Mercedes G290TD Diagnosis: OM602.983 (W461)
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
On-Board Diagnostics (OBD)
View previous topic
View next topic
Author
Message
Mark1234
2000 Mercedes-Benz G Class
02-04-2018, 17:59
Subject: Mercedes G290TD Diagnosis: OM602.983 (W461)
Quote
I am a customer who uses VCDS and GS911 diagnostic tools, and I now own a Mercedes (see above). The vehicle has a 38-pin connector installed.
Is it possible to read the engine control unit (ECU) data using VCDS? Which adapters are necessary?
Mercedes EVE Bosch distributor injection pump N3/8.
MB No.: 026 545 15 32
Bosch Part No. 0281001953 BOSCH EDC 1.4 (MSA 15.2-3.23)
Hardware Version 45/95
Software Version 21/98
I also have a Carsoft 7.4 multiplexer.
Thanks & Regards,
Mark.
Das Leben ist zu kurz, um Ketten zu fetten
Touareg V10 TDI, BMW 1200 GS ADV
Translated on 18-09-2026, 16:42.
Profile
PM
Garage
2018 Volkswagen T6
03-04-2018, 17:31
Quote
Is it possible to read the engine control unit with VCDS
No, if that were possible, then OBD2 would be an option, but if your Benz had it, it would also have the OBD2 port in the car.
Dipl.-Ing. (FH) Rainer Kaufmann -
Original VCDS mit KPower, KDataScope und Dieselschrauber Support
Translated on 18-09-2026, 16:44.
Profile
PM
WWW
Garage
New Topic
Reply
View previous topic
View next topic
Topic
Forum
DIY OBD Adapter: Build Your Own Diagnostic Tool
Troubleshooting & Guides
Passat combination instrument cluster 05.99 to 09.2000
Document 1J up to week 38/2000, ABS control light is on.
VW & Mercedes Diagnostic Kit: Which One to Buy?
Ford Focus TDI Diagnostic Tool (2000)
Can I install a motor control unit from a W210 E290 TD in...
Mercedes LMM to VW: Conversion Guide
Diesel Engine Technology
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Kaufmann Automotive GmbH
Shop für Kfz-Diagnosegeräte
. Parse time: 0.072s
