P0500, P0501, P0502, P0503 - Speed Sensor (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Post16-12-2017, 1:15    Subject: P0500, P0501, P0502, P0503 - Speed Sensor Quote
The error codes P0500 - P0503 are related to inappropriate or faulty speed measurement values.
In older vehicles, the speed signal is obtained from the mechanically driven speedometer, while in newer vehicles, it is obtained via the ABS sensors on the wheels.
Iron filings and rust particles, as well as mechanical damage to the ABS rings, and excessive wheel bearing play can lead to inaccurate wheel speed measurements, even if the sensor and its wiring are functioning correctly.
Ratings - P0500, P0501, P0502, P0503 - Speed Sensor
No new posts P0501 Error Code: Causes and Fixes On-Board Diagnostics (OBD)
No new posts Werte Geschwindigkeitssensor Transmission, Chassis, Body & Interior
No new posts Geschwindigkeitssensor wechseln Golf IV, 1,4 Transmission, Chassis, Body & Interior
