{SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P (Solution)
Herbert and Thomas1987 likes this.
Post16-11-2017, 18:35    Subject: {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Quote
In an Audi A3 8P 2.0 TDI with CFFB engine, noticeable and difficult-to-locate knocking noises occurred between 1200 and 1400 rpm.
The roaring sound comes from the 180° bend of the air intake pipe from the air filter to the radiator grille, along with the small air box on the radiator grille. Check the airbox on the radiator grill for a secure fit (using Torx screws), inspect the vibrating surfaces of the individual components (disassemble) and degrease with acetone, then cover with thin felt strips so that nothing can rattle anymore.
 File size:  1.24 MB
 Viewed:  1603 times
Ratings - {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P
No new posts MKB Engine Noises: Rumble & Knock at 2900 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4 8D, Rumble/Drone Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Noises: Rumble & Drone Explained Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Golf 3: Engine Noise at Idle Diesel Engine Technology
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts Audi 80 B4 On-Board Diagnostics (OBD)
