Hufe Schrauber
Joined: 06/09/2015 Posts: 64 Karma: +22 / -0 Location: Bad Münstereifel 2004 Audi A6 Avant Support
dieselschrauber likes this. |
17-07-2019, 19:21 Subject: Parking Assist Fault: Troubleshooting & Repair |
Hello everyone,
My parking assist system is no longer beeping.
VCDS indicated that a sensor was faulty, which I replaced. Now, all 4 sensors are providing correct readings, but there's still no sound.
Error memory is empty.
Could you tell me which PIN output on control unit 8Z0 919 283 (parking assist control unit, manufacturer SWF) is responsible for the sound? That way, I could measure whether the control unit is faulty or if the speaker is defective.
Thank you!! Beste Grüße,
Hufe
Translated on 30-08-2026, 6:08.
Profile PM Email Garage |
vag-driver Profi-Schrauber
22-07-2019, 12:02 Subject: Parking Assist Fault: Troubleshooting & Repair |
I would measure the voltage at the buzzer. Mine was also defective on my A4. There is a very high probability that the wire connecting to the membrane inside the buzzer has broken. Viele Grüße
Andreas
Translated on 30-08-2026, 6:09.
Hufe Schrauber
26-09-2019, 7:58 Subject: Parking Assist Fault: Troubleshooting & Repair |
Better late than never: The solution.
The speaker was defective. I was able to measure the output signal in the 0.0...V range.
I tested it using an old speaker from a walkie-talkie. Beste Grüße,
Hufe
Translated on 30-08-2026, 6:10.
Joined: 04/12/2002 Posts: 18107 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
28-09-2019, 9:56 Subject: Parking Assist Fault: Troubleshooting & Repair |
Translating... |
[Translating...]  |
Profile PM WWW Garage |
