for over 2000 km.
"Reading the error codes at a local garage yielded no results. Today, I finally had an appointment at the official dealership, and... SEAT wants proof that the fuel consumption has increased, so receipts with photos of the mileage + fuel receipts, etc. Nothing was done, not even reading the fault codes. I don't understand this approach by SEAT; they could at least read the fault codes and not make me feel like I'm unbelievable or someone who can't calculate their fuel consumption."
Can anyone tell me if I might be right with my assumption? Or has anyone else experienced similar problems and found a solution?
Unfortunately, I don't have a way to read the sensor data, so I have to wait for Seat and "waste" another tank of fuel, which will consume almost 8 liters.
Sure, no problem. Here's the translation:
"Thank you very much in advance... Best regards, Fraker"
Translated on 19-10-2026, 21:03.
