Help 3.0TDI Commonrail - No Rail Pressure
geoball333
Post27-08-2018, 18:21    Subject: Help 3.0TDI Commonrail - No Rail Pressure Quote
Hello, we are slowly running out of options.
After replacing the high-pressure pump and cleaning all components of the electrical system, and changing the filters, the Touareg 3.0 TDI no longer has rail pressure. Only does the pressure increase to approximately 80 bar after a long start-up. The high-pressure pump and the pressure regulator on the rail are new. All E-valves from the fuel supply have been disconnected, and both rails have been closed at all connections and checked for pressure with a Condor pressure gauge. No pressure. Since our motor has 2 high-pressure connections, we were unable to measure the pressure in the HD pump (connections for testing were not present because the threads were larger than those on the rail).
Do you have any advice for me?
All connections on the D-filter are correct. Bleeding with VCDS without air bubbles has been completed. Return line is clear and diesel is being returned.
Post27-08-2018, 19:37    Subject: Help 3.0TDI Commonrail - No Rail Pressure Quote
I haven't done that yet, but I've already checked the simplest option? Hoses connections on the diesel filter not reversed and is it sealed and there is no air being sucked in anywhere?
Best regards, Rainer
vwSchrauber
dieselschrauber likes this.
Post28-08-2018, 11:13    Subject: Help 3.0TDI Commonrail - No Rail Pressure Quote
Because our motor has 2 high-pressure connections, we were unable to measure the pressure at the HD pump.
Then it is a Euro 5 engine with CP4.2 - this requires a pressure of 4 bar at the inlet. No template -> no rail print icon_wink.gif
No new posts Low rail pressure, 3.0 CR-TDI General Tips
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy: Jerky Engine, G28 Sensor, Low Rail Pressure Diesel Engine Technology
No new posts Help for the 3.0 TDI engine with code: ASB Diesel Engine Technology
No new posts AFN Turbocharger: 2 Bar Boost, No Limp Mode? Diesel Engine Technology
No new posts Passat Starting Problems: No Error Code, Help! Diesel Engine Technology
