walti130
Joined: 11/14/2017 Posts: 4 Karma: +0 / -0 Location: st.georgen
16-11-2017, 23:37 Subject: VW Passat TDI: Black Sludge - PD Engine Fix |
Greetings from Austria.
No power, low boost pressure, black sludge in the fuel system.
Fuel filter replaced (the filter housing was very dirty), fuel level sensor with fuel pump removed (there was even more dirt there, it looked like black sludge). Clean the fuel level sensor and fuel tank. Of course, several test drives were carried out in the meantime, but with no significant results. The last step was to remove the valve cover, check the hydraulic lifters, and inspect the rocker arm shaft for the common rail injectors (side plugs are present). The common rail injectors were removed (they were quite tightly integrated into the cylinder head, which I found to be a bit too loose). I can't say whether the problem was caused by the contamination of the fuel supply to the common rail injectors or by an inadequate seal between the common rail injectors and the cylinder head. In any case, after replacing the common rail injectors with four used ones, including a new gasket set, the problem was solved.
Sincerely,
Walti 130. audi a6 4f5 2,7 tdi 132 kw
Translated on 12-10-2026, 13:47.
Turbinchen Profi-Schrauber
Joined: 04/10/2008 Posts: 201 Karma: +76 / -0 Location: 95615 Marktredwitz 2014 Audi A4 Avant Support
dieselschrauber likes this. |
17-11-2017, 6:04 Subject: VW Passat TDI: Black Sludge - PD Engine Fix |
Black sludge reminds me of the "Dieselgate" scandal; in this case, it's likely that problems will arise again.
If the filter clogs again after a short time, you should check out Grotamar and examine the (yard/farm?) fuel station and fueling habits.
Translated on 12-10-2026, 13:49.
Profile PM Garage |
walti130
17-11-2017, 22:06 Subject: VW Passat TDI: Black Sludge - PD Engine Fix |
Thanks for the tip, I already added an antibacterial additive to the diesel, I think it's from Pro Tec. audi a6 4f5 2,7 tdi 132 kw
walti130
17-11-2017, 22:23 Subject: VW Passat TDI: Black Sludge - PD Engine Fix |
In Austria, we have a biodiesel content of up to 7 percent in diesel fuel, which is why fungi and bacteria can thrive in the fuel tank.
And let's not even talk about the resulting engine wear (the regeneration process of the particulate filter leads to oil dilution). audi a6 4f5 2,7 tdi 132 kw
Translated on 12-10-2026, 13:50.
Bertil Profi-Schrauber
walti130
19-11-2017, 22:14 Subject: VW Passat TDI: Black Sludge - PD Engine Fix |
Then everyone in the EU faces the same problems. audi a6 4f5 2,7 tdi 132 kw
Translated on 12-10-2026, 13:51.
