Too much oil pressure, no compression, AFN engine
Go to page: 1, 2  Next
berger20000
Post02-02-2014, 21:18    Subject: Too much oil pressure, no compression, AFN engine Quote
Hello everyone,
I bought a Golf 3 TDI AFN with 254,000 km, manufactured in October 1997. I've noticed the following issue: If I rev the engine too high too quickly, it stalls and loses compression. It also doesn't start immediately; it takes about 10 minutes to start again. However, once it's warm, you can accelerate as much as you want.
I suspect the following:
- The oil pump generates too much oil pressure when the engine is cold, which pressurizes the hydraulic lifters and then causes a loss of compression!
What do you think about that? Have you ever experienced anything like this before?
I would now add an engine flush and then replace the oil pump.
Michael.
Audi A4 B6 2.5TDI Quattro
Skoda Superb 4x4 TDI CR2
Polo 6N 1.8T AUQ
Karma: +590 / -0   Thank you, like it!
Post02-02-2014, 21:28    Subject: Too much oil pressure, no compression, AFN engine Quote
Hello!
Okay, I already checked, there's too much oil pressure.
With the VR-6 engine, there were then problems with the chain tensioner. Because he pressed down too hard.
It's fundamentally possible, as you suspect.
I've already read about such strange things.
I would advise you to measure the oil pressure using a pressure gauge.
The maximum permissible pressure for the Corrado was 5.5 bar.
There's a pressure relief valve stuck in the oil pump. As far as I can remember, that was then fixed by an improved oil pump.
Post02-02-2014, 23:24    Subject: Too much oil pressure, no compression, AFN engine Quote
I would start by changing the oil filter and filling the engine with oil that meets the VW specification 50500 (50500 should also be suitable for the AFN engine).
Post03-02-2014, 12:06    Subject: Too much oil pressure, no compression, AFN engine Quote
icon_smile_thumb_up.gif. If that doesn't help, I would first check the hydraulic lines for leaks, or perform an oil pressure measurement, if you have the appropriate measuring device available.
berger20000
Post03-02-2014, 13:06    Subject: Too much oil pressure, no compression, AFN engine Quote
I just spoke with the owner before the previous owner... He also experienced the same issue at 150,000 km. He has already tried many different oils that were approved. However, it didn't bring any improvement...
I'll check the oil pressure in the next few days and see what the gauge reads when the problem occurs... Should I measure the temperature at the head, the oil filter housing, or both?
Thank you in advance.
Polo 6N 1.8T AUQ
Post03-02-2014, 13:10    Subject: Too much oil pressure, no compression, AFN engine Quote
Don't forget to check the bypass valve. Similarly, relay "109".
Post03-02-2014, 14:08    Subject: Too much oil pressure, no compression, AFN engine Quote
The achieved oil pressure should ideally decrease as the pump gears wear out. Increasing axial and radial clearance leads to increased leakage towards the suction side.
Therefore, the suspicion is either an unsuitable oil or a clogged filter.
To measure the oil pressure, you need to remove one of the oil pressure switches.
Was there ever any work done on the valve lifters (or camshaft)? (e.g., replacement, aftermarket parts).
Given the mileage, I would replace the hydraulic lifters anyway.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post03-02-2014, 14:55    Subject: Re: Too much oil pressure, no compression, AFN engine Quote
berger20000 wrote:
Hello everyone,
then replace the oil pump...
Michael
That's probably the problem, as the pressure relief valve is likely stuck. It's quick and easy to change the cross-flow air filter.
reflexsilber met.
Post03-02-2014, 15:09    Subject: Too much oil pressure, no compression, AFN engine Quote
I had the same issue with my 1Z engine once; the pressure relief valve was defective, resulting in over 7 bar of pressure in a cold, idling state. icon_eek.gif Changing the filter and doing an oil change didn't help. And that was in the middle of summer, with temperatures exceeding 30 degrees Celsius in August 2003!
"At the time, I installed a used pump including an overpressure valve, and the problem disappeared! I measured the oil pressure at the oil pressure switch on the oil filter housing." I would start by checking the oil pressure – it provides clear information.
Klausel
Post05-02-2014, 1:09    Subject: Too much oil pressure, no compression, AFN engine Quote
dieselschrauber wrote:
Don't forget to check the shut-off valve.
There isn't one in my AFN in the G3.
Are there any AFNs (presumably referring to a type of firearm) with a closing valve?
Greetings, Klaus.
Polo 6R, TSI 110 PS
Post05-02-2014, 9:43    Subject: Too much oil pressure, no compression, AFN engine Quote
Klausel wrote:
Do not forget to check the
shut-off valve.
Greetings Klaus
Hm, right? I probably confused it with the "newer" ALH/AHF engines, which have a vacuum-operated shut-off valve located on the intake manifold.
berger20000
Post09-02-2014, 12:46    Subject: Too much oil pressure, no compression, AFN engine Quote
Hello everyone...
Just measured the oil pressure at the head while the engine was cold; it was 6 bar until it dropped and there was no more compression.
"When it's warm, it has 3 bar of pressure and runs normally!"
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation.
Michael.
Polo 6N 1.8T AUQ
Post09-02-2014, 13:04    Subject: Too much oil pressure, no compression, AFN engine Quote
Both are perfectly healthy values.
Post09-02-2014, 13:55    Subject: Too much oil pressure, no compression, AFN engine Quote
Just measured the oil pressure at the head while it was cold, 6 bar until it drops and there is no more compression...
I have no idea how much oil pressure he (the engine) loses in the cold state before reaching the last bearing point in the cylinder head.
I would first check the oil pressure again at the oil filter housing. If it exceeds 7 bar, that's too much.
The pressure relief valve should open between 5.7 and 6.7 bar.
Post09-02-2014, 15:36    Subject: Too much oil pressure, no compression, AFN engine Quote
The AFN should have the same test values as the 1Z.
The measurement is taken using the oil pressure switch, with the engine warm, at an oil temperature of approximately 80°C.
- Oil pressure at 2000 rpm: at least 2.0 bar;
- Oil pressure at higher RPM: max 7.0 bar.
Measurements without reference to speed are not meaningful.
Where at the ZK did you measure something, and with what?
berger20000
Post09-02-2014, 16:18    Subject: Too much oil pressure, no compression, AFN engine Quote
So, the specified oil pressure is the maximum value.
When cold, the oil pressure is 3.5 bar at idle and 6 bar at 4000 rpm.
And warm, 0.5 and 3 bar.
Measured with an analog pressure gauge on the right-hand side, where the oil pressure switch is normally located.
I won't be able to take another measurement at the oil filter housing until next Saturday! Since it has to be cold.
Polo 6N 1.8T AUQ
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Allroad Luftfahrwerk - keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 2.5 TDI: No Compression in Cylinder 2 Diesel Engine Technology
No new posts CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Diesel Engine Technology
No new posts Boost Too High: No Limit on Audi AFN Engine? Diesel Engine Technology
No new posts AFB - Kompression Diesel Engine Technology
